View Full Version : Forced Induction
- Exhaust system sizing
- Seriously,leaking after my cam swap
- spitting..
- 1k+whp G-Body single intake fuel pump?
- is this a good deal?
- ARP bolts
- Crank Bolt Length for SDCE Tensioner System
- ***Twins for my 403ci ls2... looking for 1300rwhp.
- Turbo experts step inside... 69mm or 80mm?
- 'Judas' Audi Rs6 - 383 twin turbo, EGT reading confirmation.
- 98 Ls1 turbo checklist.
- tc78 vs t7875 which turbo?
- twin turbo intercooler piping ideas!!
- plug gapping??
- Procharger surge valve and STS turbo?
- static compression affect on turbo spool
- Should i wrap my headers?
- iat placement,charge pipe,or intake(aluminum)
- Few upgrades for my 6speed FRC
- 93 octane meth injected guys step in
- what else is needed....
- Precision 46mm wastegates?
- Rear mount turbo
- new tranny and rear end break in??
- Aster Bracket W/ SDCE Crank Pulley... Will It Work Without LS2 Water Pump??
- To re-ring or not, that, is the 100k question
- F1A or YSI on JY5.3
- Mounting small twins on the side of the engine. Pictures?
- S480 vs PT88 for LQ 408, which to choose
- ***Worlds Highest HP C7 Corvette 1270rwhp***
- 4.8 s475 how hard should i push it but keep it alive
- charge pipe exhaust wrap...
- twin turbo 408
- Charge pipe and down pipe sizing ?
- 2710 cfm enough to keep the car cool?
- quiten BOV
- 66 Chevelle going turbo & need suggestions
- Converter help
- dyno may 7th, whats it going to put down?
- timing map
- Quality turbo parts at competitive prices??
- Oil feed with CBR block
- I could burn this POS to the ground....
- stock lines on e85
- timing safe enuff?
- DIY turbo header elbow thickness ??
- 408 F1R build.......
- Oil from knock sensors?
- stock tank,sump,efi
- wastegate turbo build questions
- MAP/IAT sensor
- Twin Turbo|370|TFS 220|4L80E|MWC 9"|Holley Dominator
- Looking...
- Holley efi traction control
- Tore down 5.3 for turbo, LOOK OK??
- are these the good ones to get
- turbo muffler help
- russel pro flex hoses or not
- Fast responding ait mod
- Roots Blown Alcohol LSx Build
- Help not sure what to do vortech ysi
- 02 SS D1SC build with a few added features.... makes 808whp.....
- Whipple 2.9/ 5.3 E85 or Methanol?
- Huron Speed MYSTERY Sale - Turbo Kits & more - 2/26-3/4
- For those looking for a vacuum manifold for boost reference...
- Magnacharger fuel rail schrader fitting
- 5.3 pt7675 running a tu2 cam????
- Y pipe makers....HOW MANY OF YOU GUYS "FLEX"
- Whipple 4.5 is here
- Smartfire Map Sensor????
- lq4 over lq9 with p-1sc ?
- Procharger People Where do you Mount your Wideband?
- Denmah kit - GT45 Help
- Look to Huron Speed for your turbocharging needs!
- Anyone use corrugated fuel line in the sending unit? Need advice asap!
- Custom Billet Turbo Who Will Step Up?
- 5" flexible exhaust pipe
- heads for a forged 5.3
- Adjustable fuel pressure regulator with install pix
- Twin turbo, oil in the intake???
- Boost Creep Question
- turbo ls1 70c10 first start
- 4th gear in the half mile on a turbo 5.3?
- P1SC what pulley for 6-8#?
- Billet fuel rail xover what size -6 or -8?? Turbo car
- Cheapest single T4 Turbo for 383ci HELP !!!!
- Starting new build "67 chevellel", Debating between another F1A build or a Roots
- 1500hp what system to use? XFI, Holley Dominator, MS3 Pro?
- log manifold ideas
- Wrong place to ask this but I need answers
- A few questions for you Procharger guys
- Fuel pressure regulator goes on supply or return?
- Losing coolant no signs of pushing???
- TWIN TURBO S366 WS6(Mrstepheneades new build, redoing everything)
- 243/799 vs. 317 heads on Turbo LQ4??
- Built 6 speed turbo guys, quick question
- choke point on the ttiX - what CI should I run
- 6L80 for a boosted 6.0L
- timing advise on twin 70mm blowthru carb a2w meth injected pumpgas 5.3 :)
- Pusher fan help for Huron turbo build
- Alternate Intercooler Locations for TA
- Boost ref regulator question
- Going from Whine to Whistle/Whoosh
- Limitations on Stock Main Cap bolts??
- NEED HELP NOW- have return style fuel system
- Turbonetics, Garret, or S400
- need help with BOV
- stock 4.8 turbo build
- Racetronix
- 222/230 110 +4 cam ok for boost
- nova running , tuning , makes power.
- Procharger build
- How will this cam work with SC
- isky triple 12 cam?????
- tial wastgate help
- "switching off" horsepower on a p1sc LQ4
- procharger pulley belts??
- who builds a decent head for boost for a 5.3
- Snow Performance Meth kit from different application
- Vengeance Racing - E-Force C6 Grand Sport
- Need Help Broke Maf
- BW S475 Burning and Leaking Oil from Downpipe.....
- Cheap supercharger kit: Part III
- Need ID2000 injector data for Holley ECU
- Need AN braided lines to finish my install
- Engine Management Suggestions- LS3 with Maggie
- Whats needed after the Denmah Kit?
- Need help with truck manifolds
- STS scavenge pump flow rate?
- Exhaust Housing Question
- Turbo silverado idea
- Head Gasket Recommendations
- Bought a junkyard drivetrain, now what?
- TMS370 - 76/75 turbo - 4L80.. Need some advice please..
- ProCharger P-1SC with 230,000 miles on it!
- arp custom aged 625 gead studs... verdict?
- Turbo Question
- Words Fastest Hearse is AES Powered
- engine upgrades to run turbo?
- 403 with 75/75 .96 billet wheel
- 99 Transam with D1sc Cam Questian
- help! manifold gasket
- Front Bumper Support question on my '00 WS6
- 5.3 single turbo
- Best Budget 1000hp Turbo
- spark plugs?
- Twin IC and big red bypass
- Rear exit exhaust with no mufflers?
- BOV placement on intercooler?
- Anyone tried ON3 oil scavenge pump?
- Build setup info.
- Turbo Camaro (third gen) 408cid
- 99 trans am supercharger help
- maf with turbo
- 4.8 vs 6.0 hp difference
- 6-speed 5.3 turbo build....turbo insight needed
- what heads to use on my 5.3
- Manifolds glowing after cruising down the highway and idlin three blocks to the house
- mercury capri 1999 4.8/80mm/microsquirt/th400/640whp
- 01 Z28 Huron Speed Build
- ProCharger Head Unit Temperature
- Cog set with ati sprag
- safe timing
- vacuum source for Bov?
- What boost controller would y'all use with Holley ECU?
- New crazy shop X275 build. Very different. lol
- Wanting 9's with a LQ4 Camaro
- Turbo headers?
- 93 s10-5.3-twin s366s-th400 build thread
- prepping a 5.3 for boost
- Boost Leash and wastegate question
- The purest definition of "pushing water": with a vid
- hotside builders help
- 1 7/8 or 2 inch headers
- What BOV to use?
- S476, what size turbine for my 5.3?
- What are u guys using for turbo flange bolts?
- 84 mustang turbo 5.3
- Which one would you buy?
- Big red stuck open?
- TVS Experts - I need some quick help please
- 6LE g8 boost build
- Pump 91 - how much boost
- How far does a Procharger stick out?
- lunati rotating assembly ?
- MS3x msd6012 4.8 s475 100% methanol build
- higher power turbo 4l80e setups, whats your converter slip?
- how can i get my turbo to spool faster?
- Lsx + gt500 Head Scratcher
- Eboost 2 boost by gear help
- 4th gen measurement need on build
- Changed boost plans!
- Noob to turbo build
- Single Turbo kits $799.00 Use coupon code for discounts!
- CBM race proven LS engines. 2014 Season.
- PT7675 Wheel Upgrade
- What's the best fuel pump and injectors to run on E85
- 4.8 vs 5.3
- AES vs. ERL for a Supercharged C5
- LQ4 turbo owners chime in please!!
- BOOST LEASH USERS---advise needed---
- twin t7875s
- ditching the p1sc an going to the f1a advice on brackets /making the change an how ?
- Opinions please on new fuel system in the works for 600+ HP turbo 5.3
- Noob needs advice
- Lq4 turbo build questions
- Cam suggestions
- Single 44mm Wastegate wasn't enough...
- 80e guys, OD or D
- If you lean out a cylinder, you're going to have a bad time...*Carnage pics inside
- Anyone running On3 w/ AC?
- Magnacharger on ls3
- LQ9 Turbo questions
- SFI Damper
- Anyone seen this happen to ATI damper?
- Is this normal in a catch can ?
- Who's running a stock LY6 with boost
- Popped a Cylinder Freeze Plug on a dyno pull.....
- From a 3.7 to a 3.4 Pulley how much more boost
- what gears to run with blower
- After engine swap no fire on #2
- 1996 Impala SS 5.3/4l80e s475 build
- RX boost catch can
- Boost control solenoid mounting ideas
- Please Help Venting Crank Case
- microsquirt install
- NW 102mm Throttle Body
- Double Pass Heat Exchanger
- PRC 285 ls7x heads?
- Stainless schedule 10 elbows and tee pieces ?
- ptc converters
- turbo hot side .. why to get the bent pipe,clamps
- 6.0
- Boost Gauge issue
- Synapse Synchronic WG Question
- Log Manifold Builders Step Inside
- 2 wastegates and spring pressure
- Could a T6 Single Spool Early on an LS3?
- 69 Camaro rotisserie 6.0 S475 build
- 69 Nova. 5.3 L33 Turbo build. Billet S474, LOTS of pictures...
- Turbo or Cam and Heads
- Surging boost....?
- GTO Magnacharger TVS1900 Jackshaft Dissessembly
- holley efi vs fast xfi
- 4.8 turbo recipe
- Pistons For a 347 Turbo Build?
- Has any of y'all used this EGT kit on y'all's turbo setup?
- 4.8L thermostat question
- 4.8/243's/s475: How Fast?
