View Full Version : Forced Induction
  1. Exhaust restriction on a supercharged car?
  2. Procharger "J" bracket Studs
  3. I finally got my new turbo!
  4. ceramic beads=turbo death???
  5. MLS head gaskets w/98 heads - any issues?
  6. TT STS ZO6 Overheating problems!!! Help
  7. D1sc Install Manual?
  8. sts questions
  9. v-2 took a $h!t
  10. Question on B.O.V.
  11. Forget STS this is the rearmount you want!
  12. APS Stage 2 Kit
  13. Solid mount or no?
  14. Just a little heads up for some....Clutch
  15. 98 stock block & heads - what head gaskets for D1/8psi?
  16. Twin 61mm, A/R .63 too small on a 408?
  17. Intercooler/cold side pipe size
  18. Turbo Question
  19. My custom alternator relocation bracket (with pics)
  20. 6.0L limits
  21. are ebay oil inlet flanges ok to use?
  22. Anyone here use Heet?
  23. Turbo blanket - necessary?
  24. Just built this Custom FMIC
  25. Selling an awesome turbo for those interested
  26. What size turbo for 4.8L?
  27. Made some more progress on the car...got 8s?
  28. ATI/Procharger BPV Race Valve: What's the difference between open & closed?
  29. Need Y-pipe for APS kit: Jet Hot fits Hooker and Hooker fits Kooks...
  30. Ls7 Clutch with procharger
  31. C6 vette procharger question
  32. [Meth] -- How To Fill Up Your Tank Without Spilling
  33. Update: 2008 Z06 + F1C + Warhawk = .......
  34. vertical radiator
  35. question on turbo kit on ebay
  36. oil feed and drain line sizing and a restrictor?
  37. Trying to sell hotparts for a TT lt1 setup
  38. GMHTP Covers Late Model Speeds LS1 F body magnacharger kit
  39. high psi with ARP studs
  40. Procharger Bypass Valve Noise!!!
  41. next step colder than tr6 plug?
  42. vortech v1 for ls1 question
  43. open flange on divided turbo?
  44. St80 Results Inside!!!!!!
  45. whats the catch?
  46. The Best Forced Induction
  47. vid
  48. turbo GTO pic and video
  49. Cam Choice/Advance Question
  50. Late Model Speed F-Body Magnuson Kit
  51. Phamspeed kits any good?
  52. cant get the exhaust that feeds the turbo to clamp together?
  53. Check out this BAD ASS TTTA
  54. Horizontal intercooler?
  55. Tips to launching a 6speed turbo car..
  56. big 88 single + 402 99% complete pics!
  57. D-1SC + Cam
  58. gasket thinkness
  59. Thanks to Bob and the EPP Crew!!
  60. 1570 rwhp !.... gotta love some people...
  61. cogs....and tensioners. 2 topics
  62. Late model speed.
  63. 403 C6 & F1C Belt problems!!!
  64. belts
  65. 01 WS6 STS blowing off oil cap
  66. What charger to go with????
  67. How do you pick twins?
  68. Looking to Procharge my Cammed 346
  69. Heads/Cam for twin Turbo
  70. At what point does the supplied BPV need to be changed in a Procharger kit?
  71. boost referenced FPR?
  72. Where can I get an LS2 2 bolt ehaust flange?
  73. the s/c noob rebuild thread
  74. Big Thanks To Kp!!!!!!!!!!!!!
  75. what cam to choose
  76. Turbo blanket
  77. T4 flange feeding T6 turbo( BOOST PROB)
  78. Wastegates and BOVs
  79. meth mix with nitro?
  80. fuel pressure ?'s
  81. how much am i hurting myself
  82. finally got my aps car to the track
  83. LS1 Turbo - only boosting from one head?
  84. what size tubing fro crossover?
  85. heads and cam
  86. Griffin Radiator install
  87. Stock LQ9 long block goes 10.66@139.83, 3950lbs. Video.
  88. 1000 dollar turbo kit?
  89. first turbo car!
  90. here is my project
  91. Couple of questions
  92. updated pics of my heap
  93. T-netics new GTM-78 Pics....
  94. LSX block with F1a?
  95. Procharger plenum cracked again...
  96. Retarted question about TT
  97. APS TT Cam?
  98. Supercharger belts cheap?
  99. My new Y pipe for the butt mount
  100. My new intercooler. Pics!
  101. Quick Question?
  102. looking for a good combo
  103. 403 and D1SC Pulley combo for 12 psi.....
  104. Going To Manifolds For STS Need Help
  105. How do I cut the T/A bumper cover
  106. Moving Turbo up front...thoughts?
  107. Ready to forge my 346 what can I expect out of my d-1 and gt3 cam.
  108. Benefit of a 4" FMIC
  109. C5 Twin turbo build
  110. corrugated heat shields
  111. Which Diamond Pistons Should I Get?
  112. Got my turbo, now what size wastegate?
  113. D1SC F1A sound clips or vids
  114. front mount intercoolers..
  115. supercharger for LSx s14? which 'kit' will fit?
  116. LPE 2 Step
  117. Plugs and gap?
  118. OFI on '98 T/A at EPP
  119. Clocked to 4-4:30
  120. no breather
  121. At what power level has people pushed water with a 4-bolt setup?
  122. help wiring Harlan 2 step into clutch
  123. Exhaust for turbo
  124. 700 rwhp goal?
  125. help me identify this turbo and whats it worth...
  126. TT + 8.50 safety gear + all factory options = heavy.
  127. I don't like the sound of my BPV....
  128. Drive before tunning question
  129. okay a friend has me paranoid procharger and new cam
  130. How does this look for a build?
  131. start up of my APS build
  132. Going F/I?? forged low comp LS7 shortblocks $5,995.00
  133. What rings are you guys using?
  134. Anyone have a oversized 6 rib crank pulley
  135. boost limits on 93 octane
  136. Need some help pls
  137. Extremely Bad Night
  138. D1sc in my 3rd Gen with a LS1...
  139. Sell existing LS1 for new boost shortblock, or build existing one?
  140. Boost+Meth. Any reason for 100 oct. ?
  141. Tom Snitzers 402/F-1C/ 804 rwhp with 15.9 psi
  142. OFI - Resolutions
  143. F1a or D1sc
  144. 222/228 115+3 for turbo?
  145. Magnuson/Magnacharger/Radix
  146. Late Model Speed F-Body Magnuson Kit
  147. Supercharger Belt advice please
  148. LM Speed kit goes 545/550
  149. prochargers rock!
  150. virginia speed wheres it at?
  151. Round 3: 370 LSX Block Trans Am / F-1A Procharged / Est. 900+ RWHP (LOTS of PICS!)
  152. how should spark plugs look with meth injection
  153. Sudbury C5's F1C dyno results
  154. What do I need to sell for FI
  155. header wrap turbo?
  156. Going new direction...Boost
  157. SDCE tensioner setup and power steering cooler
  158. FI and engine stroke???
  159. Lots of smoke ??
  160. C6 Manifold kit - Hot parts
  161. Intercooler
  162. GM6 Turbo from diesel....Cheap FI?
  163. cutting radiator support to make room for intercooler pipe
  164. Controlling boost. Stock bottom end
  165. Filipowski with Uratchko Power goes 197 at CSCN
  166. engine combo
  167. Magnacharged 2002 z28
  168. sts or rear mount have serious question.
  169. LS-6 Block with a Turbo
  170. boost vs pump gas??
  171. not an LS but still pretty cool
  172. 2 Step and Auto
  173. Squires Turbo Systems
  174. Which block ?
  175. FI98X Transam 1/4 mile runs...finished my license runs...
  176. Supercharged /NOS/NA
  177. texas rearmount turbo?
  178. TT GTO Shakedown 1/8 passes
  179. FI LSX block machining costs?
  180. How will my car respond to 5-6lbs? |procharged fbodys advice, please!|
  181. 3 bar map
  182. APS T/A Vids
  183. sts oil fill cap update
  184. turbocharged guys with powerglides shine in
  185. who has the lowest ET on a stock cube car??
  186. Moving STS oil return line to pan; what fittings do I use?
  187. intercooler mounting
  188. whats the difference in a turbo cam and a blower cam
  189. No LY6 Turbo'd Users?
  190. Who's had the biggest ???
  191. World's Fastest C5 Vette??? Part 2
  192. APS TT Tubing Problems
  193. Hello, and My First Question(s) Posting....
  194. 3 bar map
  195. OKAy guys what am i doing wrong! No boost on my gauge!
  196. First runs of the FI98X setup
  197. vortech question
  198. Intercooler core
  199. turbo and altitude witch one?
  200. who is running Twin GT3582R's.. have a few questions
  201. Sticker Dude to the Rescue
  202. i need a fmic for a c5!!! got any pics?
  203. Ais?
  204. intercooler size?
  205. need help with pulley sizes
  206. Which WG for S91 turbo???
  207. Gen TTr numbers are in for the Goat
  208. pt91.5
  209. highest fuel pressure
  210. Wideband and Boost controller are ther any?
  211. Tune for 5psi?
  212. new 396 motor
  213. Late Model Speed in G.M. HighTech Performance Mag.
  214. aftermarket blowers on ZR-1??
  215. ofi radiator mount
  216. OK Dumb electricle quest. for boost light
  217. APS and Knock sensor
  218. Procharger? Or, third gen Camaro?
  219. o2 sensor location?
  220. Iconel/ titanium valves?
  221. SC Parasitic Loss vs TT
  222. front mount
  223. LT1 Eaton M112 dyno and site update!
  224. ls2 stock main caps how much power can they hold with arp studs
  225. vortech s trim questions
  226. procharger proflow valve
  227. NINETRES = worst luck ever!!!!
  228. Running off of wastegate only?
  229. Update on our EPP GTO race car
  230. looking to procharge the 408
  231. APS Camaro. Hp loss from single cutout over dual cutouts? Cats?
  232. Blown head gasket?
  233. c6/truck manifold setup question
  234. Quick question on external Fuel Pumps (which one of mine is better)
  235. Who sells me a nice converter (LS1 turbo)
  236. Got some parts!!!!
  237. when does boost hit?
  238. Twin turbo LS7 in a 34 ford 3w coupe
  239. Was bored Saturday so took the car out for a few passes..
  240. Just dynoed my TT ZO6
  241. F-body Procharger users......overheating in traffic?
  242. What motor oil (weight) to switch to after goin FI??
  243. this filter for ati bypass and hat?
  244. Turbo pipes melted the High Pressue Power Steering Hose =/
  245. 1000rwhp Warhawk + TTix build
  246. SEARCHED AND CAN NOT GET A STRAIGHT ANSWER c6 manifold ?
  247. Long tube headers
  248. larger air filter 4 stock d1sc
  249. Twin Turbo... Turbo Size??
  250. BBC Ignition
