View Full Version : Forced Induction
- Intake any better for a street turbo motor??
- back into build mode winter is coming.
- ReAr moUnT vs FroNt MOunT???
- bosch 044 and 3/8 lines.
- VR 707-rwhp Centennial Edition ZR1...
- on3 turbo Kit new for ls1 cars
- 5.3 /4l80e GT45 rear mount S10
- 6.69@217 new world records, lsx shout win and videos!
- Heads/Cam/Valvetrain recommendations for D1SC/370/T56
- New DD, 2009 G8 Twin Turbo, Dyno results
- Procharger noob question
- Got my car out to the track this weekend 10.700 @131 1/4
- G Body Malibu first passes
- Couple of new in-Boost videos of my Junkyard GT45 5.3 Mustang GT
- Wastegate Size & Placement for LQ4/S475 Setup??
- Battery relocation tray
- 2500# car - 4l60e - Boost
- Turbonetics T3/T4 Hybrid
- A supercharger for a 2000 Camaro V6
- On 3 performance turbo kits?
- Educate me
- Turbo Trans Am ws6 pictures
- GT55-88 ETR-HO with a little flavor
- What is Tick Performance working on?
- WhiteLTone/Legend Racing 4 day Turbo Build testing at Indy.
- so, NMCA has cancelled MEAN STREET
- Trust MAP or boost gauge when looking for pressure?
- Gt45 turbo how much power can it make?
- Injectors and fuel system for E85
- EEK 22PSI Back Pressure on Rear Mount
- 5.3 goes a little faster 8.55@159
- Need some advice...
- Good heads canx out with FI?
- Gauging interest: H11 head studs for FI applications
- Turbo leak by air filter
- Fabrication experts
- Thanks to Matt at RedLine and Robert and Robert at Chiseled
- 6-bolt Head comparison those with good & bad experience please share
- LS6 vs. LS2 intake on turbo LQ4
- 4.8 + precision 7675 + 75shot = 144mph
- junk yard 5.3 turbo records?
- Wastegate advice needed (pics inside)
- Power Gain
- Got a intecooler related qustion....opinions needed....
- another boost plug gap question
- can you adjust boost on supercharger?
- Semi-budget build Forged LS3
- MSD Slim Starter
- What is "peak power" & "power under the curve"?
- Dave Adkins 63 Impala 4.19@183, 6.36@219
- BW turbo???
- first time at track with new realstreet setup
- Need help on lt1 P600b Install in 96 WS6
- Would you or would you not?
- BOV noise
- comp ct43 6767 vs bw s366 for twin turbo 390ci
- Microsquirt vs MS3-Pro on Boost
- stock bottom end limitation?
- GT4788 Vband help.
- Twin 70's on 5.3 good or bad?
- p600b Purcahse for my 96 ws6 lt1 Should I do it? Need help
- 224/230 115lsa .59x-.59x lift idle issues
- Quench on turbo engines
- Is this a no-no? turbo mount pics inside
- Highway mpg turbo on e85?
- C5z06 5.3/Rearmount turbo.
- cheapest place to buy v bands and cupplers
- Ati double key damper, what does that mean?
- Stock Connecting rod ????
- Boosted 79 Malibu
- turbo forged 370 build. what to get and where
- Holley dominator efi or bs3
- ZL1 Front accessory drive for LSA 1900 on F-body
- IAT sensor- which one to use
- Turbo kit q:
- FIC2000 and E85 issues.
- *** Ninetres 194mph crash pics/video ***
- Catch Can Routing (Yes, I know it's been covered)
- 5.3's making big power step in. WHATS YOUR SETUP??
- My mustang street car I built this year...
- Magnuson TVS 1900 folks....
- 5.3 turbo project
- tc-78 3.5 v band? stock?
- Turbo Auto guys with Lingenfelter 2step LNC-2000 come on in
- Anyone pieced together a water/meth kit?
- 1205 RWHP on pump gas - F1X C6 Z06 by CBI/DSX
- limits on3 7681 turbo
- blow through carb non ic but water meth thinking of going e85
- What to do,... what to do?
- Front mount turbo, PS cooler???
- 6 speed turbo guys
- Twins or big single? Exhaust constraints
- Official C5 Build Thread: Front mount PT7675 LS2 E85 6 SPEED : )
- Ls1 with vortech V9 g trim supercharger
- Curious about size comparision of a S480 & GT4788 Turbo
- Rear Mount 2013 LS3 Powered VT Commodore
- LS6 w/ 65 vs LS2 ported w/ 90
- VR SinisTTer - 195mph half, 1586-rwhp, Twin Turbo STREET C6!
- Running truck coils with your FI setup? Ditch that unsightly bracket and go billet!
- How much rwhp on premium gas, turbo, lq4?
- Tick Performance Customer Appreciation Day Highlights (photos and video)
- Afco radiators
- turn up the boost or no
- megasquirt 3
- Installing key into crankshaft
- 71 Nova single turbo, am I on the right track?
- 62 Chevy II LS3 Maggy install suggestions???
- Gt45 ebay turbo oil restictor?
- Issues with Aster Bracket
- Huron Speed Single Turbo Non-AC Forged 347 High Compression E85+Meth Build
- UPDATE!! New Powerplant and TX2K14 - 98 Mustang GT, 6.0, 80mm Turbo
- pics of lq4 in the car and hot side.
- 5.3 turbo ?'s
- Holley hp efi or fast xfi for turbo 5.3
- Twin 76 garret,s on LS3
- Question about plate to hold radiator on stand up Griffin radiators.
- Procharger BOV mounting HELP
- Precision PT 76GTS turbo Lm7?
- Who's running or thinking of running the GT5018?
- Anybody in here running triple Walboros?
- X pipe on twin 6262 turbos
- Intercoolers
- Supercharger/Blower for Retro Swap
- vacuum for brake booster
- changed WG spring, issues
- how/what would you build?
- What's the max power you've seen from a 402 at 14-15psi?
- Thoughts on Autometer wideband gauge
- 427 LSX 4.140 bore Cam Question - Procharger F1r
- My 5.3 with ebay gt45 turbo is alive
- Twin Turbo With A/C?
- Vortech YSI seals ?
- Altenator Relocation Kit
- My twin Lsx 70 Nova build
- 408 lq9, s480 build advice
- will a ebay turbo kit be good?
- stock zl1 vs stock ss with converter and street slicks .turbo iroc chase car
- cheapest place to buy 5" v-band flange and clamp
- Has someone actually ran the obx turbo manifolds
- Large frame turbo blanket
- 6-71 Blower.
- Help deciding on a ar?
- 98 to 2006 4.8 wiring contemplation
- D1SC Steel SDCE J Bracket Work on F1?
- Lambda for Meth Injection?
- Twin turbo oil return
- Holley EFI meth users
- LS3 Large Chamber Heads?
- Has anyone switched their boost bypass valve to the other side of their TVS?
- LQ4 turbo build, suggestions needed
- manual rack and relocated alternator
- What turbo for a LQ4 Tow Rig??
- Need some info
- Most power made with a LQ4/LQ9 block?
- turbo drag car. do I need coolent cross over tubes?
- does anybody make a 3" 50mm wide Cog Idler/tensioner pulley with sidewalls
- Whipple or magnuson supercharger for 08 silverado
- Need Help PLEASE!!!
- 94 T/A turbo LQ4
- Went 9s today,video inside. Full weight on 17s!
- Another Help me choose my turbos thread !!!!
- Looking to buy a wide band for my turbo 6.0 build, AEM?
- Not building boost
- Size of s475 vs "ebay"gt-45
- Gearing advice for 850Rwhp turbo Fbody! Experts inside.
- Meth Injection.........HELP PLEASE
- Injector size Question
- Check out this stock bottom end pass!
- Turbo Exhaust
- Rear mount intercooling question
- boost reference ?
- Here we go again: Turbo built .2
- What Makes A SBE 5.3 or SBE 6.0 A Better Option Than A SBE 5.7?
- Afr drop of 3points with dual nozzle meth, normal?
- Turbo? How much an what?
- Advice and help
- PT88 402 c5 only makes 13-15 psi
- how many running microsquirt plug and play?
- Where to order Raw Stock to use for DIY Intercooler piping?
- LQ4 turbo build starting to collect my parts Turbo
- BW S366, Comp 6767, PT 6766...
- Anyone have a 6-bolt engine for sale?
- holley hi ram intake
- Going turbo lets hear your thoughts
- An interesting idea for you guys to critique.
- Switch to prime meth injection before WOT
- Charge pipe sensor and nozzle location?
- turbo 5.3 s2000
- Procharger question
- those of you with the AES 390
- Car wont accelerate,studders and stumbles
- Turbosmart raceport bov mild steel flange
- Anyone run 16 injectors on a Hi-Ram?
- LS3 turbo Truck manifolds work?
- IAC not closing idling @ 2500 rpms
- ~NEW Comp Turbo Standard T4 turbos w/ 79mm Turbine Wheel
- Steve Morris Engines doing my car. Questions.....
- 427LSX - AFR Heads What Rockers?
- STOCK 346, TFS 215s, FAST 92, P1SC @ 11psi= 700whp ;)
- Tick built 347, stock 241's, stock LS6 intake, T-trim@14psi=700rwhp
- Which WG & BOV for billet S480/370ci ?
- settings in HPtuners for timing on transbrake
- ebay twin turbo?
- tc76 and 10bolt to S478 and 9", with results
- Need some advice on hooking high HP on the street
- new twin setup for my dragboat
- Blow Thru carb....
- Question about supercharger pulleys
- hptuners or ms1/6010 for newb
- Turbo Headers that clear AEI motor plate
- constant coolant to turbos?
- What more do i need
- Fuel system questions 900-1,000rwhp?
- 2nd gen f body manifold/headers
- How much boost can it take?
- Join Boosted LSX on FB
- Another 240sx 5.3 turbo build.....what do you think?
- Budget boost idea and some questions
- How much boost?
- Boost controller comparable to AMS1000
- Speed Inc, comes through.
- 2004 GTO TC78 Build
- JGS Wastegate issues...
- 6.0 shorty headers instead of manifolds.
- Fuel pump setup dilemma! bahhhh
- ProCharger Rewards - It Pays to Choose ProCharger!
- Newbie questions
- New Dual Whipple Setup
- Twins selection
- lsx376 turbo selection
- Guys making 2000 plus hp turbo lsx
- Holley High Ram/ProFlow FI guys come in
- Map sensor question.
- Holley hp or dominator on turbo nova
- critique my setup please!
- return or returnless fuel system?
- boost valve springs,how far from coil bind.
- Wondering what kind of power D1SC will make?
- MORE AIR...for coooling
- 3 cars over 1000hp in a month...
- spark plugs for boost?
- Need wastegate spring with CO2?
- C6 manifold collector stud size
- LS3 or TFS235 Heads?
- Procharger Newb questions
- Video from XOS Outlaw Limited Street
- What's a good aftermarket oil pan set up
- what size BOV and what size wastegate for my combo?
- Cam Question
