- LS3 supercharger
- is 49psi at WOT with STS normal?
- Couple of STS Questions.
- Some good info many people don't know about ...
- Will my combo make 700RWHP
- How many High HP(1000RWHP) are running a Bottom end Girdle???
- Compression help!!
- Another ebay build
- New turbo arrived, is this normal?
- Anyone have STS instructions?
- What is a safe FI tune?
- Scooted to an 8 at Bristol today.
- what is the biggest plug gap with stock coil
- Is this gonna be a major problem?
- Flanges for truck manifolds?
- my C6 Vs Zo6 ( stock )
- Final Race of year, New PB -- 9.88@140.86
- my c6 magnacharger Vs R1
- powdercoating coldside
- Forced Inductions Turbo Stress Test
- How mush boost?
- what size turbo?
- Breaking up at 6k,do coils go bad???
- HP LOSS with FI?
- Magna Charger Worth Puting On A 408ci
- Stock bottom end LQ4 goes 5.72@126 1/8th
- When is spark blow out an issue
- F1R intake question... Keep the FAST?
- Wideband/Boost combo gauge?
- tt ls2 408 Chevelle
- Vendors for tubing/flanges for turbo build
- Late Model Racecraft at the Shakedown at E-town in New Jersey!!
- intercooler that fits between foglights
- Use a truck manifold for an LT1 turbo build?
- afr225 /370
- Paul Major Sets LS DR Record
- Procharger Race Valve (open) question...
- Made my NHRA license runs, best 9.21 at 153.96mph plus turbo thermal tests.
- 408 WITH A Magna Charger RADIX ?
- paxton sn2000 or edlebrock e force for a sbc
- ST80 back at the track again, improved my times
- Truck manifold?
- Sts Afr?
- Another aps build happening now..
- Sponsor/Builders/Installers....Want some more work soon ?
- What size silicone for stock TB
- Weber Racing Equipment New Shortblock and Freshen Up Program
- Changing setup's, OFI S85 kit is for sale
- upgrading from incons to a custom twin turbo setup...
- Engine Noise - Part 2
- Yank py 3400 e or sc 3400?
- Stupid Idea or Possibility
- Catchcan help
- Compression
- what internal wastegate turbos to go with?
- Carb cleaner in turbo?
- Anyone have any gm diagrams for taking off my front bumper cover and all that stuff..
- 10.3 @152 Speed Inc. APS Twin Turbo ZO6
- New LSx 427" shortblock done, TFS 6-bolts or ET LS7 6-bolt heads
- PSI on motor
- how much is to much boost for this compression?
- Turbo guys: used oil analysis (UOA)?
- Best valve spring kit?
- Vacuum/boost guage
- 3.5" v-band and misc couplers
- Ebay kit questions
- map on back of fast 90 intake does boost leak out of it ?
- So anyone tried the new aps intake ducts yet? Any higher boost dyno numbers?
- Vortech Supercharger/92mm FAST Intake/TB, 100mm TSP MAF, Tuning help needed!
- Tuning ? for LT1
- Bad turbo Help!!!
- 3 bar map and can I still run my maf for awhile.
- how far can it go?
- high(er) compression
- which size head gasket
- you hi HP guys running a 4l80e please read
- Noobie Help turbo decision
- How loud is an open downpipe?
- procharged 2002 ss on corn
- Cam size
- Where to find Clamps
- Dynoed 1170hp/1180ft/lbs today.
- Stock Turbo LS1
- EPP blower cam idle vacuum ?
- new Project F1C
- Reverse F2 procharger kit?
- daily drivers... how much boost ya running?
- Boost gauge troubleshooting
- Finally got the LSX running!!!!!!
- boost leak test question
- having a few issues can someone give some advice
- Comp. Ratio for this boost application...
- tial 44 wastegate to small?
- procharger APS TT NOVI
- Congrats Tiago! GM High Tech cover
- How Much Meth Are You Runnig
- Meth pre-turbo and after
- Anyone with OFI kit
- overheating with a procharger
- Still confused about PCV
- Help! Turbo car car keeps cutting off under light acceleration
- Broke my PTE GT47-88 (pics added)
- 2600 a good price for used procharger?
- Recommend me a lumpy idle turbo cam
- EWP: yes, no?
- turbo setup
- Who has a F3 procharger with gear drive on a 4th gen?
- Engine Noises...
- what is a good manual boost controller
- procharger p1sc oil help
- My A/w Intercooler Pic .
- ATI ProCharger D-1SC EPP complete kit prices
- KYTP S91 Heading to Kuwait
- a quick vid before the mile
- Longer radiator hoses?
- which supercharger?
- turbo 76mm
- Track results TC 78
- Rear main seal..more questions..
- The story of Longrange4u's FI..
- Finally got it 9.97@138, Remote mount S-10
- Turbo Timer Install
- APS F-Body kit question?
- Exhaust
- Hey guys, new to the section!
- Thoughts on why #5 and #7 pistons have chunks missing?
- F.I. tune
- What does the damage look like from small ring gap?
- APS TT, Hooker ORY, and emissions???
- putting a tc76 on my s10 some ?'s
- LSX S-10 Procharger question
- Trans Brake 2 Step
- Some more track passes on the rear mount ST80
- Magna charger for 2001 f-body question
- Nitrous On a Turbo car
- chrome downpipe
- parts starting to come in
- how much boost
- Where To Buy Parts For 6 Rib To 8 Rib Conversion?
- ls1 mani's
- Fmic overkill?
- mild t6 flange to stainless tubing?
- best FI I've seen
- Who can spec a kickass cam for my LT1?
- Procharger Guys!
- Plugs and wires
- HKS EVC boost controller
- Turbo Question T88H-38GK
- Supercharger set up... what does it consist of?
- looking to turbo non ls1 need some pointers
- Turbo + LS1?
- How To Determine Procharger Rib Pulley?
- NGK 8's dumdumdum or TR6?
- To procharge or not?
- Intake dilemna
- Intercooler water tank..what size
- So whats the deal MP T76?
- Is my buddy getting scammed?
- Watesgate options?
- APS Stage 1 to stage 2
- redid my intercooler water system for cheap
- DYNO RESULTS EeBAY TURBO KIT Z06
- APS on an LT1?
- stupid or not
- 106mm or 91mm
- New Numbers, 11lbs D1sc + Meth+SD
- Forced Inductions.com
- Why not use variable nozzle turbos on rear mount STS kits?
- Revised sts..nice.!
- AMS-1000 Version 3 highlights
- Husky (Home Depot) Oil/Water seperator???
- Even more ST80 2 Step testing, with good info for 6speed users too
- LSX Miata Rear Mount Turbo Plan
- Slp oil pump which spring..?
- Has anyone built a self contained oiling system for a Vortech?
- Rear main seal question and FI.
- Fastest Drag Radial V8 Car
- F2R Rebuild
- Gt2876
- tial 60mm gate issues
- Twins????? Turbo guys please help....
- WG piping size
- Orange Turbo Car
- cooling problem HELP!!!!!!!!!!!
- Best Twin Turbo kit for a C6Z06 corvette?
- TC 78 Limits?
- Who wants to build me an FI Motor
- Hey guys a friend of mine has a vortech just laying around his shop!
- STS Turbo Kit Question
- Rear mount closed oil system
- A/F guage?
- 6.0 T-76 turbo setup
- What's needed to hit 450whp with an STS?
- ????????????? STS Oil Return Question ??????????????
- Procharger mounting bracket????
- Turbo question
- Turbo Kits
- 800+rwhp turbo guys come in
- Twin GT35R's vs twin TC76's info inside...Dr.Turbo?????
- Oil drain question.
- The Build
- 2 bar map pig tail
- under powered?
- VACUUM question
- Intercooler questions
- LS1 in a Dragster, Thinking Supercharger..
- Use Snow meth injection controller as a Hobbs switch?
- 402ci, GT5533r, 6 speed. BOV/wastegate ?
- coating
- STS dealers?
- Got the Turbo and the A2W IC mounted
- The MP T76 has arrived!!!!!!!!
- ? blown head gasket
- First race with my Nova-62
- BS3 car dropping passenger side bank
- Virgin Turbo Passes
- is garret 60mm to small?
- ATI Twin ICs - Move to front side by side?
- what gears should i run 6 speed turbo???
- NEED HELP with Vortech V-9 rebuild please
- Advice needed... very simple questions
- oil drain scavenge pumps
- where can i find 14 gauge mild steel bends?
- W2A Intercooler question
- APS cars with 402+ cid how much boost?
- Not Bad, 300 RWHP From a Tune............
- FI t/a's from illinois come in...
- Twin Scroll turbo on an LSx?
- 930 rwhp is it possible with this setup?
- Alternator Relocation Bracket That works?
- H20/Meth injection question
- Breaking up a little after pass...
- New best, got a couple questions.....
- I got Robbed!!! 10.01@143 / 76MM Remote Mount S-10
- 383 iron block stroker? Advice
- New best 60 foots :)
- Procharger (d1) how often should i check the oil?
- 151mph shakedown pass on the new Speed Inc TT kit.
- white smoke
- Magnacharger Guys - Can you help me troubleshoot?
- 42 lb injectors small
- TTi Race System v.Build up, Ryan K
- Quick turbo question?
- Twin GT42R GTO 1/4 mile shakedown... advice!?
- AEM TRU Boost Controller
- Turbo Technology v.60-1 LS1 Street System
- Late Model Racecraft's Magnacharged C6 Dyno Vid!!!
- Turbo size
- APS TT G8 - 553rwhp - PICS and DYNO!
- SDCE problem
