View Full Version : Forced Induction
- Which turbo for my goals and setup?
- Overheating Issues with Front Mount Kit
- Lasershop's C5 Corvette driveshaft mod
- lq9, milled 317 , ls6 cam, boost, HELP info
- Fuel line and fittings
- what size waste gate and how many for 408
- EGT tuning with E85
- high compression and boost
- Will fast fuel rails work on a ls6 intake?
- What clutch to hold 1000+HP?
- p1 vs D1 vs turbo
- 4.8L with gt45 which injectors
- Wiseco pistons in turbo 5.3 what piston to wall clearance?
- 4.5 liter Whipple build
- GT45 bolt size??
- T6 Borg questions
- Horrible serpentine squeal after alt. relocation.
- microsquirt launch wiring.
- Project Murphys Law *C6*332ci*Twin s256's*
- Log/tubular style turbo manifolds
- 408?
- intercooler inlet/outlet
- Switching to SD tune question
- Fbody Procharged guys filter question
- V-1 supercharger
- What compression ratio for 1000rwhp 408
- Compression.
- My 54 chevy TT 5.3 build
- On3 turbo, 5.3 track results
- PCV system with twins?
- Air Filter Question
- Anyone need a RevExtreme RX Boosted Catch Can?
- Water/meth info
- s475 /s476 how fast
- better budget build???
- Cam to big????
- Looking for some opinions from the experienced FI guys
- cam retainer seal?
- Fuel question for FI
- Cause for flat HP curve? Chart inside.
- LNC-2000/CTAP-001 Nitrous Setup
- on3 76mm?
- Spool valve for a diesel work work for gas?
- Wastegate Spring Question
- Need some info on how W/G & MBC work
- S480 T4 downpipe v-band flange?
- Vortech Kit, what is missing?
- WTB novi or vortech
- Holley traction control
- Dominator fuel pressure question
- **LMR Brings home the $$ to Texas**
- Methanol tank - How to attach a fitting??
- P1SC questions
- centrifugal boost question
- which radiator for 408 s480 turbo build
- Ats intercooled twin turbo kit
- ls3 twin turbo intake temps ?
- FI guys what do you do with your HIGH COMPRESSION HEADS???????????
- Which Turbo to Lower Back Pressure and still spool early
- Hooker cast iron manifolds/flipped
- ati damper assembly?
- Electronic boost controller
- Stock LS2 W/ Cam and A&A kit almost hit 9's
- Are my WG's and BOV the right size?
- Who has broken a stock crankshaft?
- idle issues when in gear, need help
- oil pan fittings
- procharged 408ci lq9
- Twin turbo 5.3L in a Lexus Is300...sounds fun right?
- aster bracket tq specs
- fab my own supercharger from a turbine, good idea or bad?
- Precision GT4788 408 w/ A/C
- Runs rich for no reason. turbo 6.0
- truck manifolds ???
- water tank and location of pump for air to water
- What's the best tranny to go with for boost?
- LS1 5.3 Procharger LS tuning kit //// fitment problems
- Wiring up Eboost2 boost controller
- belt
- Proper way to hook vac lines to 2 wastegates?
- Threaded IAT sensor
- Now for something different and then a question...
- air/water intercooler
- boost
- Ice Tank Placement
- Intake fuel system Fbody turbo build
- Boosted LS 408 or 364 in my chevelle?
- I need help plumbing 2 stage MBC
- 2000 6.0 iron w/iron heads on3 turbo
- How far have you pushed Siemen Deka 80lbs
- turbo exhaust to the rear bumper
- How to plumb catch can
- AEM Wideband/Boost Kit?
- stock cranks and a supercharger !
- Fender/bumper exit exhaust. Plumb gate back into DP or just vent to atmosphere
- log building question
- AMS-500 With TT and 2 Gates
- wait time.
- Heads and cam how much will it reduce boost
- Can HP tuners /EFI live change pulse ring count in the ECU
- poor mans 6 bolt block
- Give me some pointers
- on3 turbos
- 317 vs 862
- What V-Band assembly? 3."5? 4"? Borg Warner Turbo
- 408 vs 427 for boost?
- New turbo guy with questions
- blowing ignition fuse during hot start
- exhaust on turbo?
- Fender exit exhaust guys
- build help, and opinions?
- Stock 4.8 802RWHP but valve float now
- 71 nova build thread finally started
- Anyone use the ls1 style 3 bar map sensor from efisource.com?
- Turbo Technologies Inc.
- Huron Speed V1 Truck Manifold Turbo Kit BLOWOUT!
- HURON SPEED Silverado/Sierra Hot side Turbo kit has arrived!
- Hitlers take on Flash and FR8
- 6.0 Build
- 1000 Horsepower Streetcar. AES Style.
- S480 turbo ????
- pic
- 85 Chevette Sedan turbo build. (lr4, gt45, ls1 cam, stock rear)
- Need input on $ for $... Blower on stock or do heads n cam
- S400sx-80 V3 billet wheel 5.3 build
- LSx Truck Manifolds vs Turbo Headers
- Lingenfelter intercooled intake for a turbo application?
- best procharger for LS3
- red race valve?
- What lifters you guys using?
- Aster Bracket belt problem.....
- Highest HP C7 Corvette-LMR 1121RWHP-Video
- What to expect out of a setup
- Best off the shelf cam for twins
- Fic 127 injector settings
- S480 upgrades
- what pushrods?
- Blower cam question
- JS boost controller
- few? e85 and injection 96lb..
- LS3 twin turbo?
- Anyone had any issues with wilson TB sticking?
- School me on Engine Delta Pressure
- ***408 STROKER/81MM turbo BLOWING HEADGASKETS!!!***
- I blow up my ls2 engine and I have 5.3 short block
- Borg Warner s400 question.
- 1444 rwhp cts-v
- Fan wiring help ?
- CTSV Twin Turbo build # 2!
- AEM UEGO Sensor Installation?
- best boost block
- Size of Exhaust after turbo??
- Where is your trans temp sender installed?
- Turbo 408 overheating/running warm; critique the setup
- 5.3 turbo build
- 408ci Build opinions?
- ls1 turbo which spark plugs
- Anyone with the procharger fan/shroud help!!
- Turbo guys- exhaust leak help
- I'm back in the boost game
- t6 turbo?
- The other "GT45" Ebay turbo (80mm)
- Kentucky turbo hotside question, wastegate size
- LS6 or 6.0L
- Exhaust housing advice needed
- Replace or add another wastegate?
- LS3 stroker or not for supercharger suggestions
- 67 firebird lq4 holset ht3b
- Advice needed for Magnuson Swap from LS2 to LS1
- RMCR lower blower bracket please come in !
- Project **Hat-Trick**
- Huron Speed Turbo Trans Am
- Few questions on crossover, clearance and intercooler
- F1-A Iron 370 Cooling Question
- need opinions on best intake for turbo application
- regulator
- EBay turbo blankets
- 370 built.. Advice please..
- Borg Warner S471 / 5.3 in a 91 Z28
- 2000 ws6 turbo build. single s366 turbo. trucks manifolds, stock alt location
- lq4 6.0 turbo mustang build
- Ebay Turbo kit build thread 02 TA
- Gt45 for my build or not???? Need to know asap
- C5 Procharger bracket options
- Is this to close?
- old roots blower on ls
- summit racing 408 block
- Anyone put the BOV on the IC
- Building of The Mistress
- Custom cooling system fittings
- welding a divided t6 flange
- Supercharger and exhaust
- LS9? LSA? Other?
- 3.42 or 3.23 for turbo?
- 5.3 blow through carb selection help
- 2 1/4 inch vbands on truck manis
- Need advice on what gears to run on my turbo camaro
- Need help ASAP
- spool time on 4.8 auto
- Buying c5 procharger kit for fbody?
- turbo lq4 nova gears. 3.73 or 3.08.
- swapping for a 5.3l turbo build
- Race Proven Motorsports goes 9.11@156
- Turbo motor advice
- Roots supercharger lq4
- is it worth it to port heads for blowers
- Coil Issues (passenger side not firing)
- WG and BOV sizing charts
- need help on turbo cam specs
- turbo ls1 running at 215 for 15-30 mins at idle.
- Boosted LS3 whats the best stock style cylinder head choice?
- Another 5.3 jy build question, what turbo/cam/stall/gear for 9's?
- 5.3 Rebuild parts
- What oil pan for turbo motor?
- TSP 408ci F1-A Procharger
- Power Limit of Stock TTY Head Bolts?
- LT1 Radiator
- Wiseco's Junkyard dog 5.3 "drop in" forged boost pistons
- Another recommend me a turbo thread!
- turbo,cam convertor choice for 5.3l build. other help as well
- budget 6.0 s475 build up
- cam help please!?
- need advice on Turbo Build ls6 or Iron
- Check out this CAM!!!!!
- intakes?
- turbo L33 questions
- Tranny cooler suggestions ?
- Turbo rebuild/balancing
- 8.65 8rib pulley crank F-Body ProCharger
- Turbo LS1 Build thread/help.
- Developing ac/PS forward facing turbo headers
- anyone with straightlines t4 kit?
- My blinged out Meth system
- Need some help on ls1 build ls6 heads
- harmonic balancer for truck 6.0?
- dual injection with e85
- 71 nova 347 billet 76 build update!!!
- stock 6.0 block, LS3 heads, 408ci, F1x, 23psi=1140 rwhp on pump E85
- Twin Turbo 408 camshaft
- 88 Mustang 5.3/S475/4L80E Swap First Track Outing
- Exhaust setup for the Huron Speed A/C t4 turbo kit
- Help with microsquirt
- Is this possible?
- cam change with head change
- Does anyone make an 8 heat range RESISTOR plug with a Non-Projected Tip?
- Knock with TVS
- Dual 320 LPH pumps. Constant on or Hobbs switch?
- Metal in the oil pickup...HELP
- LSX block, 377c.i., LS3, YSI, 17psi=870/730 on pump gas
