- spool difference between turbonetics t76 with p trim vs s trim turbine
- Part number for Cobalt 2bar MAP
- Where are you getting the bar across the front when standing radiator straight up
- Making meth??
- When do you start building boost?
- Best Fitting Aluminum Radiator with A/C and D1SC
- external wastegate leaking by at an idle!?!
- Twin turbo suggestions
- Compression Ratio Calculation
- valvesprings breaking!
- STS new numbers
- Anyone try silver paint on head gaskets?
- LSXTV Article about 8 Sec Z06
- Stuck trapping 154-155mph...
- AIS meth kit question
- p1sc c5 epp blower cam and kooks installed clip
- Fastest Rear Mount F-body??
- turbo setup(so far) andy suggestions
- Nice 447 with a 101 turbo video
- looking for the best mbc..
- Track results are in!!!!!
- Ls6 427
- Typical gains with Methanol injection??
- blow up my motor, pics inside
- Need help on this camshaft for my turbo
- kenne bell
- Start Up Audio and Pics of V8 Miata
- STS dropping boost
- Am i safe or pushing it?
- Boost Guys Opinion
- Forced induction lq4
- Installing custom FMIC. Have some questions
- 09 corvette supercharged numbers
- In Car Pics of my 427LSX motor
- Miata First Start Up - More Videos to come
- How much boost?
- Stock LS1 turbo questions?
- APS 346 dyno 599/543
- boost controller on s/c
- Complete ProCharger D-1SC kits with tune from EPP
- Best Chemical cooling agent
- Frcefed98 Signing off.......
- how much boost will i have
- exhaust manifold gaskets
- side dumps
- Best place to get a 76mm turbo??
- Just how much power??
- Coating Turbo Headers - which one recommended
- Synergy 2step wiring on 98 F body
- Turbo setup for 4th Gen camaro
- turbo fittings
- WhereToBuy - Procharger J-bracket?
- restrictor plate guys come in !
- Boost Pressure Gauge
- AFR dual valve springs good for boost?
- Playing with the trans brake and 2-step....
- Who all has disabled Burst Knock?
- FINALLY Taking the Rear-mount 88 SS out!!
- compression?
- Where to get a z06 cam
- Lunati Pro Billet rods
- ls6
- stock MAP with MAF tune?
- Intake Elbow?
- Need Big Boost Big Bore Head Gaskets
- light weight fly wheel?
- APS Twin Turbo Questions
- procharger fan setup
- any problems with wrapping exaust pipes??
- LMR Procharged 08 C6Z Dyno Vid and Pics!!!
- turbo selection help
- Dyno Question
- supercharger wanted
- supercharger
- anyone have a 2/3bar timing map i can copy
- what does a evap solenoid do and why do i need it?
- twin turbo lq4 or ls1
- Alkycontrol Kit: Denatured Alcohol vs. Methyl Hydrate
- turbo or procharger?
- Turbo bikes?
- Downpipe w/ Truck Manifolds
- lt1 intercooler piping ???
- sts exaust question
- would i need a retune?
- Oil fittings in/out S480
- pics or advice
- Boost Controller 'duty cycle'. What does that mean?
- Keep forged 347 or build iron 6.0
- Boost reference FPR base pressure
- To hell with n/a!!!!!!!!!!
- 233/239 cam for turbo
- 317's on LS1 For Boost!?!?!??
- Lookint for boost gauge
- 3.08 or 3.50's?
- HX52 turbo
- Ways to keep AC?
- Belt size for ECS bracket, D1SC with 3.2 pulley?
- installed meth inj.? some opinions needed
- Questions on a DD turbo truck project.
- 11.0 to 1 compression on 10lbs.
- turbo piping
- pusher fans
- LT1 FI tuner?
- turbo headers
- where do i get a quad guage pillar pod
- Crushed bent pipe ok for turbo piping
- Oil Pump For a 370?
- Belt PN for smokinhawk alternator bracket
- Pieced together a complete Procharger kit, 8-rib, FMIC, 4" Inlet for $2k :)
- best intake for my setup
- Boosted 6.0L guys inside please
- My Harlan 2-step not deactivating
- best comp ratio/build for a procharger 900+rwhp ???????
- Looking for a serpentine belt
- turbo/nitrous
- What injector whould you run??
- Retorque heads
- Pix please of your custom overflow coolant set up?
- 72 chevy project
- 317 head swap
- Where's the best Magnacharger kit?
- intake idea for my 5.3
- 60 lb injectors ?? Boost??
- oil cooler? who runs one
- Best place to get 1 3/4" stainless bends
- restrictor plates
- .82 or 1.06 A/R ... that is the question
- air to water IC ?s
- Up the compression and lower the boost or keep what I got??
- Those with a third gen and a turbo LSX
- speed inc twin turbo f-body kits
- Cam opinion on Procharger setup
- Magnacharger or STS?
- v bands leaking like a sift!!
- New Build for a novice
- Oil restrictor on a T67?
- Msd 6010
- Ebay turbo manifold
- Quick rundown on the Setup
- broke the clips that hold the MAP sensor
- IAC block
- fuel injectors
- PCV questions... car stinks like oil
- would this be enough fuel?
- f-body manifolds vs truck manifolds?
- procharged 346
- Please help!!! ASAP
- Boost spiking between gears.
- T76 feeding a TVS1900 blower
- Question on APS power output in 2 different cars
- vortech kit on LT1??
- warhawk vs afr or other !!!!!!!!!
- Any idea why this thread got closed?
- turbo from a supra in a...
- LMR 09 Challenger with Techo Supercharger!!
- Any C5's with exposed Front mounts???
- SC with cam
- getting no boost!!!
- AEM UEGO Wideband acting funky...
- thinking of going 4'' dump
- boosted 6.0 cam selection help
- Any APS owners running the Burkhart front bumper support?
- need some advice for a turbo setup
- Is this cam good for a turbo 5.3?
- Getting fuel to the turbo LT1
- which fuel pump?
- Good FI tunners in MD, VA, DE
- Where to mount eboost 2 in a camaro?
- Lets pick out some heads!! 408 iron motor
- Highest Boost a LS6 Manifold Can Handle??
- Turbonetics TC-76 Downpipe
- decisions, decisions...... need some suggestions
- anyone have a maggied car New Haven CT area
- It finally shipped!!!!!!!
- i know they are pieces of junk... but..
- Msd 6010 ?
- Billet tensioner with a centri?
- Mike Brown's best ET?
- Whats the quietest SC system?
- [PICS] Katech Performance Air Attack LS7 D1SC. 865hp/735tq
- harlan 2 step for sale
- Oil Pump Up Grade with rear mount?
- Help! Whats this Turbo for!?!?
- help with sts turbo needed
- Our NEW Set up from ....
- Help me pick some components to my turbo motor build
- Need opinions on this cam
- Intercooler Size?
- Turbo Info
- How would you do this
- Thrust bearing worn? what causes it.
- Kenne Bell on a Camaro? fab'd K member?
- Why an Iron Block
- boost control
- sts turbo
- lt1 procharger help
- Opinions Needed, 10.1 CR & Turbo
- changing Procharger F1 oil...
- 978 hp 1300 tq 496bbc with ebay T70's
- Forced Inductions Is The REAL Deal !!!
- heads for boost
- LS2 Turbo build - Opinions/suggestions
- turbo hose
- s400 to big for 5.3?
- DITCHING the fmu with my LT1 vortech set up?
- **TPE Kenne Bell Blown 434 LSX and Hannibal Lector Cam**
- Lmr cts-v!!!
- LF 6.1L FI info :)
- Rear Mount Guys
- Lt1 block + boost
- STS rear turbo exhaust leak...
- Another 1000 rwhp TT GT35R C6Z
- how much boost on stock internals
- a few newbie questions..??..
- TTI 70MM Street Build!!!!
- Where to buy MS 3.5" mandrel bends and flex pipes??
- Lt1 turbo
- Camaro SS F1-C Build
- Do I need a IAT sensor?
- AFR and Exhaust Leak
- Gets close to boost and sputters
- getting ready for the Tx Mile new best stock short LS2
- exhaust leak vs power?
- f1r procharger on an lt1
- How Much PSI-Stock Long Block
- boost psi vs head flow for 427
- Don't Overcomplicate it! Turbo kit install instructions posted ;)
- 11.2cr 370ci w/D1sc@10lbs frontmount intercooler
- Stock ls1- low boost what are the LIMITS?
- remote turbo hot pipe size?
- Truck manifolds...painted, coated, bare??
- must have supporting mods?
- PT101 compressor map?
- Bov spring???
- turbo cam
- bbc single turbo fuel injected on 92 and alky
- Oil feed?
- Mild steel versus stainless
- problems with the hp performance turbo kit.
- Twin GT2871R
- STS Turbo upgrade
- Tapping LS1 water pump heater hoses for plugs
- incon
- custom rear mount turbo kit
- Blower cam wtihout blower?
- S400 and S 91 size differance?
- FWD Ls1 Manifold..any pics?
- Turbo exhaust housing temp on rear mount..
- My 2009 Build for my Turbo 98 Cyber Gray SS with pictures
- Switching to a .68 AR
