- mpg gain from turbo install?
- Downpipe w/motor plate pics (anyone)
- turbo help
- steel or aluminum piping kit for twin intercooler procharger
- wastegate
- turbo leaking oil
- cooling fans drawing too much amperage , options?
- Wiseco ring problem!
- Suggestion for fast 90 repair or replace
- Magnacharger kit for LS1 F-body..
- a complete list of stuff needed for turbo builds
- what ring gap?
- Pictures of custom rear mount setups?
- procharger VS. turbo?????
- cam question
- Throttle body size?
- Has anyone ditched the ATI twin intercoolers for air to water?
- Oil Line Restrictor - where to get em'
- PTK pics of wastegate and bov placement
- Stainless bends?
- NemesisC5's Video Clips
- Ordering a gatorback belt for my procharger. Thoughts?
- High miles on 5psi should I?
- Someone help me with supercharger cam?
- Anyone use this setup?
- wastegate flange Q?
- When to upgrade valves for 850+whp turbo build?
- turbowerx scavenge pump
- Ok to add 2 gallons of Sunoco leaded 110 to tank for race day????
- can you run long tubes headers on a rear lt1 turbo?
- FI cam swap??
- Where to get C6 exhaust flanges?
- just finished my 1998 WS6 MPT76 build
- procharger and 400 turbo?
- Took measurments for belt and cant decide which one to use.
- W/G and BOV Requirments
- Running Vacuum Lines Question
- 383 d1
- HKS 60mm wastegate
- VGT on an LS
- Twin turbo street cars.
- ZR1 supercharger on a LS1
- Anyone with a Gear Driven Procharger?
- pt76gts numbers?
- Forced Induction Question
- Spohn K member with front mount turbo...
- Boost Controller
- Speed Unlimited President's Day Sale This Monday !!
- i have a t67 turbo w/parts for sale
- Turbo newb sorta
- Question about EPP FI cam
- LT1 radiator is this right???
- Testing out the TH400 for the first time
- 7.65" Crank Pulley with SDCE?
- Cam needs! Sponsors inside..
- any 5.3's running a stock fbody cam?
- FI Intake Elbow: Edelbrock Brand
- ebay turbo
- Anyone Running Open Down-pipes? Got Video/Sound Clips?
- What do you guys think......10psi /w meth /w nitrous?????
- *PICS* 80MM Turbo Setup on my LS1
- smooth bellow
- tell me about this turbo? pics inside!
- Built LT1 or LQ9 6.0L
- ProCharger Qs
- bmr turbo k member brake lines
- SC4 Cam/Forged 370
- centrifugal and turbo
- Another Powerdyne question
- supercharger for cheap
- LMR's 9 sec ZR1 Video Inside!!
- cam to big for street?
- o2 sensors in cross over or downpipe?
- high HP converter question
- Upgrading intercooler help
- new ricer trend
- Wana turbo, Did some research, got more q's.
- royal purple xpr
- Can you do sts setup with an ms4 cam? sorry newbie
- Kenne bell kits for 2010 camaro
- track pics and vid 2 6 10
- Turbocharged 408ci LQ9 & TH400 Caprice
- last turbo post swear, please just look
- Most recent turbo build - NOT an LS1
- which gauges and why?
- Getting on the Maggie
- Backfire now a vaccum leak-FAST 92
- Turbo carnage
- Turbo vs heads
- UMI roadrace k and twin turbos??
- 22 1/2 degree silicone
- acceptable amount of shaft end play?
- MPT70's on a 5.3?
- cam help
- vortech v-1 trim identification
- WOT Backfire
- Air to Air in Burkhart Bumper support???
- supercharger for new Denali truck?
- BMR k-frame issues....
- New to boost, considering a turbo
- Need help finding LT1 Vortech parts
- Straightline performance 408cui rear mount build
- Anyone used VP M5 Methanol in their injection kits? Already did some searching
- pistons to go with 317 heads and a magnacharger?
- *869rwhp/828rwtq World Warhawk ECS 2200-UNGAGE the RAGE*
- ? about cr
- 1265 rwhp C6 Z06.
- efi elbow?
- Help on turbo engine
- i need a turbo?
- Edelbrock - 2010 Grand Sport Wanted for S/C fitment
- boost issue ,, iit does not hold
- FINALLY...im going turbo...look please
- Methanol Question. For APS setup.
- 402 Turbo Project Advice
- Compression and Turboo!
- Purchased a Pro-Flo XT Intake Today...
- cam and computer
- sooo...about aps
- D1 PROCHARGER VS F1a PROCHARGER....??
- Worth it to stroke LS1?
- Changes to my setup this year / trailer for Zombie rear mount turbo saga part 2
- which turbo pistons and rods
- Air filter to fit master power T76
- Eboost controller with a supercharger
- turbo oiling question
- What size oil feed line to run?
- cooling system?
- 383?
- 370 or 402
- 1970 Chevelle Tube Chassis Turbo Build
- Lingenfelter oil feed/return?
- looking to trade my procharger big red for a turbosmart race port BOV
- which head gaskets?
- Anyone with a P1sc or D1sc for sale
- 383 LT1 SR cam 88mm turbo HD VIDEO part 2 intercooler
- powerglide for a turbo car
- Radiator with Procharger setups ?
- Oil Restrictors? AND pipe size questions??
- Someone tell me this is a bad idea...
- Rear Mount vs. Front Mount
- who has used a GT45 turbo under hood of F-body
- APS,Stock Bottom End, 110 octane??
- biggest turbo for ptk kit
- Maggie and catch can.
- Procharger guys w/ FMIC
- hobbs switch placement
- s-10 with 5.3 & front mount???? anyone?!?!?
- lq9 ?
- What kind of rwh to expect out of LQ9 stroker
- Wastegate question
- what bearings are you running
- Vacum line reducers
- Precision or Garrett
- Running an LS1 STS Kit on an LT1 Camaro
- TTI turbo kit oil return and general questions!
- Is this cam okay for FI?
- Vertical Rad Washer Reservoir
- alternator relocation
- Fastest Stock CI LS1?
- Mahle Pistons for Blower ?
- Someone overlook my build, critique heavy please
- wastegate that fits ptk clone kit
- D1sc to my new pt88 truck maniflod build
- Which to run on a budget?
- Turbo with Nitrous dyno numbers
- Radiator support for FM turbo systems
- Rear mount gto build. :) LQx REBUILD TO COME
- a4 transmission cooler lines relocation ?
- Who has a lt1 with a sts t67 turbo.. What are your hp numbers
- what size wastegate for 78GTS
- cam help with my lt1!
- Procharger F1 for 346?
- FI w/ ram air? TMIC w/ ram air?
- Good turbo cam?
- LY5 5.3L suitable for boost?
- Which is the best meth injection system
- EPP FI cam + 5.3
- It's Alive...and running great!!! DYNO VIDS UP
- 1 5/8 primaries with supercharger
- Boost Controller
- lightweight flywheel w/ procharger???
- GTO and F-body owners: Front Entry Cathedral Port Whipple kits
- looking to S/C, would like some info please
- Anyone using an intercooler like this.
- 12.808 @ 104.39 in the express VAN
- Anyone running Virginia speed turbo manifold
- Starting a turbo build need some advise
- Who has over spun their D1? I've talked to 3 techs at Procharger w/3 different answer
- Old Story - Single or twin for me?
- Ignition for 383 procharger build (LT1)
- Pick out my S/C cam for me! (LT1)
- worth it or quit being a cheap a$$
- Question for everyone
- want pics of stainless works down and forward turbo headers.
- Having problems picking blowoff valve spring as Im right in between numbers?
- Victor Jr. users inside!!!!!
- Turbo: oil feed source?
- Where is Bob from EPP? Ordered a part 3 weeks ago, still nothing...
- Game over!!!!!
- Race Proven Motorsports 667RWHP Cam, ARH, A&A C5Z!!
- Precision VS. Turbonetics (billet vs. TC)
- HPE 440lsx F1R
- APS Turbo Question
- HP gain w/o inlet pipe
- Benefits of Meth Inj. when running big fuel system, race gas, air/water intercooler
- which TB for boost?
- TC78 Dimensions
- budget ball bearing turbo?
- How much do I gap my plugs for my 5.3 turbo
- 304 stainless coating or wrap?
- is this a waste of money????
- Tall deck RHS block...
- anyone runnin 10.50 or faster with a M6?
- STS Concerns
- Another 1,150+rwhp street car by Speed Inc.
- Thinking about side dump...in the front...
- Edelbrock 2008-10 Corvette Test Vehicle Wanted
- Stock untouched heads and 834/694rwhp/tq???
- Turbo Experts: T72 question
- multiple problems- do not know what to do
- Front Mount Turbo w/ A/C
- Aluminum downpipes
- largest fastest spooling turbo, 364 engine, ptk kit
- Uncage the Rage!!! RR-Forged LS7 w/ ECS 2200 876rwhp "Z06Beast"
- where to buy vband for masterpower turbo vband outlet
- 69 Camaro, 410" LSX with Procharger F1C
- turbo 400 or 4l80 for my F1A
- Procharger Pulley install?
- Smooth Idler and J-Bracket?
- looking for tc78 or better
- Procharger torque specs?
- lets see those alternator relocations
- Front mount intercooler location and bracket
- Turbonetics contact & website
- To those with steel piping
- Which Supercharger for a C5?
- Sts
- Anyone running higher boost, E85, and no intercooler?
- Ls1 worth boosting? or 6.0l swap? Turbo size?
- does it matter where the 317's come from?
- ZO6 cam kit...install it or sell it?
- which turbo?
- Oil people are running with an STS
- Who wants to make some serious horsepower?
- Would there be any benefit to portmatching 317s to the exhaust manifolds?
- Camaro SS supercharged radio bezel
- How much PS! is robbed when using a intercooler?
- Got a summit gift card, wanna help me spend it?
- speedinc tu3 turbo cam?
