View Full Version : Forced Induction
  1. ? on LS6 facing backwards. HELP!
  2. stock cube turbo question
  3. quick question
  4. is my turbo too big??
  5. PAC 1218 good for 16-18psi of boost?
  6. Looking at a 99 LQ4. What issues with a TH350?
  7. 370+ GT4276 Truck Manifold build
  8. Who sell sts turbo kits?
  9. Paxton Novi-2000 rebuild ?
  10. Staying with twin T70's. .68 or .96 housings on a 370???
  11. Enough with the 6 speed
  12. STS wiring schematics help needed
  13. Will this layout for PCV on a boosted engine work? Picture within
  14. Photo's needed for Upcoming F-Body Book
  15. I love it when a plan comes together...awd VAN beats ZR1.
  16. Undivided 1.15 F1 68 housing?
  17. 5.3L engine with 13psi boost 6600lbs, 2800 rpm converter, powerglide... will it work?
  18. boosted g8 at 5psi, can't tune out knock.
  19. New plumbung cold side & A/W. Pics added from Speed Inc.
  20. Oil in charge side of turbo?
  21. Just got my car back from speed tech
  22. 5.3l forged pistons for turbo setup
  23. What size spring for Tial BOV?
  24. Anyone have a Procharger 6 rib balancer bolt?
  25. eBay kit D/S header
  26. More P1sc install issues
  27. Need Head studs for my lq4 project?
  28. Update to my BS3/Backfire issues...
  29. High Engine Temp. Question.
  30. Turbo smoke....
  31. Another 1000hp LMR Street Car!!
  32. 242/242 .624/.624 on a 115 or 242/240 for Rearmount
  33. What size charge piping?
  34. Discovered APS turbo fllaw?
  35. Boosted 6speed conversion
  36. Too much power for Rearend?
  37. Trying to find a 1/2" or 10an check valve for FI catch can setup?
  38. Pics of the other eBay kit
  39. Burkhart Bumper Support and Manual Master sale LSX Shooutout preorder
  40. best cam for a disc
  41. 408 build
  42. APS Turbo Failures
  43. Intake for turbo L92 6.0....LS3 VS Vic Jr ? ?
  44. 7psi on stock tune??
  45. Battery relocation
  46. 04Cobra compalation video
  47. Which valve springs for stock engine with 6-8psi of boost?
  48. Rear mount turbo: turbo upgrade time
  49. Can anyone tell me if sts kit or something similar would fit under my car?
  50. Edelbrock LS3 E-Force Supercharger???
  51. Ninetres > ZX10 video
  52. turbo ls1 piston recomendations
  53. firefightergib start up vid!!!
  54. borg warner S400 turbos any good?
  55. P1SC Procharger head unit forsale
  56. Who makes turbo inlet pipes with the lipped ends
  57. Fuel pump volume VS Boost question.
  58. 370 vs 408 for pushing water/lifting heads w/GT91
  59. Magnacharger guys- How long did it take to get your supercharger??
  60. Need More Power!!!
  61. Is C16 the best bet for race fuel?
  62. ebay guys!! my O2 sensor wont fit on passenger side :(
  63. just got fired may have to sell
  64. what size oil lines??
  65. Looking into superchargers for my setup?
  66. Stock ls6 MAP on 15 psi of boost
  67. MP90 Magnacharger
  68. A2W core selection help!
  69. GT 35 BB bolt on turbo for the APS F body TT system
  70. procharger installation
  71. oil viscosity vs oil temp in turbo applications
  72. Deleting PCV to catch can what size hose?
  73. Throttle body opinions...
  74. Not always boosting on my P1SC
  75. modded sts should I port match the flange?
  76. Couple vortech questions
  77. t70 vs t76
  78. 347 at 10psi of boost
  79. Heat shielding
  80. oil feed and drain lines on a ls1
  81. Size hose and what size fitting for oil return with turbo?
  82. What Wastgate spring is in the STS kit? Can I use it in my build?
  83. MSD 60# injectors??
  84. What size intercooler
  85. Considering price of FI with my parts to sell
  86. cam/converter/gear questions
  87. HELP strange power cut please HELP
  88. Check your meth nozzles!
  89. New cooling fix
  90. Need a custom turbo kit?Look no further.
  91. Anyone with Kentucky Turbo A/C kit?
  92. Should I run a 2 Bar or a 3 bar Map sensor in new setup?
  93. LMR Twin Turbo Corvette runs 9.40 @155mph first weekend!!
  94. 20psi on 6.0L???
  95. Will Flowmaster hurt too much?
  96. twin 60's
  97. Turbo Exhaust Question???
  98. Help with 1000+ hp engine.
  99. Pro's and Con's of running either compression ratio with my setup?
  100. At what point do I need a boost referenced fuel regulator?
  101. Kentucky Turbo is doing TT my build
  102. P1sc install question
  103. Few updates on the Firehawk
  104. IAT's
  105. Major problems with F1A Inlet Hat
  106. Exhaust wrap length?
  107. Which lifters for Boosted apps?
  108. twin turbo 4th gen kits?
  109. EPP GTO ProCharger Overdrive Crank Pulley $425.00
  110. what balancer do i need for a d1sc?
  111. magnacharger mp112
  112. D1SC same impeller as F1A
  113. Mild vs Stainless Question
  114. Help me decide
  115. How much Boost can I run Safely?
  116. Turbo HOT side pipeing
  117. Aftermarket condenser?
  118. CX Racing 2-in 1-out front mount intercooler
  119. project D1 procharger
  120. F1R help?
  121. Need help picking cam
  122. Some more video of my spooling my 1.25 a/r 80mm turbo at the track
  123. At what power level?
  124. People who have purchased APS kit VS. Kentucky Turbo kits.
  125. Godspeed turbo kits?
  126. Header Wrap Protective Paint?
  127. What gauges do you recommend?
  128. help me go fast
  129. Need Help With New Set Up ???
  130. Are these the correct specs on the TC78?
  131. what converter stall for my turbo
  132. Inline BOV?
  133. Calling out APS
  134. Truck Manifold 408 S88 track results
  135. Crank trigger
  136. Todd @ superchargerrebuilds.com is a fraud!
  137. Twin Turbo LS1 1993 RX7 Build
  138. Recommend me a timing chain
  139. Does the sts turbo oil return line ? Want to run AN lines...
  140. making the switch from procharger to turbo !
  141. Head studs, Hex nut vs 12 point nut input wanted
  142. APS Extreme Kit
  143. 6-rib boost
  144. Pics of the internals of bad APS turbo
  145. I have 98 TA with a front mount turbo and I'm having issues with my 99+ pcm upgrade
  146. Starting my Turbo build
  147. Poll: OEM Turbo vs. OEM Eaton based S/C
  148. Why's my turbo car so slow?? 6.9@104
  149. Procharger pully swap ???
  150. Max effort turbo headers...
  151. PTK kit Cooling fan Feedback? Anyone wire up a 3rd fan for their turbo setup?
  152. What do you all think of this parts list?
  153. rearmount with seperate oiling
  154. Installing a AIT sensor in a LS6 intake? has anyone tryed this?
  155. Meth nozzels in a TB spacer plate after the throttle body?
  156. My .76mm 04 GTO
  157. help me make a next deployment build sheet!!
  158. Big Red ATI Race valve location.
  159. Turbo Component? APS 2 Inlet 1 Outlet Intercoolers?
  160. LSX427 Cooling issue's????
  161. Another Turbo camsgaft thread !!
  162. F1-R on 6.0L?
  163. Pics of major defect i found in APS turbo!
  164. What Master Power turbo to run in a rear mount 383 setup??
  165. vaccum system
  166. Overheating issues with ProCharger: Resolved
  167. Electric Fans a Must?
  168. LS1 418 F1A Build Thread
  169. Article: Show n'Go, Mark Koehler's 7 second LSX Firebird
  170. Misc. Front mount questions ..
  171. Custom rear mount for a GTO. What do you guys think of this setup?
  172. no boost
  173. APS w/meth
  174. finally did some test and tune with my camaro!
  175. Whats everyone's converter flashing too?
  176. What are you guys doing for fuel pressure in your 600+ vehicles?
  177. what turbos for my 5.7 ?
  178. Vortech S trim superchargers???
  179. will this port work as a fpr vacuum source? see picture
  180. Procharged 5.3
  181. tr8?
  182. Front Mount Taurus Fan
  183. LC1 not reading...
  184. who runs high comp low boost?
  185. Free Shipping on ProCharger Systems at EPP
  186. Going Turbo - need help
  187. What AR to go with on the MTP76 for 383 stroker build?
  188. Crankshaft Drilling Question.....
  189. Car wont pass 3600rpm
  190. Colder Intercooler Fluid
  191. Is this about right for what I gained after putting on P1SC?
  192. MAF improvement
  193. shift points for xer273 comp cam
  194. ported 317 on stk 00 lm7??
  195. My APS fuel regulator relocation
  196. Any users of MSD starters on a APS F bodys
  197. Ls-7 compression
  198. Help!!!!!
  199. A couple new pics of my F2 build
  200. Done for the season
  201. does this "sound" normal - TT Z06 rev?
  202. Virginia Speed 438" LSx sets new track record 162mph 1/8 mile!
  203. LMR's 08 Corvette makes 1023.44rwhp and 874rwtq!!
  204. Post your Single or Twin Turbo Setups!!!
  205. Twin Turbo 2010 Camaro From STS!
  206. 80# injectors to much for my 383 build?
  207. 2 step w/o transbreak question
  208. Mock up pics of APS scavanging kit
  209. Should I swap TB in my 383 stroker build?
  210. 317 or 243 heads with boost
  211. coolant line running to cylinder head ?
  212. >> Who blew up their stock internally motor on boost??? Details??
  213. Negatives of restricting blower inlet vs. changing pulley to get less boost
  214. Putting together Incon TT, still missing a few parts.... need help!!!
  215. Can I get some opinions on my ideas?
  216. Thinking of turbo C5 ideas. Please chime in.
  217. I have a extra APS F body turbo
  218. Steer me in the right direction .. 91mm turbo build
  219. Piston to valve contact, are my pistons trash now?
  220. LMR's 1000rwhp Corvette!!
  221. MPT76 dimensions
  222. Ebay kit while retaining a/c?
  223. GT4202 Results
  224. GTO Overdrive Pulley for Fluidampr 740102 Balancer
  225. big o' box o tubing
  226. The hardest what will it run thread EVAR!
  227. Y-pipe downpipe?
  228. Do I need to get manifolds coated?
  229. front mount intercooler
  230. Comp Lsr Turbo Cam 54-480-11
  231. More pics of my Truck Manifold, 6.0, MPT 76 Turbo
  232. Truck manifold alternative...
  233. Pulley change
  234. help!!-procharger making weird noise
  235. Incon TT Stage 1, Stock Block, Cam Opinion?
  236. LS-7 procharged
  237. turbo upgrade question
  238. Turbos and AC (YES I SEARCHED)
  239. FI close LSA dyno #s
  240. Using 85mm SLP MAF with STS
  241. head stud size for LSX
  242. Twin STS system for FBody?
  243. compression for procharged LS-7
  244. magnacharger q's
  245. She's alive #2
  246. larger intercoolers
  247. Need V-Band for 91mm turbo
  248. supercharged 5.3l
  249. Wide Band ?s.
  250. timing with a low compression turbo setup
