View Full Version : Forced Induction
- Did a auto swap do I need a retune
- Can I make 500-550RWHP with this setup?
- Tb???
- How much fan is needed for boosted+ac car?
- 05 S2000 (turbo LS1 swap)
- Non-ac turbo guys. Ways to keep cool? Little car fans any good?
- Twin turbo upgrades
- PRC 247cc heads for boost?
- Magnacharger parts needed
- CBM 2014 Performance Products Catalog
- External pump for "street car". Need help
- Question ab big injectors but stock fuel rail
- stock Iron headed LQ4 limitations
- LQ4 pistons for boost?
- spintech oval exhaust sound?
- 86 Mazda RX7 FC - 5.3 - TC78 build
- Looking to stand up my radiator
- Want to buy precision 8891
- New pulley availble for ProCharger users
- ~NEW Huron Speed V2 Single T4 Turbo Kit *GROUP PURCHASE*
- Thinking about upgrading my turbo....
- Speed Inc LSX alternator relocation kits!!
- Gauges for turbo build
- 370/91mm/4l80 bird
- LS7 Exh manifolds anybody using ?
- F1R intercooler piping size
- Should I loose the FAST?
- ***Big changes for 2014***
- Pure Evil - VR CTS-V Coupe, Heads/Cam, Nitrous, pulleys, Weld RTS & ADV1s...
- Who has the best price on s475
- First day above freezing, so what else to do but test the new TiAL blowoff.
- gt45 with 76mm compressor
- Part Number for NGK BR8EF spark plugs
- 1100hp with an f1r
- Need opinions on cam
- LQ4 Turbo S300 Or TC78?
- Corret part numbers
- ***LMR Twin Turbo C7 Corvette makes 836rwhp and 737rwtq***
- 1972 Chevy C10 5.3 turbo
- spark plugs
- how much boost on stock lq9
- 370 or 408?
- Twin Turbo oil feed lines??
- water/meth injection
- Methanol Injection questions....
- Slo-poc, Futral Motorsports Build
- Junk Yard LS...Cracking the Code!
- Am i the only one with this engine combo?
- Porting a holley hi ram for boost ?
- Buying a USED Procharger?? LQ4
- 02 TA Procharged
- Huron Speed stepped up to the plate to fix an issue that was not their fault!
- Thinking of going turbo
- Sick 650-rwhp CTS-V Wagon content inside!
- LS2 or LS6 intake for boost?
- Stock LS2 and a TC78, is the turbine too small?
- budget turbo setups
- Who is running a bumper exit with a bullet muffler?
- Need some help picking my wastegate size
- super oil system for rear mount turbo setups
- how fast or how much power out of a bw475
- Purchasing an on3 turbo setup...couple questions
- Best single turbo for high hp LS1?
- Turbonetics .96 vs PT .81 vs PT vband pic comparison
- pt94 is it too big for the street?
- What AR to use on twin turbo 5.3?
- Turbo Motor with No Turbo
- Budget Turbo LQ4 Cam selection
- Ysi
- Whats a good inexpensive twin turbo kit?
- Need some guidance
- My 80/20 meth/water experiment
- John Deer Hy gard Trans Fluid?
- Novi 1200 s/c on ls3
- Truck manifolds with egr, ok for turbo build?
- Planning P1SC
- Benefits of E85 + meth?
- Tial Q 50mm BOV spring rate test
- Frontmount LT1 Question
- help with piston/rod selection
- Truck manifold guys, how close are the flanges to the frame rail??
- Twin Turbo TA Upgrades
- Who to buy a turbo cam from....
- Twin 4.5" Intercooler question
- Which cylinders do I pair for Twin Scroll ??
- lsx intake
- Twin screw or centrifugal?
- Procharged and boost???
- head and fuel input requested for new build - supercharged 2003 Z06
- What to do with O2 sensors on stock computer/HPT?
- Best lq9 cylinder head
- hp guestamite on my twin 70mm dragboat deal
- Question about Fast 90 Intake/TB for boost
- O2 Sensor Placement?
- twin 5.3 converter
- Time for some upgrades to the Turbo Firehawk
- Noob...Please help 5.3 twin turbo build
- Incon Turbo owners what Rad cover?
- Cx racing air to water intercooler
- questions about Maggie setup
- LS style exhaust manifolds list / pics...
- UPP turbo kits for corvette's
- Keep vette filter with Aeromotive regulator?
- Procharger cam swap HP numbers?
- 4.5" twin intercoolers to single FMIC.
- post picts of your truck manifold set-ups..
- Turbo sizing for now and future
- intake........
- LS9 heads on LS3 block
- 2000 Mustang GT 347", single 88mm True street style Ride..
- Pictures of catch can mounting
- Carb and Inj question
- boost and pump gas
- Stock lq4 boost ??
- Precision PT8891 CEA
- HELP Turbo identification
- Compression
- Vortech discharge sizing
- looking for procharger bracket
- Billet wheel
- Which heads for my supercharged ls3? tfs255 or ported lsa?
- 1st gen c5 procharger kit
- LMR Twin Turbo C7 walk around
- Turbo questions
- turbonetics7875 turbine to small?
- EGT tuning? on unleaded vs. e85..... Nobody really talks abou it
- Wastegate suddenly not opening, advice needed
- **LMR in another Final in Qatar**
- 408 stroker with twins
- Junkyard turbo option for daily driver 5.3
- Picking your brains...
- Girdle Questions
- Live link to Qatar!
- BW s366 or GT45?
- Intercooler size question with meth
- C5 STS twin turbo system
- Does my cam fit its purpose?
- Is my cam efficient enough?
- 86 trans am + 5.3L + turbo+ th400 + Moser 12bolt no F*ucks given build
- So..What does the collective brain trust think?
- SEMA- NRE Maximus
- Power brake boost and trans modulator etc - under boost
- Tuning Meth with Boost
- truck turbo manifolds ???
- Turbosmart vs precision wastegates
- 1 BADAS Z (5.3 BW480 billet 280z build)
- Welding a 4" V-band flange to a T6 s480 turbine housing...
- GTO procharger advice
- Compression Ratio and boost
- RHS build for TT 1K Midengined Kit Car
- Getting some new skin....
- Has anyone used C02 or compressed air with an AEM Tru-Boost?
- ~650whp, 4l80e, what stall and rear gear?
- 4.6 mustang p1sc?
- Are the gt 45 turbos to big for a v8
- LSX block for turbo/procharger?
- need info about a 5.3L rebuild with porcharger
- gt91 smaller displacement or larger displacement
- advice on turbo build
- microsquirt
- Are 317's really worth it on this build?
- Intercooler Comparo....Custom Garrett vs. VSRacing (E-Bay)
- What upgrade bearing kit for stock rockers?
- Question about a Chinese turbo
- Looking for a large intercooler. 5" or larger core.
- Behind the wheel difference between superchargers and turbos?
- 402 NA power before a blower
- Turbo a/c kit need help
- Metal vac/boost lines
- 8-Rib or 10-Rib for F1R
- 300ZX Turbo L33 Build
- Turbo cam?
- Do I need to install LS9 gaskets for my build?
- Would you swap heat sink coil for new style coils?
- help with new turbo build
- turbo gearing ???
- 2002-2006 Truck 6.0 Flexplate?
- D1 going on a 383
- Thoughts and opinion on a cam for turbo
- Piston question
- 26 psi on stock bottom end?
- turbo build
- Turbo Build help
- 65 Nova II - Basic LQ4+S480 build
- ProCharger 2014 Corvette C7 Stingray tuner kit is released!
- Got my twin 61mm Turbos in!
- C5z, f1r, 9.33@150
- Stall Converters & Turbo's
- My gt45 79 malibu build...
- Turbo and TH400. Converter?
- FI noob has some questions.
- Air to air and meth vs air to water??
- Spark Plug Question
- 1000HP Turbo Car?
- OBX Shorty headers for Turbo setup
- Ebay oil cooler users
- 800 + rwhp stock LS3 short block with F1A
- turbo oil line & return line ????
- Holley HP users, how are your input/outputs configured?
- My 02 z28 80mm magnum playin on the street. Also for sale.
- Anyone ever use Professional Products 96mm intake
- In-cabin boost controller
- Hotside piping ???
- Turbo PCV Help
- Anybody ever tried a coating over hot side wrap?
- Modifying license plate cover for frontmounts...
- GT91 turbo Exhaust V band size???
- What intake manifold to run on l92
- Tick Performance LT1 turbo build 907rwhp/860rwtq 19psi
- Vbands - where to buy?
- PT88 Rebuild kit or parts to rebuild
- e85 or 93octane with meth?
- How does 50/50 water/meth affect Air Fuel Ratio?
- New PT88 with T6 upgrade PTB700-3025 1.08 ar on ls3
- gt4508r
- 5.3 tt build questions
- cam and heads or supercharged with a lot of miles
- Haltech with E85 and meth injection
- stainless vs mild help
- Camshaft suggestions for a 402 F2
- 2.87" pulley on T-trim stock bottom end LS3?
- Setting base fuel pressure w/ boost FPR
- twin turbo 5.3 build suggestions
- Can anyone plz list all the mods you see in this GTO
- Maxed out ATI D1SC owners; what is the max boost you see on a regular basis?
- 347 or 370 for TT DD
- They said it couldn't be done....
- Derale 16925 fan question
- AES is heading to the Middle East
- stock 5.3 bottom end
- Anyone share a main stud girdle CAD drawing?
- what fuel pump ?
- Smartfire injectors map sensors?
- Fab tubing for hotside?
- cold side pipe thickness
- Edelbrock vendors, need part sourcing
- Help me pick a turbo
- Back pressure with 80mm turbo
- Anybody using holley dominator and methanol
- Nova camaro turbo headers
- Has anyone used the BBK or the Weiand intakes with boost?
- How far have you seen the procharger D1 pushed
- 2000 ws6 with huron speed turbo kit build
- Snowball of a build - Turbo LSx Rx7
- IRON 408 APS twin turbo & ttix twin turbo results
- Iron ls1 turbo plans for TX2K14
- Pac 1218's and a TU2
- on3 7681 to 475/87/1.0
- Another new product!
- 89 RS turdgen JY 5.3 WE HAVE BOOST (tuning in progress)
