View Full Version : Forced Induction
  1. What makes an engine able to make more power on pump gas?
  2. Guys logging pressure ratio
  3. Wiring a Two-step?
  4. What's the largest T4 turbo that would drop in where my TC76 is now?
  5. Lt1 mainfold!!!!!!
  6. Hissing noise when I hit boost
  7. Centrifugal Supercharger w/ Front Mount Intercooler
  8. Coating IC Parts?
  9. Intakes for boost
  10. procharger question
  11. My 71 camaro LS2 w/ MAG build
  12. Wastegate
  13. How strong is the LSX 376
  14. meth and nitrous At the same time?
  15. compression to low or no? mill heads or no?
  16. LS1+Procharger+10psi+meth= Which Fuel Pump??
  17. Took the GT55 Turbo Z06 to the track tonight...
  18. Procharger idler bearings?
  19. the "Catch Can"
  20. Anyone have specs on this turbo by chance?
  21. Any maggied ls1's out there??
  22. Stock plug wires or aftermarket?
  23. Bought used STS kit and found small amount of oil inside intercooler
  24. Aluminum vs Iron.....
  25. 9lbs of boost then nothing on Vortech Ttrim
  26. 408 s91 boost question with l92s through exhaust
  27. '98 WS6 Trans Am, 8 yr old ProCharger - Not Building Boost?
  28. Roots blown 4th gen question about k member spacers
  29. who to have spec a turbo cam?
  30. Cheap vortech v9 f-trim!!!!!
  31. ATI Super Damper Pinning
  32. Edelbrock TVS2300/GMPP L92/LS2 questions...
  33. Cold Side Pipe Size Step
  34. Blower cams?
  35. The Pass Time Experience
  36. LS3 3bar map sensor??
  37. Deja Vu. Forgive the non LSX build.
  38. cleaning out exhaust pipes
  39. aps twin turbo on gto questions
  40. piston limits
  41. Night Ryders 106mm build
  42. What kind of oil do you recommend?
  43. Any Turbo Kits I can bolt on from home w/o losing AC?
  44. Check Valve Needed... Where Would I Get On?
  45. cog pulleys bare or anodized ?
  46. Turbo help
  47. Process of Mounting Intercooler
  48. Making the switch from Procharger to Turbo
  49. Truck manifold question i gotta ask
  50. pulley interchangability
  51. Force induction + nitrous
  52. Best Map for 18+lbs
  53. innovators west
  54. Procharger Intercoolers...
  55. Vortech T trim Vs Procharger D1SC
  56. Used STS kit?
  57. What are the correct valves (LS3 head) for FI
  58. What intercooler are you guys running
  59. Engine builder Recommendations
  60. TVS Guys...
  61. Engine for turbo application
  62. Ems dilemma efi live, hp tuners, pro efi, bs3
  63. Congrats Mike Brown and Ray Litz (wins at Norwalk)
  64. Anyone useing the 3.3 Bar Delphi Map sensor ?
  65. Looking to be pointed in the right direction
  66. procharger balancer
  67. Smoking at idle BAD
  68. More JGS wastegate springs?
  69. procharger 8 rib crank pulley options
  70. F1r vs F2
  71. procharger 8 rib slipping
  72. Anyone using Spek boost controller?
  73. Answered my ? 6.0 is 9.teen for my rear mount
  74. How much hp on stock 6.0 crank
  75. How much boost on stock plastic intake
  76. upgrading to 8 rib
  77. turbo build cost
  78. Dyno on wednesday quess HP
  79. SLP LM2 for turbo
  80. D1SC Questions
  81. Gasket Thickness?!?!
  82. For Those Who WANT To KEEP A/C !!! single or twin lOok InSiDe!
  83. F1A question (got a lot louder)
  84. Engineering the weak link into my project
  85. let me hear a sound clip of your turbo/turbos
  86. cam help on 6.0 truck manifold build
  87. help!!!!
  88. Piston Sleeve Wear
  89. Those with turbos and A/C
  90. Magnacharger tune
  91. Building Boost w/ 2 Step In A 6SPD Car
  92. procharger s fan
  93. F1A procharger setup
  94. JetHot 2000 Coating on Turbo Manifolds, Did you coat the inside?
  95. LS6intake/78mm TB vs. LS2intake/90mm TB for 1000rwhp? Restriction....
  96. STS turbo Kit for Sale 2500 OBO
  97. stall/gear suggestions to use with Brute Speed/EPP cam
  98. Starting a build thread
  99. ProCharger adds intercooler options to their GTO systems!
  100. 90* silicone TB hose.
  101. 107,000 boosted miles comes to an end!
  102. Wish me luck!
  103. intercooler upgrade?
  104. 2008 Silverado ext cab - est MPG with a MP76?
  105. Underhood temps of 170-180F - normal??
  106. First turbo build. Couple of questions
  107. My Precision 76mm turbo build
  108. RACEPAK... IQ3 vs UDX ? whats better for ForcedInduction
  109. Source for cheap and cheap-er turbos?
  110. Intercoolers:Twins VS Front Mount?
  111. You guys using special gaskets for exhaust manifold to piping?
  112. wanting to test fire motor before kit is on car.
  113. Procharger rotation question
  114. How much to expect from a cam swap?
  115. Can you keep DOD with forced induction?
  116. maximum safe rpm of stock internals??
  117. Anyone try a b1 with turbo?
  118. Rear Mount Turbo??????
  119. 364ci forged engine: best intake and cyl head combo? Comp Turbo CT81 setup
  120. WHO sells ported throttle bodies with the meth nozzle tapped?
  121. Rear mount on stock 5.3l
  122. 5.3l and 88 mm turbo? Pros and Cons Good or Bad?
  123. F-body screw and roots blower ppl enter
  124. 4th gen LT1 to 5.3 turbo budget
  125. **LMR Standing Mile Corvette Updated Pics***
  126. Need some help Please.
  127. New record: 7.66@177mph
  128. Source for cheap and cheap-er turbos?
  129. 2xxx Tahoe Turbo E85 Conversion
  130. what are stock bottom end ls3/l92's making
  131. Oil Feed line for front mount turbo
  132. 2010 base 4.8 truck 2wd mpt76q trim build
  133. My Sleeper!
  134. Screen for procharger inlet
  135. Just wondering about my 402, D1sc setup.. opinions?
  136. BOV location and FMIC question
  137. Gear drive on the street: Durability???
  138. carbed blow through!!!!!!
  139. anyone interested in trading new smaller new for bigger used??
  140. Turbo Tuner Charlotte NC or Surrounding Area
  141. procharger.com are spec on head unit accurate?
  142. Head Gasket Issue
  143. how to remove a Procharger head unit
  144. Which 3 bar map for 102mm LsxR Intake?
  145. ls3 cylinder head gasket to lower the compression ratio
  146. APS kit got me an Tax audit.
  147. ? re: exhaust manifolds for turbo setup
  148. ?s for the big power procharger guys
  149. can i get some opinions on this turbo please...
  150. dyno results t76 ls1 setup
  151. My 1225 RWHP C6 Z06
  152. couple questions for the remote turbo guys...
  153. Intake and TB Recommendation
  154. Good converter companies for turbo cars
  155. mp t76 ?
  156. vid of new 88s on dyno
  157. which pin kit for slp underdrive pulley
  158. V6 camaro turbo
  159. do i need to pin my crank pully?
  160. procharger race blowoff valve
  161. What size turbine in PT88?
  162. p1sc question
  163. diesel turbo question
  164. after shutdown bearing lube
  165. LS2 corvette turbo drain to pan question...
  166. Mustang supercharger question.
  167. Finally some track times!
  168. Vortech SC belt sizing
  169. how would an Evo turbo do on a stock LS1?
  170. who is the fastest 6.0 stock headed/stock crank/truck manifold turbo car?
  171. twin turbo lt1 z
  172. *aps kit with kando carts update*
  173. Procharger Inlet Problem/Question?
  174. Lets see u procharged strokers out there!
  175. Best Turbo Route for 7s?
  176. Mac Mids on a rear mount setup
  177. Help me pick a BOV, Questions!
  178. Which shortblock?
  179. twin turbo vs turbo
  180. Possible causes of seized PT88...?
  181. ARP head bolts?
  182. What should I do? Help!
  183. grand national turbo on lt1 ?
  184. Started the car for the first time... Vid inside... Need help ASAP!!!!
  185. another FMIC MP t70
  186. What to do about APS turbos?
  187. Boost Response & Backpressure VS Turbine Dia and Housing AR
  188. Rear Mount turbo on my '98 WS6. Need help
  189. okay..Snow variable controller..placement??
  190. help picking a turbo
  191. Boost? What Boost?
  192. Pinning front of crank?
  193. National Speed Build: 2010 Chevrolet Camaro - Eric Berry - NZ1200 - 1,200hp+...
  194. Two step ?
  195. Critique my set-up, I want more power!!
  196. Custom STS build questions?
  197. 434lsx what turbo thinking of a s91??
  198. ProCharger pricing changes 8/23/10
  199. i need help please
  200. 2 Turbo/ Tuning Questions
  201. What plugs yall running.
  202. sluggish boost on transbrake
  203. N20 to spool turbo
  204. Going from a 22x19x2 to a 24x19x1 to try and solve over heating problem...
  205. Is a support required for twin turbo setup?
  206. 2 bar map not registering boost
  207. Coolant temp issue (stop and go driving) on front mount turbo
  208. Header advice
  209. Have you played Car Town yet? Game for car people on Facebook
  210. APS owns with LG upgrades inside please
  211. Those with alt's on pass head w/ turbo by battery
  212. need help with smoking
  213. 82mm Turbo on 347ci !! Lots of questions
  214. u1016 loss of comunication with VCM !!!!
  215. what map do i need 2 bar or 3????help
  216. looking for a 5.3 or 6.0 long block
  217. what the best spark plug ? 18 psi
  218. Help Me with my build!
  219. turbo vs. procharger
  220. D-1 Rebuild Time - How Many Miles On Yours?
  221. LSX Silverado Turbo build !!! pics...
  222. Camaro Turbo Build
  223. LSA Supercharger on ebay
  224. What turbo for a front mount 403? Space is VERRY LIMITED!
  225. Rod Journal Size?
  226. PAC 1521 springs good?
  227. Some pics of my water to air when car is running
  228. Shooter's Magnacharged 419 Camaro
  229. CTS-V vs TT-ZR1
  230. Coming up with a list here...
  231. Turbo Time For My LME LQ9 408... Turbo Guys Come Inside Please...
  232. STS system concern
  233. heads and Intake Questions
  234. Another Ebay turbo kit
  235. turbo size ?
  236. Vortech Kit Questions
  237. can i upgrade my p1sc to d1sc
  238. Possible Boosted Optispark Failure???
  239. Reichard Racing Pulleys?
  240. Getting hot with ac on
  241. 11:1 LT1+turbo?
  242. 5psi with 11.4 compression
  243. noob quiestion
  244. e85 users please share your knowledge about tuning LS1 ( timing)
  245. Gears for boost
  246. p1sc, how to get more boost
  247. Hooking Up 3 Bar MAP Sensor
  248. Still breaking up and backfiring
  249. How well do 383s do under boost?
  250. STS turbo piping?
