View Full Version : Forced Induction
  1. Whipple Build
  2. 160 t stat standard procedure for blower?
  3. Looking for a good cam.....
  4. Were To Put Fuel Cooler
  5. How to DIY build a truck manifold turbo kit!
  6. Cylinder Heads ?'s
  7. Cheap supercharger kit
  8. 427 LSX six bolt, head gasket issues?
  9. Twin Garrett t3 .42/.48
  10. Holset H1E?
  11. How to build and install a FMIC for a D1
  12. Large Frame front mount without cutting the radiator support??
  13. Cooling issue. Radiator experts come in.
  14. Need advice on Merge pipe dia. and WG sizing
  15. sdce 7.6 crank pulley 3.4 blower belt size
  16. Turbo location
  17. Not making boost? Check this out...
  18. I love turbo power!
  19. boost psi vs map kpa reading
  20. 427 LSX, twin 76's, FD RX7
  21. crank pin, slp underdrive
  22. boosted
  23. Boost question
  24. New Bumper Mounted Air to Water
  25. Meth vs nitrous on a roots
  26. few questions on my current setup
  27. what would you pay??
  28. sbc 383 with gt4788 help with exh housing
  29. Crank pinning question...
  30. 00 Camaro ss, just bought new to the site
  31. Exhaust sizing for TT setup? And high flow quiet mufflers?
  32. STS set-up - Junk coupler on TB keeps blowing off
  33. LS7 lifters?
  34. Max boost on a 9.5cr stock crank?
  35. Need ASAP! Fluidampr 740102
  36. Electronic Boost Control systems... what are you using?
  37. What hood will work ls1 camaro rmcr kit
  38. is procharger fan wiring correct?
  39. Some don't use a BOV????
  40. blowing oil
  41. Boosted high compression, et's on 9 lbs?
  42. sdce vs aster
  43. FMIC thoughts on LT1 camaro
  44. How much boost before intercooler is needed
  45. My 1000RWHP dyno sesion
  46. cog belt alignment
  47. What is the loudest centri blower for a vette
  48. what fuel pump should i use with a vortech super charger
  49. Boost Control Issue
  50. Trex cam + boost results
  51. sdce vs standard 8 rib
  52. Anyone know where I can get just a center section (chra) for a GT2871R turbo?
  53. any advice for supercharging?
  54. Cylinder head/cam recommendations on this setup...
  55. New personal best 174.9.
  56. Electric water pump?
  57. TWIn .57mm 18*@14lbs
  58. Question: Procharger Kit for C5, PICS inside!
  59. Blonwn head gaskets!
  60. T trim installation pics and tricks
  61. Blow thru setups
  62. msd 2 step, efi afr with tb
  63. fastest turbo car on a detroit locker
  64. Oil coming out of bov
  65. opinions on turbo choice!
  66. How turbo charging works!!! this should be good.
  67. Im about at my wits end
  68. measurements of a tc76 turbo
  69. Custom cam for 408 76mm Turbo build
  70. Pinning Crank using ATI Dampener
  71. Procharger newbie: (HKE 408 iron block) please help me w/my setup! Lots of ?s inside!
  72. Turbo build?
  73. good brand to buys forged internals ?
  74. This Forum Rocks!
  75. D1SC Head Question
  76. Supercharger from a 2002 Vette
  77. Turbo cam!
  78. WTB 3.4" 8-rib Procharger pulley
  79. L92 Vic jr and elbow
  80. Header wrap... any real benefit ???
  81. ProCharger P-1SC-1, no boost?
  82. ATI vs VORTECH
  83. Whats wrong with this combo
  84. My new twins
  85. KYTP A/C kit&tc78,670whp,16psi,auto,9inch car!!
  86. LQ-4 Motor Limitations
  87. Thinking about going turbo
  88. Need a recommendation for a good intercooler
  89. FMIC Camaro grill pics wanted
  90. Guys running WILSON intake manifolds come in
  91. e85 question
  92. What to do
  93. Large primary headers kill bottom end power on supercharged motors?
  94. vaccum questions? booster...
  95. Truck manifolds and sway bar...
  96. AES Racing Engines FI Shortblock sale
  97. Chris Alston Chassisworks Blower Gear Drive
  98. FAST 102 + high boost?
  99. Way TOO much blowby from PCV
  100. calculate the speed Pulley ?????
  101. Seeking advice re: STS turbo and LS1 engine
  102. Turbo piping measurements
  103. chevelle / nova guys. turbo hotside available
  104. Procharger D-1SC
  105. Procharged Trans Am.....Progressive Meth kit??
  106. Finally some pics of my water to air for my procharged f body
  107. my twin turbo parts list what do u think?
  108. Incon TT Master Thread (All Issues Addressed)
  109. truck manifold oil dipstick?
  110. Which Throttle Cable For Vic. Jr?
  111. Thinking about buying, need opinions
  112. anyone running a blow thru setup
  113. Where to hook up a oil pressure gauge on a Warhawk block
  114. How to properly setup BOV for SC?
  115. Roots or YSI
  116. Head gasket selection
  117. filter location TTix C5 kit??
  118. is this a good turbo for a stock ls1
  119. Bypass Valve Operation Question
  120. LS2 intake with D1sc - Any thoughts?
  121. 5.3 with precision 70 in 3rd gen formula
  122. More progress pics of my 10.5 outlaw Trans Am
  123. twin turbo kit for a 76 vett?
  124. Collapsing Inlet Ducts - APS
  125. TWIN GT35'ed 408 what boost controller & CORRECT way to Hook up
  126. truck manifold turbo kit
  127. Scavenge Pump Set Ups - APS
  128. Stock LS1 D1SC dyno/et? Looking for information!(+EPP/brutespeed cam)
  129. Magnacharger TVS2300 Hot Rod Kit - Where?
  130. water to air for procharged f body
  131. Gmpp lsx 376
  132. Boosted head choice ??
  133. New best mph @ Pinks All out
  134. Proparts Spek boost controler
  135. turbo spark pulug and gap
  136. Piping for rear mount
  137. PLEASE HELP>>>balancer separated, any suggestions on fixing
  138. need some help..
  139. Twinturbo help needed
  140. Have extra Large Yellow TIAL W/G spring
  141. sts dragstrip times
  142. Overheating issue
  143. radiator used for turbo setups
  144. question about procharger f1c
  145. round 2 new build, pics page 2(s85,th400,370ci,9")
  146. IROC Boost
  147. Why no Kenne Bells?
  148. Truck manifold turbo people...please step inside
  149. Considering pair of GT-K 650 for 408 pump gas build
  150. Boost and stroker Q
  151. Muffler before the turbo????
  152. Blown with ICE?
  153. Screw Roots!
  154. Twin gt37's or single ?
  155. E-boost 1 fitment in TA vent
  156. Procharged ls3 dyno numbers?
  157. BOV Question
  158. What turbo is best for me? rear mount, 408.
  159. KY-Turbo Inc. TC78 A/C Turbo Setup.
  160. Starting 5.3 turbo E85 build?
  161. High RPM turbo cam?
  162. Cooling with front mount single turbo???
  163. Edelbrock 245cc heads from WCCH...
  164. Is this the correct way to set up a manual boost controler APS!
  165. STS truck kit. Convert to f-body?
  166. twin 255s intake
  167. 00 turbo ta...2bar 3bar??? Wtf
  168. The Texas grudge superman get's his head cut off!!!
  169. Vortech v9 gtrim
  170. 317s on a 4.8 LR4
  171. Who Sell's Power Steering Relocation Bracket
  172. stock 6.0 truck crank power levels
  173. Turbo oil return line - different
  174. can a forged 346 or a forged 370 handle more boost?
  175. 88mm to big???
  176. Installing 3 Bar map sensor on LS6 intake.
  177. Help with clutch selection...
  178. What step plugs?
  179. ProCharger Survey
  180. procharger guys what filter are you using????
  181. fuel pressure gauge question
  182. What grade bolt for turbo manifold?
  183. My build I driving me nuts!
  184. High A/F ratio on fresh engine
  185. Who makes custum MSD wires
  186. Where to buy this bendable after blower coupler?
  187. What coupler to use for AT1 truck inlet hat???
  188. Which truck coils are best for FI?
  189. My new turbo ride...eh, project
  190. ls1 vs ls1 gt67turbo
  191. Best stock head for forged 370" FI motor
  192. Will gto magnacharger kit work on f-car ls1
  193. N/A to Forced Induction
  194. Flywheel holder necessary?
  195. Blew the oil dipstick tube out
  196. Supercharger EXPERTS, technical question
  197. FMIC installation
  198. vortech SC pulley for LT1?
  199. walbro gss341 fuel pump
  200. Front mount MP70 turbo, a few questions
  201. 98 vette on the dyno
  202. Turbo kit?
  203. Finally! I have cut my lag time down!!!!
  204. Muffler Before Turbo----Rearmount??
  205. Twin Turbo Charge/Hot side pipe SIZE question
  206. Tial WG and Turbo XS boost controller help
  207. 2 step on stock bottom end
  208. need help with belt size on procharger
  209. Need help with SCDE tensioner install
  210. thinking of the right blower for my 2010 ss
  211. Remote mounted turbo vs. Conventional mounted turbo.
  212. Please Help! Still Working the Bugs Out of New Turbo Setup
  213. optimal oil return size for rearmount turbo
  214. Oil on the intake side of my Vortech V9 G-trim
  215. Got Boost Sag?? Don't need that fancy EBC!
  216. Wastegate Question!
  217. Will this turbo help me reach my goals?
  218. Stock bottom and single plane intake.
  219. Finally Good Pics of my Pro Charged LSX Nova..56k stay away
  220. Custom Twin Turbo setups F-body post pics
  221. First updade in along time on my outlaw 10.5 T/A
  222. Newb with a question :)
  223. P1SC on silverado 2007 classic body
  224. Upgrading the STS
  225. Vengeance Racing | Magnacharged GTO
  226. Is it necessary to o-ring the heads at 1k plus rwhp?
  227. need a better understanding on wastegates and bovs
  228. Smallest turbo of physical size for a built 408 TT
  229. Stock ls3 mains vs Callies billet vs Katech
  230. Cam question??
  231. time to down size
  232. looking to build a boost car. New guy here. Sorry. Lots of questions.
  233. Very odd issue on turbo ls6
  234. how much can the stock bottum end handle?
  235. Thinking Of Boosting The Slowmaro....
  236. Sts turbo installation manual needed...
  237. What can I do to make my procharger quite
  238. YSi on ls?
  239. turbo engine build
  240. ? about a turbo...no idea...
  241. fast 102
  242. Target AFR's w/ E85 & boost?
  243. stock 06 gto A4 with F1 procharger 13-15psi
  244. Nelson Racing Engines
  245. PTK/Ebay Kit spark plug wires - Anyone try LS2 Corvette Plugs?
  246. KYTP GT-88 Truck Manifold 408ci Build w/Pics
  247. 2 step retard question
  248. Help - P1SC 98 Camaro..
  249. Trans Am FMIC
  250. LS2 APS W/LG Turbo (part 2)
