PDA
View Full Version : Forced Induction
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 [71] 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228
  1. 1,870 HP so far.. New Texas Mile Build
  2. Methanol pre-blower results
  3. I'm stumped! Any ideas?
  4. Turbo rebuild..leaking oil
  5. Guess Dyno #'s
  6. Total cost of procharger for my car?
  7. procharger kit completion
  8. Aeromotive 13301 ok for my 5.3 twin turbo??
  9. s475 inlet elbow suggestions
  10. stupid question but i donno what supercharger i have
  11. which head bolts do i get?
  12. Straightline Video Novi 2500 corvette
  13. lots of questions
  14. Since the racecar is going away...need ideas for next project (street/strip sleeper)
  15. Huron Speed + 1999 Z28 Build Thread
  16. Around how much rwhp gain will I get with D-1SC on 8-9 psi?
  17. stock 317's or prc 317's?
  18. Can anyone tell me what size headunit this is? (Video)
  19. aluminum ls1 bottom end or iron 5.3 or 6L
  20. modifying floor to clear exhaust
  21. 650-700 whp LQ4 what turbo??
  22. How much would I gain from 317's?
  23. E85 with 83# injectors and meth
  24. Procharger Truck Inlet Issues
  25. 6.0 block power limits
  26. Critique my hotside, pics. Changes are still possible!
  27. Boost drop from 15-12lbs changing trans fluid?
  28. FMS F13-114LSA and FI
  29. Which is better 3.42 or 3.73 for Camaro turbo
  30. LQ9,LS3 Top End,GT47 80mm turbo build
  31. What is everyone using to tune their turbo setup?
  32. Turbo vs Prochrager
  33. engine knock- first time i ran to 6k with the turbo
  34. G body turbo manifolds
  35. Changes to D1SC Kit to Run an F1A/F1C?
  36. 390ci blown alchy injected pump gas. 6x tranny. Should be fun.
  37. Emissions legal reality check...
  38. critique my build and help me pick the right turbo
  39. 4.8 or 5.3 pistons?
  40. Over 700rwhp guys on E85
  41. LS1 Camaro Intercooler questions
  42. Is there any reason to chose a 5.3l over a 6l?
  43. Can You Make Your Own Turbo Blanket?
  44. 1971 stock 350 on boost
  45. Nitrous to Turbo Help
  46. Turbo guys please chime in!!!
  47. Anyone here from Chicago?
  48. Alky info needed
  49. Custom TT goat, stock motor/track times
  50. Anyone ever put turbos on a dual quad setup(or dual TB)
  51. Yay! My Kando turbo for APS kit is blown!
  52. Technical quetions for my custom procharger kit
  53. Blowing through converter or something else? "pic of log included"
  54. Procharger D1SC 8psi Question , Aster Bracket?
  55. running a turbo setup n/a
  56. ebay kit/ptk kit question
  57. Turbo blanket question
  58. Bov
  59. Can a Corvette C5 5.7L LS1 1999-2004 Magnuson Supercharger Kit be modified to fit a 2
  60. My CAI setup on a TC78
  61. t76 for sale
  62. Can a turbo car pass Canadian Emisions ?
  63. Stock 5.3 timing chain
  64. s475 t4 or t6
  65. We all know now that the Holley EFI has problems with boost. Now what...
  66. 4" Downpipe Through Stock K Member - Oval?
  67. Boost Leash
  68. Anybody With This Setup?
  69. Anyone stock prochargers
  70. Couple Meth Inj Questions
  71. anyone used?
  72. Painting over high temp ceramic coatings?
  73. Direct replacement for blown up Ls1. 5.3 or 6L ?
  74. Questions on what heads/forged bottom end on ls1
  75. Turbo LS1 Miata Dyno VID & #'s with COMP OIL-LESS TURBO!!!!!
  76. I'v got a question
  77. D1SC noise
  78. Holley Hi Ram Intake
  79. when in boost-timing retard
  80. 99 trans am ac complete removal!?
  81. Power steering relocation kit is FINISHED!!!!
  82. ?? oil pressure sensor??
  83. Tial Wastegate Rusts Shut
  84. Huron Speed FINAL Pre-Sale Special. Ends 3/17/12
  85. Cause for turbo thrust bearing failure?
  86. Help on turbo
  87. whats everyone runnign for an intercooler?
  88. turbo guys a newbie needs help
  89. recommendation for head gaskets
  90. My twin turbo shopping list....Comments/advise welcome
  91. Choices on new build hotside... Opinions welcomed
  92. Turbo guys-- I need some help
  93. Cooling setups on Boosted LS1 ? driven on the street
  94. lq4 or lq9 for a mp112 supercharger?
  95. turbo heads
  96. Cost, procharger vs. turbo
  97. down pipe size question
  98. Turbo 6 speed Fbody 1/4 Record?
  99. building lsx turbo headers on a mustang coupe, pics inside
  100. Open downpipe questions... who's running one?
  101. Are coated turbo headers less prone to cracking?
  102. Huron Speed Complete Single Turbo Kit SPECIAL! $2299
  103. need advice on runnin hvy springs and solids
  104. Speed Inc 1579 HP Vid added
  105. cam suggestions
  106. how screwed am I? crank pin fail
  107. Big turbo build advice
  108. 67 Nova TT build
  109. 5.3 lqx Iron blocks Strenth question
  110. D1SC procharger got quiet not sure why
  111. Burkhart Chassis Tax Sale
  112. LSA swirl wing. Effects?
  113. Another cam question
  114. what size and where to buy a turbo?
  115. gt500 supercharger on a 5.3L
  116. two step with auto?
  117. who makes Up and forward turbo headers for 4th gen camaro?
  118. boosted vaccum sources
  119. Manual vs Electronic Boost controllers...
  120. Need help???
  121. Local turbo for sale, need quick advice if good for my build
  122. These should make some power!!!!
  123. Engine Gridle
  124. Need Help With Head Selection
  125. Spoolin performance altenator bracket
  126. How much HP difference 317's vs. L92's on a turbo 6L?
  127. anyone recognize this car?
  128. Water/Meth kit trunk mount. Will this be track legal?
  129. Cylinder charge temp bias with meth injection
  130. Where are you mounting your A/W Tanks?
  131. **LMR Drag Radial Car runs 4.66 in testing**
  132. 9.52 @ 144 Stock bottom end LS6
  133. Lt1 p1-sc?
  134. New dyno numbers with AFR225, XSPower catback on my single turbo ZO6
  135. Cam question. F13 and lm7
  136. Fairmont 2.0 (forged lq4, s480, 800whp, under new management)
  137. tsp 231/237 112 lsa with vortech?
  138. torn on turbo selection for my 408 build
  139. Confirm 98 OEM Fbody stamped steel manifold material.
  140. PCV/ Catch Can help please.
  141. Turbonetics turbo identification
  142. Boosted break in question
  143. Ls6 vs Tu1 cam in a 5.3 how much am i leaving on the table...
  144. crossover / merge pipe
  145. Mounting turbo to frame
  146. AI/trex to procharger? what cam should I get
  147. E85.... Thinking of trying it out.
  148. Boost referenced regulator question
  149. Truck Manifold Flanges
  150. Turbo LS6 Cap Walk?
  151. Street car, pump gas, what fuel pumps?
  152. budget junkyard 02 lq4 TT for roadrace build
  153. Critique my Twin Turbo Plans Please!
  154. Ls9 vs ls2 turbo head gasket?
  155. Who has used LSA exhaust manifolds?
  156. Air to water plumbing
  157. Question about tuning before startup
  158. Want to build a turbo header
  159. Got my procharged camaro tuned!
  160. Supercharger = Insurance Dropped?
  161. Using PE Adder vs. IAT as safe guard for meth failure?
  162. Truck manifold placement question
  163. Would like to know about this Precision turbo.
  164. How much power will ID1000 injectors support in FI.
  165. lt1 style trans am intercooler size & location?
  166. air to water cooling question
  167. heat transfer
  168. LT1 Blower sizing
  169. procharger f1r
  170. s475 choking out?
  171. Website feature on my single turbo C6 !
  172. Help building custom rear mount system
  173. Build 347 or 370 for pt7675
  174. Catch Can setup with single plane manifold
  175. What gears??
  176. Comp Oil-less CHRA upgrade for APS kit.....who is interested?
  177. Wow...talk about a sleeper!
  178. Explain Meth is it safe + dependable
  179. Anti surge compressor housings yea or nay?
  180. Nasty BOV for D1SC video inside...
  181. Which Borla XR-1 muffler? F-1A/408 setup...
  182. D1SC issues just after install
  183. Exhuast is way too damn loud.... power loss?
  184. pics of my twin turbo hot pipes for a lt1 camaro
  185. gt91 408 cnc ls3 heads hows this cam look
  186. Plug gap
  187. Anyone build a turbo kit with stock fbody manifolds???
  188. Built LQ4-Will it handle 20#+?
  189. best coating for mild steel tube headers?
  190. pressurizing a carb
  191. Meth vs Nitrous
  192. Question re: STS Turbo and Muffler Setup
  193. Procharger guys with truck hat come in
  194. SPA turbo gasket eliminator?
  195. Magnuson MP112 on ls 4th gen fbody?
  196. turbo lq4 electric water pump question
  197. H/C/I/E to FI
  198. NEED HELP!! Twin turbo 70 chevelle build
  199. should i turbo a 210,000 motor
  200. which turbo should i get
  201. Tips on getting spool time down?
  202. What will it make? 370 - F1C - E85 - lots of other stuff!
  203. CBR alternator bracket
  204. Dagger GT?
  205. Zirgo electric fans
  206. MP112 Cam?
  207. Is this turbo to small
  208. twin turbo ls1 question
  209. Project "Ricky Bobby"
  210. **LSX Drag Radial Racers get READY, LMR IS winning championship this Year**
  211. Turbo in a high hp manual car an issue??
  212. Cam for T6 88mm on 346
  213. what cam for boost?
  214. What heads are you running on your procharged setup? 12+ psi
  215. 1995 Steeda Q car gone to the dark side
  216. Cam Specs with complete I bought. Advice
  217. Question about catch can?????
  218. Vortech V1 kit no mounts or crank pulley....
  219. Help me identify my new turbo
  220. Stock LQ4 76mm turbo questions
  221. Turbo build cost?
  222. Carb Hat or Carb Box ? Blow thru set up
  223. 317 heads help
  224. Piston ring gaps for 76mm Turbo LS6 - Need Clarification & Opinions!
  225. speed inc tu2 cam
  226. p1sc 5.3 blazer
  227. Ebay Turbo, any turbo set-p for sale
  228. Another E85 thread
  229. removing starter with APS kit
  230. Super chiller
  231. **LMR ZR1 Corvette 9.47 Vid**
  232. How low is your filter?
  233. front mount install help
  234. Turbo header
  235. any way to test seals on a d1sc?
  236. LSX 434ci | TFS 245cc | Viper T-56 | SP Tubular Headers ***WHAT GARRETT TURBO*** ??
  237. How much timing are you guys running 93 with Meth able to run?
  238. HELP will this boost controller work?
  239. st80 turbo on a 5.3 motor
  240. Procharged 408
  241. fuel pressure regulator and boost
  242. Headers or manifolds for turbo?
  243. how is boost limited on a whipple?
  244. Anybody have a 9/16 Rotabroach?
  245. proflo vs ls6 turbo
  246. Holset HX40 for Rear Mount LS1 RX-7. Good size? Compressor Map Inside...
  247. remote mount and intercooler
  248. No 9 sec FI M6 car out there ???
  249. TBSS TT,PTE 6766, 385ci, AFR 225cc
  250. HOlley Hp Efi and Boost with Stock Coils... Problems?
