View Full Version : Forced Induction
  1. what stock LS1 cam is better for turbo?
  2. ok to hook up wastegate/boost gauge at port behind intake manifold?
  3. HHR SS Turbo and intercooler
  4. crazy idea of mine for boost...
  5. Ford GT TT setup we are doing
  6. My Incon turbo kit and other parts for sale
  7. TC78 Goes on Mustang dyno today!!!
  8. What PSI spring are you running in your Turbo BOV?
  9. Aps !!! Stage 2 Kit ???
  10. Thinking about going with an STS turbo kit
  11. 187mph with 85mm inlet turbo
  12. Smokinhawk Bracket,i Cant Find A Belt!!!
  13. Looking for any Broken Wastegates and BOV?
  14. ProCharger Tensioner for D1SC
  15. 9" soon... Procharger gear ratio???
  16. Some pics from around the garage....forced induction friendly
  17. turbo ws6 project
  18. single versus twins
  19. identify this turbo
  20. TRT coupler split
  21. Good luck to Mike Brown in NMCA T/S
  22. Turbo oil return flanges
  23. Critique my return lines....
  24. high altitude turbo suggestions
  25. lookin for a scavanger pump, whats the best?
  26. Anyone with a broken Turbo?
  27. sts oil scavanger pump question
  28. Went to the track with the new setup, have some ?
  29. 346 Forged Ready For Boost Where do i start?
  30. AMS-1000 Boost Controler
  31. Just dyno'd with new blower
  32. Scavenge pump users, click here
  33. New FI-94X is going to the track....revisited.
  34. TT rear mount question
  35. Minimum acceptable clearance between alternator pulley and blower pulley?
  36. Advice on Engine...
  37. Oil smoke on decel after boost
  38. Thermostat Rec. On Supercharged Cars?
  39. ?'s dual ball bearing vs traditional journal bearing
  40. Turbo 6.0 ???'s What heads?
  41. gto procharger upping boost?
  42. Cam Experts Please (Degreeing my cam)
  43. Vortech V3
  44. 3.8L Turbo Guys
  45. Intercooler piping, Is there a Benefit
  46. Hot side tubing size?
  47. What wastegate ??
  48. Stock long block Lq-9 makes 825/847 to the tires!!!!
  49. waste gate springs
  50. PTK Belt routing
  51. Which cam for a 402 with at 16psi
  52. who uses a launch controller?
  53. What to do about tuning?
  54. Have a inspection Comming and need cats to pass
  55. anyone run a BW S475? pics? dyno?results?
  56. SC gearing compared to Turbo gearing
  57. Oil leak from D1SC Procharger?
  58. Mustang Dyno Results
  59. How to secure turbo blanket?
  60. Fans for Griffen Radiator and Twin Turbo
  61. What magnacharger tune looks like?
  62. kentucky turbo build pics
  63. are there any advantages to polishing?
  64. Pros/Cons of T56 VS Th400 in a turbo car aka, why T56 turbo cars suck.
  65. replacing my lifters what to get?
  66. Boost question
  67. Rear Twin turbo Z06
  68. Supercharged guys-Cutout question
  69. Twin Turbo ZO6 by Speed Inc.
  70. where to get the steel procharger bracket?
  71. Plug gap ?
  72. Oil in downpipe....Heerrreee weee gooo..
  73. A2A or A2W on FI set up?
  74. F1C procharger impeller speed
  75. Procharger pinning kit with Eagle crank??
  76. well is this true about procharger?
  77. 500-550hp lq4 truck manifold setup
  78. procharger causing oil leak?
  79. NGK TR8 vs. gasketed plug
  80. STS Turbo system Intake question
  81. need more boost
  82. Prosport Gauges.Anyone running these?
  83. Auto turbocharged vs. Manual turbocharged
  84. New BS3/turbo setup won't start
  85. 3" Blow off valve Piping. W(here)TB?
  86. Underhood heat
  87. all verticle radiators come in!!!!!
  88. LT1 boost questions......
  89. My setup
  90. How much rwhp should I expect with my setup?
  91. Got it fired! Now a fuel pressure issue...
  92. adjustable alt. bracket for a truck manifold set-up
  93. new edelbrock cam good for a turbo setup?
  94. Another one bites the dust!!
  95. twin or single
  96. what size wastegate?
  97. Fi 94x Billet Build-up
  98. SBC turbo motor got one?
  99. Turbo freaks come in for feedback....
  100. p600b procharger help.
  101. Short video of my Magnacharged Trans Am
  102. Does a 10lb spring on a 60 trim equal 10lbs on a T67?
  103. Advanced look at BLOWER SPEED
  104. Lets see some front mounts!!
  105. FMIC On dumdumdumdumdum
  106. i got a FI Comp Cam and have a quick question
  107. How much boost are you guys running on stock short block w/6.0 heads?
  108. Best Fluids for Forced Induction
  109. APS BOV's removed
  110. APS PCV system... problems?
  111. Plug & Play harness for ATI Procharger fans
  112. Wanna see a 300+ft Long Wheel Stand
  113. thinking of trying race gas over E85
  114. My buddies whippled cobra*VID*
  115. intercooler?
  116. Yet another PCV thread
  117. Procharger Diaphram
  118. What brand intercooler is the best?
  119. Paging Turbo Gurus
  120. procharger 6 rib falls off
  121. Blow off Valve Flange
  122. I gotta pull tranny on my APS Camaro
  123. tial wastegates on ebay?
  124. single front mount
  125. Velocity stack with a screen ???
  126. Turbo Rebuilds
  127. Are exhaust cutouts worth it on a turbo car?
  128. Burkhart now carries Chiseled Performance Intercoolers
  129. Drove car for 1st time since removing turbo
  130. LS9 Build Video
  131. Any feedback
  132. Precision PT8047 turbos on sale
  133. intercooler
  134. Ontariovette's 427 F1R build up: UPDATE!!!!!!!
  135. EPP ProCharger Prices
  136. ATI Procharger D-1SC Kit
  137. How far are you supercharged going on the maching of the block??
  138. Please can you read this map for me?
  139. I need a CHECK VALVE, which one?????
  140. 365" or 403" LS2 with T-Trim?
  141. blowby with sts...poss pcv issue?
  142. 106 turbo questions
  143. Max boost with Stage 1 Incon kit??
  144. looking for detailed frnt mount intercooler pics
  145. MAF or SD tune? which is right for me?
  146. Wiring help.......adding 9 inch spal to procharger shroud
  147. APS kits, lets hear its downfalls (if any)...
  148. dumb turbo question distance vs spool time
  149. Turbo setup nearing completion
  150. LMR Custom Twin 67mm Initial Start Up Vid!!
  151. Anyone w/ Maggie or KB running Meth?
  152. Uh, so..which charger..which cam?
  153. friend wants turbo
  154. So many ways to go...
  155. Not the best way to start the day.....
  156. it's coming....
  157. APS kit: Spark Plug Gap and detonation/gas mileage
  158. 95 turbo TA inj. pulse disapears at 4,800 once warm
  159. building my own sts kit??
  160. Holy crap - check out this video
  161. YSI 383 combo pully size and ect?
  162. Anyone using total seal rings w/ chromoly top ring?
  163. New Hardcore Parts are Ready!!!!!!!
  164. Need a Recommendation for Spark Plugs
  165. Which spark plugs for boosted e-85 car.
  166. APS TT 92/92, Vic JR or GM performance
  167. whats the biggest bore on LSX block with FI
  168. 408/PT98/Six Speed Build
  169. Are TR6 plugs available in Platinums ?
  170. gt47-88 with .69 a/r???
  171. just wondering???? sts exhaust pics
  172. My 408 iron block, GT47-88 build.
  173. Is There A Whipple Dealer In The House?
  174. what rearend/tranny combo are you running on turbo cars??
  175. PART NEEDED Silicone Reducer, 90° bend - 4.0" to 3.0"
  176. Procharger Fan Setup
  177. magnacharger + methanol + Nos
  178. aps turbo project underway
  179. Since its hot and my car dont run that well..
  180. Masterpower 2008 catalog link!!!!
  181. Anyone with the Ebay kit have a problem with the wastegate bolting up?
  182. Custom PT88-402LQ9 build pics!
  183. Forced induction timing and air fuel?
  184. Most Power From LSX TT setup
  185. Cam on stock LS1??
  186. APS intercooler, how well does it work??
  187. MAF delete hose for APS kit
  188. What ever happened to the HPS Formula?
  189. Doweled Main Caps
  190. Tires size and spool
  191. Plenum Box Exploded! (Procharger Race Bypass info needed)
  192. Possibly stupid question about a 2 step...
  193. 2 bar MAP
  194. new d1sc build
  195. OFI kit and aftermarket k-members?
  196. Its a STS kit? good luck making any sort of decent power
  197. Need 2.5" Merge to T4 flange, build or buy?
  198. Forged LS1 build?
  199. STS turbo Methonol kit info
  200. Dyno #'s for my STS set up
  201. need advice on turbo
  202. Belt length with SDCE tensioner??
  203. 6 to 8 rib coversion
  204. blow off valves?
  205. ignition cut out...on turbo car?
  206. 2000hp LSX Twin Turbo/STOCK CRANK
  207. Widebody Twin Turbo Corvette C6 (Turkey)
  208. Anyone running a Proparts boost controller?
  209. EvoByDawin's eBay build-up
  210. Interesting pics over on another forum....
  211. Stock motor + turbo + 93 octane..
  212. Head studs on LQ9 block...
  213. Redid APS inlet pipes
  214. D1SC Filter Problem.
  215. FI98X Initial Startup movie
  216. garret a/r 1.39 hot side - go or no go?
  217. Possible twin build - Turbocharger's physical size
  218. Exhaust diameter size?
  219. Rear mount guys. Has anyone thought of this
  220. my car falls on its face in 4th gear..Help
  221. For those that have asked about Turbosmarts new 50mm Gate....inside
  222. Cam for a S/C stock LS1
  223. torquer 2 cam and a procharger?
  224. motor and parts all came in!!!
  225. supercharged map sensor question?
  226. vortech T.Trim
  227. pics needed: turbo bracing
  228. Mild steel pipes
  229. supercharger swap
  230. Stupid Question: weight???
  231. VIDEO of Superchargered F-Body by MTI Racing
  232. Gen TTr Install Pics on 04 GTO
  233. Anti-Surge system?????
  234. What should I do about the Oil Return?
  235. Who else ordered the new tc78?
  236. Upgrade crank pulley to SFI Procharger /w GTO blower pulley, who makes one?
  237. Turbo Build
  238. Compression Ratio?
  239. will a MPT-70 .96a/r t4 fit the stock t4 sts kit
  240. MTI Racing F- Body Supercharger Kit
  241. High HP Guys Not Using BS3 - Knock Sensor Question
  242. building a 1300-1500hp turbo LSx ?'s
  243. STS tuning suggestions
  244. Quick question about OBX
  245. SI007 Cam for Boost
  246. Fitting a 106mm turbo...
  247. LSX, F2 in another mustang
  248. How do you STS guys feel about your kits piping?
  249. belt tensioner question
  250. Any Sponsors make a Radiator Relocation Kit?
