View Full Version : Forced Induction
- 93+meth 20psi,tuning advise
- loog for a turbo?
- Going Turbo ls got some ?'s
- How to run a return line threw the evap ?
- Help me put a kit together...
- Procharger
- Added a blower cam to my LS3 C6
- built 5.3l or a AES 390
- Belt pn modular turbo alternator relocation
- rear mount turbo TOO LOUD!
- First boosted vehicle. Prioritize my next mods.
- one or two 450 walbros e85 pumps
- Need help with fuel pump issues
- Building a 408 Engine. Need some tips please
- Turbo 5.3 E85 fuel problems
- am I going in the right direction ?
- Rear End Gearing
- Which system to buy.......
- Looking for a fabricator to make me a custom intake ls7 for kenne bell
- Help me pick new TT LSX engine size
- 403cid w/tick cam and rear mount
- Anybody run an Aeromtive Eliminator Pump Submerged in the Tank?
- Koolrayz 88mm X275 Car
- Fuel system help..
- ***74 Nova*** 5.3L Single Turbo Build
- Proper cam gains over stock LS1 at 800+ whp?
- MY Real Street 275 build
- Sponsor fuel pump and wiring ?
- Do the precision vband in exhaust housings limit power compared to a t4?
- FAST 90 busted do i need a tune to switch to 102
- 10.8:1 compression + Full Time E85 + 21psi.....will it work OK...?
- meth inj or e85 for a midwest car?
- Turbo+motor questions
- Needed parts to complete Procharger setup?
- Intercooler choice????
- Stand Up Radiator and Retain A/C?
- Stumble when methanol kicks on.
- 2.5 V band clamps
- sloppy mechanics s480/s475 testing
- would these turbos work?
- Want some input before I start hacking up my TA bumper for a FMIC
- 8-900RWHP to 1100-1200 RWHP
- Max boost/power, built motor
- halltech ecm and dual fuel
- fairmont 3.0 (5.3, isky 3x12, s476r) 721rwhp @ 17psi pumpgas 9.68@145mph
- 2 bar timing map
- Motor build question with procharger
- 2002 Trans AM with D1 Procharger
- Which cast manifolds ?
- Evap solenoid question
- Another Stock Bottom End In The 8's
- Twin Turbo setups, what A/Rs turbines?
- Boost guage help...
- How much should i worry about my boost spikes?
- TFS Genx 255 ls3 vs Mast ls3 med bore
- Another will this cam work?
- Painting mild steel hot side?
- Huron Speed A/C kit
- Turbo set up gurus please
- Newb with FI on 347 Questions...
- Whipple or Procharger for my 383 LS1 jet boat?
- Wheelie?
- see the 6.0 turbo transplant in a G body
- Lingenfelter Supercharged 2014 Silverado Completion & 2014 Corvette LT1 Development
- FI with 11.1 comp ratio? Whats needed?
- What's best for FI? Holley hi ram, super victor or mast LXR
- RPM TBSS Goes 9's
- Questions about reluctor wheels
- Twin PTE 6176s or TC78?
- How cheap to hit 8s?
- Now what? What are my options?
- Innovate LC1 wideband o2 flashing "7.4"
- Gears or Convertor ?
- F1A question
- Gt45 ebay turbo where do u get the v band clamp ?
- Lifted heads on 5.3!! Back pressure??
- S400SX-80 ET-R HO Billet w/ Race Cover
- Any VP fuel dealers?
- WB02 sensors
- Holley EFI
- My twin 66/408 Straightline/Turbo Joe build
- Turbo the Bavarian Monster - LM7 turbo questions
- over heating(large frame turbo)
- anybody looking for 5.3 heads/cam for boost?
- Help! Steering Knuckle Clearance!
- Intake selection for Turbo 408
- ID this turbo?
- Anybody running stock fuel rails?
- Billy Briggs-engine break in procedure
- Holley hi ram throttle cable bracket. pics inside
- turbo spools but no boost
- lsx 376 b15
- Turbo ID?
- Coverter and gear suggestions
- 4.8 supra swap wanting insite on twin turbo's
- Who makes the best flowing heads for 4.030 bore and a THICK deck......for my 390ci...
- 5.3 turbo build cam
- New turbo build, crazy oil leak.
- My first build- turbo 5.3 in 1981 c10
- blew intake runner seal, what intake should i get now?
- twin turbo fueling questions
- 1026/821 377 ls3 ysi
- Dumb question on piping/couplers
- Safe dynamic compression for boost?
- start of my 5.3 turbo build
- Twin Turbo Recommendations- Comp Turbo?
- E85 + 100% meth. What is the octane?
- is this a good cam for my 6.0?
- low/rear mounted turbo oil check valve?
- stock spec lq9 twin s366 build..
- Differences in Derale Fans
- what kind of power levels 383 lt1 with 14psi
- Single TC78 or Twin GT35 for 5.3
- Help me pick my new Turbo !!!!
- Checking backpressure
- Maxing out a turbo.....
- Engine build decisions. Cam or CNC heads?
- radiator location
- 5.3 turbo build injector size??
- Turbo cam selection: Tick?
- Boost control using one WG on a twin scroll setup
- What is the fastest anyone has gone with the Z06 cam?
- Just Chevy Trucks Turbo Manifold
- Sequential turbo set-up
- big turbo forged internals
- HAWKS Magnuson TVS 2300 Formula "SALLY"
- Huron Speed TURBONETICS turbo sale!
- LPE LSA to LS9 TVS2300 conversion front cover
- Mayhem Motorsports 275 Radial C6 is making progress!
- fuel system for turbo 5.3
- 900hp vette VS the Junkymustang
- Decided to turbo, guidance for a newbie
- What's the best turbo setup for a 434?
- Alright, got some WOT videos of the old crazy hay haulin farm truck haha
- bench flashing harness (sloppy style)
- ?? Eric Stubbs Racing ??
- A2W intercooler setup for street and strip.
- Which Borg Warner turbo?
- 1981 Mercury Carpi Turbo LQ4 build
- STS kit vs Custom Rear Mount?
- fastest stock block?
- adding bosch 044 inline with existing dual walbros intank
- turbo with a/c... how hot you running?
- Spearco 2-230 intercooler
- First Turbo LS Build
- Where to get a cam from?
- **Help with high heat and plug wires**
- Newbie Question on a Whipple S/C
- 4.8 + 7675 + nitrous
- timing for a stock L33 with 7 # boost ?
- New build. 5.3 rear mount c5z06
- Boost control Help
- NEED TURBO HELP! STS guys also!
- lq4/ arp rod bolts
- Keeping vaccum hoses connected on ls6 intake manifold under boost
- turboing a stock motor question
- Non intercooled + loads of meth?
- P1sc and new motor ?
- Ceramic coating, who, where, how much?
- 95 Z28 V6 turbo swap
- ET estimates on 1983 Ford Mustang hatch
- twins for a 4.8
- Reduce Compression to Increase HP?
- high pressure throttle body shaft seal?
- Fuel rail size and fuel line.
- Turbo 6.0, 5.3 or 4.8
- 5.3L turbo
- Build Numer dos (Turbo G body)
- Twin Turbo farm truck gets a small makeover
- turbo wastegate question...
- Testing for boost leaks
- Motor builder
- How much boost safely on this set up
- Help! Turbo Pick
- Stock Rockers or Trunion Upgrade?
- What turbo for 1000rwhp 370ci lq9?
- throttle body boost leak
- Turbo kit for ls1 in silverado
- 1968 camaro radiator choice?
- turbo oil drain question
- Wastegate and manual boost cont questions?
- New S400 Turbine housings for the 96MM Turbine wheel.....
- Help me choose a turbo
- FI C5 Corvettes - How much torque will the driveshaft take?
- eBoost 2 question
- Who has relocated radiator to the rear??
- Battery Relocation..
- my experience mounting extra 9" Fan(with pics)
- big dreams, 98 ecsb turbo ls vs new 5.0
- IM TRIPPING OVER TURBOS! Huron Speed turbo special!
- what head gasket to use????
- griffin radiator guys, what coolant over flow?
- GT45 vs. 76mm
- P0340 code now??
- lightest battery
- Oil in water
- combined 02 sensor trims in hptuners? speed density
- 76mm street Nova runs 8.39/163.75 mph!
- 50-120+ in a truck. :)
- How does this Combo Sound? 02 SS DR
- Lets talk about turbo exhaust...
- Hi volume oil pump with twins?
- 97 Camaro LS1(346) 76MM Turbo Build Thread
- Early 5.3 rods bending?
- Real street turbo build. "Silverback Gorilla"
- SBE pt7675 on e85
- Newbie at FI with a twin turbo kit
- Head gasket oops
- for those using 317 heads
- Log manifold O2 sensors
- When should i ditch the Truck intake?
- Chevy 4.8 V8, turbo or pro charger?
- Who Is at 3200 race weight with iron block?
- 383 on twins
- Methanol/Water Injection Guys... Post your #'s
- Holley hi ram or ls3 intake for boost?
- Best intake manifold for a turbo LS
- which pulley for 8 psi
- Holley Dominator EFI, OR, PRO EFI
- ProCharger Customer Vehicle Gallery
- C6 manifolds for turbo?
- msd 6010 map sensor help with boost
- Any one use a steering wheel button to activate boost controller?
- 2010 Camaro D1SC
- Mishimoto intercoolers?
- speed inc tu1.5 cam
- hotside pipes extending past flange?
- LQ408 and a V3 Si
- using helicoiled block for boost.
- Master Power Turbo Mystery?
- 6.0 91mm turbo mustang. what trans/converter?
- T4 or T6
- Cam good for boost
- Best location for 02 sensor pic included.
- procharger problems
- who has a CNC program for LSA heads?
- Co2 or no?
- Quick turbo question
- Exa Pump Wiring
- What plugs for a turbo ls7
- Anyone no limits on hp with 4" exhaust
- anyone have info on fitting a 6/71 blower on a LS1?
- Turbo torque converter decision HELP!
- Projected tip plugs for turbo
- LS1 basic turbo build
- Intercooler question.
- Twin Turbo C5 Corvette Side Exhaust
- Simplified Catch Can Set Up
