View Full Version : Forced Induction
- Weak Point on Stock LS1 with FI?
- divided vs open
- Which turbos for my LSX427?
- What are these procharger parts worth ?
- Forced induction cam ? Thompson engines ,Huron speed,tick performance come in!
- Got some free stuff and LSX block warrantied
- 91 camaro 6.0 LS3 heads turbo build
- New Turbonetics Turbos
- so i took the caddy to mexico...
- injectors for 700rwhp
- E85-E70 How much will it effect my tune
- on3 turbos
- C16 or pump gas w/meth injection?
- Ls1 vs. ls6 intake
- anyone tried this
- my 5.3 parts list help with turbo
- Thank you Huron speed
- Turbonetics??????
- External oil pump for turbo system
- FMIC or Meth Injection?
- Fast 92mm intake and boost?
- 1930 Model A Twin Turbo 5.3 Build
- How much hp can dual bosch 044's handle with -08 feed.
- Valvespring question
- Opinions Needed!
- Oil pan question
- Procharger F1-A on 97 SS
- Measuring boost before & after intercooler--What is an acceptable loss?
- List your cheap-azz combo
- can my 5.3 spool this?
- Anyone use a stock shortblock l92 for boost?
- Best Meth Injection Kit?
- Fuel system
- Huron Speed Truck Manifold Turbo Kit TAX RETURN SPECIAL!
- Low Compression + Pump Gas... How Much Boost?
- Any front mount turbo guys using this?
- good budget glasspack/strait muffler for turbo lsx cars?
- Catch Can has some smoke/vapor
- anyone using a bmr alt. relocation bracket
- Turbo flange braces, what size round bar?
- 9.0h at 150 tc78
- z28 vert*370*twin 76mm*budget/barter build
- Starting over/Help Needed
- Educate me on Prochargers
- oil feed question
- Some Video from the CTS-V Rental 2/23/13
- Root/Twin Screw - Supercharge Options
- LT1 Guys Come On In Please
- Newb question????
- power adder advice
- is this manifold broke???
- ProCharger guys...anyone ever have issues w/ stock crank?
- The new WOOOOO ls/sb radial tire record!
- FI.com lists tc78 (1000hp) why?
- 402 10.8:1 pump gas boost possible?
- My Build 96 Impala SS
- Spark blow out, my experience & what I learned
- 408CI boost question
- stock vs aftermarket heads
- A/W intercooler question????
- Procharger Kit/tune?
- What does your turbo car weigh?
- Stall on a Turbo T/A
- turbo k member
- Whats going on at Race Proven Motorsports (Video)
- Heintz Racing does it again!!
- Version 2.0 / Z28 / Procharged / 383ci / Build /Dyno Results
- Huron Speed A/C Turbo Kit GROUP PURCHASE!
- 2011 6speed camaro ss turbo build
- Turbo s10 build thread
- THANKS! Huron Speed
- My attempt at TQing boosted LS head bolts. (Inspired by Denmah)
- 1998-2002 F body Pro Charger mounting...
- Huron speed guys? oil return hose ??
- Low RPM / high torque
- FI + m6 + 27.3" = ?:?? gears
- Lock the converter for less RPM at traps, or leave unlocked??
- New turbo manifold for trucks. :)
- Dual Fuel on the fly(87 and e85) on stock pcm's!
- Turbo 4.8 Dyno Mule
- LQ4 - Single or Twins
- Unique Turbo Recommendation, Please
- how well do you think this turbo will work?
- Wrapped headers to help with under hood temps (d1sc car) what u guys think?
- C6 Corvette build - ProCharger F-1A / 365ci / LSA / E85 [*UPDATE* 915whp/815wtq]
- Changing pistons, need 370 pistons .. What to get
- If I wanted to build a LQ4/LY6 for a turbo, what should I do???
- Bosch 044
- 6.0 + S480 = 1289 rear wheel horsepower.
- Belt for ATI harmonic balancer?
- Filter Selection
- T70 vs T76??
- How much boost are you guys running through your FAST intakes?
- Denmah inspired 82 Fairmont Futura turbo build decide to go with a big single!!
- S85 track video
- Swapping engine, K-member.....
- Turbo - Which intake & accessories
- fastest stock cube with turbo?
- Oil Supply/Return Locations for LS2 Turbo?
- PT106 and 5.3L stock?????
- wastegate vacuum hose/ rear mount
- Is there a difference between the two intercoolers?
- WTB Alky meth kit and BOV
- *** Engine Carnage Pics ***
- The Vanilla Gorilla! LQ4, xt80, 97' RCSB Chevy on Propane! Update! Track Times!
- Holden Monaro (goat) procharger help!
- Cam selection on 434 LSX- Procharged F1d ---
- Time for TNT...hardcore racers chime in!
- Boost creep - looking for opinions
- Borg Warner Turbochargers - Huron Speed
- How to wire spal fan with stock wiring harness?
- s10 build
- Twin TB's -- Sensors?
- 79b injectors enough? Turbo
- 1998-02 LS1 Twinturbo system
- Results After Adding ECS Alky Control Dual Nozzle Meth Kit & Tial BOV
- Turbo 5.3L $5k Budget Build Max HP?
- LSX Real Street 383F1C build
- My First Two Runs at the Track with Denmah's Fairmont....
- HP Tuners.... How hard to learn, Should I go this route?
- garret turbo question
- Not an Lsx BUT still turbo...Saab 9-3 2.8 turbo
- Too much turbo for my goals? (s480 race cover)
- Another cam question
- Why does forced induction cost more than the engine?
- turbo 5.3l rebuild
- Anyone thinking about getting a ON3 turbo? SAVE YOUR MONEY AND DON'T!!!
- CFE Racing VS Fast 104
- Super Victor intake / air distribution.
- What hat/filter for F1a/front mount setup.
- Scavenge Pump or gravity drain
- twin gt45's to small for 408?
- 99 3.8 upgrades or turbo
- 70 chevelle turbo header question....
- 1999 Camaro SS 996rwhp stock 5.3L dyno video
- What crank pin kit for procharger?
- what engine builders dyno motors before shipping?
- C5Z/F1R goes 9.96@148.99 with a M6
- 5 wire mass air/sd tune
- b16gsr 99 AW FRC Vette build, 5.3L, F1C, TR6060, Tick Performace,*6.29.13Update*
- kkr1000
- FMIC, Relocated Condensor, Dual 16" fans
- Worth changing cams for turbo setup?
- High HP E85 Turbo Tune
- FI CAM ON N/A or N/A CAM ON FI???, and LS3 & Paxton Novi 2200Sl general.
- Inquiring about hardware for the TVS 2300.
- If you know how to wastegate a procharger come in.
- PIX needed with 4 port coolant crossover and HS turbo kit
- Spool time differences b/t gt4788 and s480
- help with wg placement
- Welding to truck manifolds
- Need Foxbody LS 6spd turbo advise
- 9.81 @ 138 w/ 1.48 60'
- 1970 c10 lq9 Turbo questions
- Attention moderator!!!!
- Huron Speed A++
- Thoughts on this turbo kit
- tc78 having some problems
- Advice Needed For Piston Over sizing
- Blow Through Carb
- '84 Cutlass JY5.3, Custom Tick Cam, S400SX4-75, 4L80e, 3.73s, 27 inch MT's
- Any fi guys do alot of street driving without wipers?
- stand alone waste gate . possible ?
- what cr are u high hp e85 turbo street car guys running?
- 408 10.9 comp, e85 ideas (help)
- Help with turbo cam selection
- 5.3 gt45 4l80e what gears!!!!
- Wastegate size help on turbo swap, boost creep?
- Tial Wastegate Springs: rating vs actual
- What turbo is this ? Borg Warner/Forced Inductions
- looking for input on building a motor for an F1A
- Reclocked PT76GTS, what torque spec for housings?
- APS twins... reliable enough for a DD car?
- Will this work to make 450-500rwhp?
- Edelbrock Victor intake with elbow?
- any one using truck accessories and truck manifolds, in here please
- Pa racing turbo k member issue!
- My ideal set up
- Size difference between precision Pt88 and aTurbonetics 88mm
- 14 gauge aluminized steel?
- Just picked up a FI car D1SC
- th400 and 5.3 or 6.0L guys step in
- Turbo cam help please
- replacing turbo on my STS LS1 next week
- 402LS,E85,91mm turbo what fuel setup to run
- p600b procharger for my 6.0
- Turbo 5.3 fuel system
- help me choose my new aps with lgs.... or.... a huron speed single kit?
- aluminium block vs iron
- Will this cam work?
- ATI crank pin kit
- How to build boost using the Trans Brake?
- Open down pipe?
- 241 Heads on 5.3?
- 99 Camaro SS BW S480/87 347 C.I
- Cx racing build thread
- need help p1sc or 76mm turbo kit
- Turbo 6.0 4-Door Fairmont Build
- How are people keeping their map sensors in their FAST 90's???
- Cam/heads or turn boost up
- Turbo placement variables
- Need help with double keyed crank!
- Special kind of Twin turbo
- help me hook up my jgs bov and wastegate please
- 3.08 gears+tight converter+drum brakes=fail
- S480 w/Race Cover or Without?
- Lsx mustangs with truck Intake (hood)
- to big of injectors?
- Huron Speed Special Edition Kit w/ Turbo, WG, BOV, Oil Lines!
- LSX ironblock engine for corvette c4
- Roots blown vs Turbo
- 3" T6 Turbo Merge Question/Request for pics
- Interesting results with alcohol injection NON-ls1 engine
- Changes to control engine heat?
- A&A / ESC supercharger bracket !
- Which heads to choose
- ptc converter brake stall?
- Best place on pan to weld in -12 oil return bungs?
- Techline high temp coatings
- F-1 a c or x what are you doing with radiator
- Nitrous Problems come in
- 402LS,PT91 what gear ratio ???
- turbo cam upgrade
- TT 69 Camaro - Vendors
- 29.5 degrees of overlap + Boost-?
- KY Turbo/ Race Fab
- 68 "GTTO" 5.3l Twin Turbo Build with 58mm Garretts
- Will this fmic work for procharger?
- Turbo 5.3 Foxbody. HELP!
- stock LY6 longblock mild build, re-gap rings and head studs or leave alone?
- hobbs switch and vac manifold blox
- Help me solve this problem.....
- 80mm turbo intercooler needed if I'm using meth?
- What fuel pump or???
- Boost comments
- Need COG belt ASAP HELP
- denmah's commonly bought turbo car items (update 7-11-16)
- Boost leak around Injector O-rings
- another s472 turbo 5.3
- WTB vortech ysi
- spark plug chart or diagram for boost level?
- Those who use a 3 step (low/high) limiter to get spooled up quicker on converter.
- INTERCOOLERS Thoughts on air v water
- E85 vs Alky
- REDSLED Photoshoot
- Race gas question
- c5 p1sc the same as a p1sc for an f-body?
- Help me choose a turbo.
- Help on a formula to tt my nissan 240sx ls powered
- Mast Mozez heads + Chris Razor on methanol...
