- Need to get my converter tweaked suggestions?
- What rpm is my Vortech V-9 spinning?
- twin turbo help
- Virginia Speed turbo headers
- VA Speed 370 ci 1500hp street/strip engine
- Cog drive
- Couple of FI questions
- Where to order piping and flanges?
- 408 FI build
- Progress pics of Turbo Drag radial build.
- Wsss6 - MPT70 Front Mount Build
- Ls3 with 317 heads
- Do FI apps require different lifters than NA?
- cam 221/221 .561/.561 114+4 sound like a forced induction cam?
- What size turbo do i need?
- port size on head for 402?
- 347 tube header primary size
- Turbo Kits?
- STS Or ebay knock off Kit
- Cold side piping
- Belt size from autozone?
- Oil feed question
- What intake are you running?
- Race Truck Manifold Setup
- Can't find thread!!Help Alt relocation
- Turbo engine ignition system
- studs or bolts to attach exhaust manifold??
- What are the big #'s being made with truck manifolds?
- Meth vs Nitrous for FI
- Electronic Boost Controllers
- Holy Fing trans brake!!! FLT 4L65E, tc78 KYTP KIT!
- Anyone installed a float level sensor for methanol in stock tank?
- soon
- whp max with a ebay manifold kit?
- Intercooler Tank ?
- Running E-85
- LMR @ shootout???
- Turbo cam motion
- STS turbo kit smoking like a chimney, ??
- New Turbo setup pics what do you think?
- Poor man's method to better belt wrap on an fbody
- 853 heads??
- For anyone mixing Methanol...Conversion charts inside.
- My motor issues are figured out!
- crankcase evacuation?
- Intake behind radiator or ??
- Best super charger kit for a H/C/I stalled 347ci
- twin turbo intercooler
- Glad I decided to dump my wastegate
- What turbo for a 402?
- I suppose its time to make a build thread...eBay kit!
- FMIC on a trans am, keep the foglights?
- PTK Corvette kit
- what metal to build custom headers?
- Front Mount Turbo CTS-V Questions
- Cheap Heads for D1SC
- Questions on this ebay kit
- aluminum block power potential
- AMS-500 Boost Controller Plumbing
- Using Vortech SC, Which engine 5.3 or L92?
- 5.3 lots of questions
- new best with my turd
- ls9 + kenne bell?
- High Compression Turbo Cars and Timing...
- PT88---3.5" downpipe okay?
- Neeinfo on 01 ls1 heads and Lq4
- Truck headers
- 4000lb. True Street Car Pulling Wheels.
- How to tap oil feed?
- 09 CTS-V at LSX Shootout
- Too hot and need help!!!
- So apparently I've been lying to you guys...
- 2 step and Procharger??
- intercooler idea
- New best with the D1SC today
- Which cam do you like for turbo boosting?
- epp fmic 90degree elbow with stock throttle body
- which cam should i use
- New Best Today for my Turbo GTO 10.45@134
- Turbo Component Setup for 347 CI
- 01 WS6 w/ LS3 Trubo Build ?'s
- Best turbo (largest) plus BEST Price for 347CI
- Reichard Racing Pulleys
- well ran the ltX again, 6.2@112 in the 8th!
- Rebuilding for boost, just a quick question(s).
- ysi vortec supercharger oil residue at intake pipe
- Turbo LS1 Hybrid Car
- high inlet temp problems
- 6 bolts vs double O ring
- More boost, Less timing OR Less Boost, More Timing
- Garrett TA45/51
- Building tubular headers for a LSX RX-7- 106MM turbo
- Procharger Tensioner Pulley
- Help Intercooler Couplings
- stroker engine temps
- 402 LS2 worth the extra $ over 383 LS1?
- Max cubic inch for MP122
- Maggie ?
- Is anyone else running poly motor mounts w/ truck manifolds?
- 4psi Jump on the 2-3 Shift???
- Wondering wut rwh i may expect with my setup
- Finished pics of my scavanging pump setup
- is this cam ok
- master power turbo question
- Fuel line size
- T70 Turbo?
- Maximum Effort LSX vs Warhawk
- Quick connect tubing
- APS Guys: Who would be interested in GT35Rs?
- W2A on a STS finally up
- TC76 vs. TC78
- Belt Slip What have you done to fix it and why?
- Turbo RWHP???
- boost limits
- TC 78 race cover anyone ?
- supercharged 6.0 potential
- single turbo with a/c & p/s
- IAT Sensors on turbo cars
- SLP muffler > Flowmaster?
- Increase blower RPM potential power?
- block
- 6.6 diesel turbo setup? possible?
- KYTP setup
- Be for i go to far. take a look and help this build.
- Twin Turbo LS1 Maserati vs HKS GT570 R35 GTR
- Ebay Wastegate Spring
- Several questions for the more experienced FI guys..
- STS Question, Will it fit on a 3800 since its rear mount?
- All Out Performance, Josh at KYTP, LSX Motorsports
- dart pro 1
- What valve spring height setting should I have?
- How many miles on your 2618 forged piston engine?
- Oring'ed Heads... who's done it?
- How to boost my 402
- exhaust gaskets...?
- What does it take
- Blow Off Valve clips?
- valve spring question
- procharger vette mounting bracket on f body????
- Anyone have the instructions for the STS boost controller?
- VID, 9.80 pass, 1st day out
- threading a iat
- What is the best to do first, motor or the FI setup?
- custom spark plug wires
- What intake????
- Turbo pro's advice highly needed
- vortech sq9 smaller pulley
- Sts oil pump plz help
- Who own this TTi TA?
- Burkhart shop car update
- Turbo motor questions!!!
- FAST INTAKE to LS6 tune?s
- the actual turbo parts help
- F/M Turbo w/ pwr steering or not
- Miller Engine
- 11:1 compression and wanting boost?
- No Boost - Turbo
- Best method for holding down heads??
- Bunch of hot air or Not ?
- F1A / LS3 Build-Up
- STS warning buzzer
- New dyno numbers
- BOV, MAF and TB placement?
- cam suggestions
- Quick vid of my rear mount car
- 25.5 93 Mustang LS turbo powered build thread
- meth nozzles
- Meth Injection location on a whipple
- Ive got problems, pushrods welded to lifters only on intake side, help!
- Pump for A2W System
- wanted to say thanks
- need help!!!
- Boosting a LS3?
- Members with turbo close to radiator,come on in.
- need a muffler recommendation
- For all of our forced induction customers going to the shootout
- Boost gauge vacuum reading be at idle?
- 130 miles from one tank
- Anyone run a .68 exhaust housing on TC76 or T76?
- Max power with a F1 and RE-0870 Airfilter
- HELP - IAT issue - HELP
- Head to piston clearance
- Turbo+Air conditon in FBody?
- Best Cooling for FI?
- Problems with plug wires
- maggie build Q's
- 383 ls6 vs 416 ls3
- carb hat vs box.
- Ignition advance per compression and boost?
- my build!!!
- Vortech V3
- Best way to go FI... 800 hp
- Pushing coolent?????
- O.f.i.
- What compression to go for
- i need some pics of 1st gen f-body turbo setups!
- what is needed
- APS LG upgrade vs Garrett T3/T4
- Need a coolant fitting for turbo cooling
- LS3 6.2L Bare Block
- RX7 FD Sheetmetal Widebody VA Speed LSX 463+PT106 on E85
- A&A + Cartek + Moizer = help me please !
- 98 ta 414ci
- head gaskets felpro vs. cometic... opinions
- It's here....
- turbo failure?
- need help from the aps turbo guys using a manual boost controller
- Oil Lines and Pan Question
- Fireball Outlaw Drag Radial Rebuild Thread
- What pistons?
- Michigan Engine Builders?
- When is your supercharger maxed?
- Some small tips for fi builds.
- 852 hp 402 aps with LG turbo upgrades
- Who has actually bent /broke aftermarket rods?
- what should i do?
- D1sc help
- What k member are you running and why (turbo or regular)?
- Need your opinions please...
- E85..with FI
- Boost on a Crane 227 cam?
- Water crossover tube...
- Advice needed on new LS build
- Anyone have a LS1 383 stroker? Curious of numbers?
- FLIP DRIVE - Finding the limit on 6 rib blower drive - Part II - 21 pounds of boost
- Forged Iron 370 / AFR 225's / Truck Manifolds / PT88
- Questions on new 2 Bar MAP??? With pics...
- oil return
- wich is stronger LS2 block or truck block?
- New Car, Revised Tune - Graph attached - Thoughts?
- STS Upgrades
- The GTO we are trying to get ready for the Shootout!
- NOVI 2000 C5 VS TT SUPRA IN Kuwait
- How silly would a STS turbo be for my setup?
- Recommended plug heat range..
- Changing a few things. Cleaning house also.
- Redoing my turbo setup.... some parts up for grabs!!
- has anyone tried the Carbonite coated pulleys?
- 10 rib pulleys
- need to know what all i will need to install supercharger?
- How much power
- LSX 427, LG Upgrade's, Goes 1040 RWHP !!!
- Methanol injection need help please.
- any1 know what turbo kit this is???
- lightweight flywheel for the street? (with turbo)
- D1-SC strange noise...
- Ready for LSX Shootout!!!
- Fuel Rail
- What size headers with my P1SC?
- F1A Procharged 1972 Nova pics inside.
