PDA
View Full Version : Forced Induction
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 [77] 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228
  1. Oil how to
  2. Front mount turbo with a/c almost complete PICS
  3. 3" vs 2.5" crossover pipes....LETS LAY IT TO REST!!
  4. Whipple in a camaro
  5. max psi on stock heads?
  6. 5.3l turbo build
  7. Stock Bottom 5.3 Selection for 15-20 psi - mileage?
  8. question about garrett 76mm
  9. ARH / Farks Supercars Wins the Gen 5 Class LSX Shootout
  10. procharger and tc
  11. 1500HP recipe drag only turbo build
  12. intercooler/cold side piping
  13. 2001 ss twin turbo build
  14. Who's going fast on 17inch or larger drag radial?
  15. spoiling twin t76s
  16. You guys are gonna shoot me: 95 Z28 V6 turbo swap
  17. change to turbo setup?
  18. Forced induction LSX need ignition box?
  19. Does Kenne Bell make a blower for the 98-02 Fbod?
  20. 9s with auto swap
  21. tial 44mm wastegate routing? help
  22. Shopping List for 2000 C5
  23. lq4 garret t76 need advice
  24. th400 converters
  25. So I picked up my CBR Twin kit this weekend...
  26. Ive out grown the bottle....
  27. Thinking of swapping out my Turbos for bigger ones.....
  28. Cam Selection Help
  29. So we DID NOT let out at 1100 feet
  30. Best place to Buy 2.90 Pulley?
  31. twin turbo and a 6 speed?
  32. procharger twin intercooler install
  33. where do I send my car for a custom turbo build???
  34. factory head choice, 15psi
  35. 799 head combustion chamber size
  36. Any one run a ball bearing turbo without water?
  37. procharger on stock rear?
  38. Uggh... Cam Help PLEASE !!!, LS3 Heads/410ci/m6/Twin 67mm turbos
  39. Need a decision...What would you do?
  40. Custom G8 GXP TT project
  41. Bearings bad?
  42. Blower Pulley
  43. Compund (series) turbocharging
  44. How to get LQ4 to 8000rpm semi reliably?
  45. Lack of power with ProCharger?
  46. which intercooler kit? help
  47. "Spool Vlaves"?? Lets talk about why and why not...
  48. maggie for 7-800 hp??
  49. Procharger kit from brute speed
  50. STS turbo for my setup? - Need to pass Cali Emissions
  51. cam for MP 122 maggie
  52. injector size
  53. **LMR TTG vs Hennessey TT Ford GT**
  54. What hp rating is the new turbonetic HP67's? how do they compare to the new precision
  55. What hp rating is the new turbonetic HP67's?
  56. What's the fastes stock cam and boost car
  57. Crane 224/224 .551/551 114LSA for turbo 5.3
  58. The results are in!!!! And I'm a VERY happy camper!! D1SC tuned! **Videos Uploaded!*
  59. APS TT C6 w/ upgrades
  60. Mixing E85 and pump gas thoughts
  61. BMR Turbo K-Member Group Purchase? Yes...
  62. Would this be a good upgrade for a 6.0?
  63. Question about mounting IAT Sensor, Depth. And why after meth?
  64. advice on two setups
  65. Stock zo6 procharged reliability?
  66. LS9 headgaskets ?
  67. Modular Turbo oil drain kicking my butt
  68. Hx55 questions
  69. Throttle body to fast 102mm
  70. Turbo questions on Trans Am
  71. 799/243
  72. Need CO2? Twin 6765's on 427 and AMS 500
  73. where to tap into for turbo oil feed line? steel pan not stock
  74. I may have High Exhaust Back Pressure Issues...
  75. carb or FI with TT setup
  76. Impressive A&A kit + Meth results
  77. Mass air flow Question
  78. Turbo MAF or MAFLESS
  79. turbo build questions, help, and advise
  80. Info on pinning/dowell the main caps for crank walk?
  81. help..another heads thread. aftermarket only!
  82. What heads to use for ls1 turbo build
  83. Wastegate help/advice
  84. tc78 vs st80 on a 370??
  85. STS or Custom??
  86. Anyone controlling meth with the eboost controller?
  87. What fuel should I use???
  88. Please help with injector size..
  89. AtomicFusion 2.0 Official Twin 88MM 2500+hp build Thread
  90. Draw through STS/remote mount turbo kit?
  91. Camaro s475 TURBO build.... LOTS OF PICS
  92. LS1 Turbo Build 69 Chevelle post your pics!
  93. turbo 5.3L fopxbody. post your pics
  94. Need help with parts for 370 turbo
  95. What cam for my turbo build? (List to choose from)
  96. PRC 227 Heads sell or use them?
  97. B/W S400-75 (1.10ar) T6 vs. MPT76 Q (.96ar) T4 for LQ9
  98. Check this out: Hose Candy
  99. FI guys, I need the "skinny" D1SC/LQ4
  100. Finally....getting a tune! D1SC. kinda nervous lol.
  101. Help needed- Procharger Air Inlet Hat
  102. is this kit worth it
  103. going to do rear mount turbo
  104. Lastls1-Speed Inc at LSX shoot out.
  105. ls1 350z turb0 feed help!!
  106. BOV no noise?
  107. Dose anyone have a part number for fan male connector ?
  108. Holset Ht60 turbo feed size?
  109. chasing a set of truck manifolds
  110. Front mount intercooler with AC
  111. Procharger/Vortech Maggy wanted!
  112. Coating combustion chamber and exhaust ports?
  113. Koolrayz Wild Ride
  114. Heads question.
  115. help me get hi figured out...trying to get a tune this week for my D1SC.. :(
  116. Any inexpensive T6 turbo's?
  117. ST80 347ci dyno number on 10psi !!!!
  118. BOV opens up as soon as I start the car
  119. So we let out about 1100 feet and hit the brakes
  120. Holset ht60 turbo. Any insight?
  121. Tried to put it on Kill (vid)
  122. C5Z with G5XB in n/a form
  123. 85mm maf to procharger inlet
  124. Need a 2.5 bar map
  125. lsx turbo sonoma track times
  126. Blown head gasket?
  127. Twin-Screw/Roots Superchargers
  128. 6Speed Boosted Guys....
  129. Twin Garrett T3/T4 .63ar 57trim turbos on a stock LQ9?
  130. Confused. Vented or sealed catch can?
  131. stock 5.3 F1A w/ brute speed cam. how much can it take?
  132. please help with turbo ls1 build
  133. Can i mount IAT Sensor in ls6 manifold? then meth nozzles in throttle body?
  134. Got it tonight!! 9.86@145.5 PT7875 Street Car
  135. log manifold question
  136. who here has maxed out an 88mm turbo t88?
  137. Supercharger wanted!! Vortech Procharger etc.
  138. Vengeance Racing Builds Synergy Green 2011 Camaro. Whipple/Cam/Fuel/Rear/Susp/Meth
  139. where did you buy your turbo from
  140. GT91 oil return flange????
  141. Turbo set up Idea?(just a thought)
  142. RPM 4L60E and a A&A YSi kit goes 160mph!
  143. Does this D1SC setup sound ok?
  144. Need help with cam size for a turbo 4.8
  145. 1000ish HP, smallest turbo?
  146. doin a really basic turbo set up...advice appreciated
  147. Want to Turbo LS1, noob but please advice would be Helpful
  148. Vortech YSi Installation
  149. t70, 4.8l 87 IROC. couple questions
  150. thoughts from LS1 superchager owners
  151. lq4 with 88mm t6,,,,cam???
  152. Help me pick out a turbo.
  153. Best turbo for a stock LQ9?
  154. Ever been attempted with 4th gen?
  155. Guys with procharged cars or QA1 coilovers, what front springs do you run?
  156. 99 SS D1SC with a lil show and go!!! lots of pics
  157. what kind of cam is good with a blower?
  158. LT1 D1sc and E85=?
  159. pro-charger setup
  160. Turbo 5.3, aiming for dead nuts reliable ~425whp and quick response
  161. best forced induction head for around $1500?
  162. turbo installed- blowing ignition fuses?
  163. josh@kytp
  164. forged 370 or 408?
  165. Turbo cam ?
  166. which of these 3 clutches would you chose
  167. aps kit
  168. Speed Inc TT Typhoon new best (vid)
  169. HR Built Procharged 2002 Camaro SS: Cam/D1SC/Exhaust
  170. gt55 turbo and a 5.3
  171. Turbo Build Ideas!!! Opinions and suggestions Please!!!!
  172. turbo leaking oil externally. not feed or retun. ????
  173. Wtb 7/8 sec single turbo camaro or cobra
  174. D1SC on a 383 with 10lb - joke!
  175. Anyone used Probe forged pistons for high hp?
  176. Whipple Supercharger for the Gen 4 F-body
  177. oil cooler block off plate
  178. new to turbos few questions
  179. Wastegates dumped? Anybody got a sound clip?
  180. If I were to turbo the Z06..
  181. blown 454 lsx ?
  182. riddle me this
  183. Turbo kit
  184. Converting Ebay hotside kit to T6?
  185. What turbo for forged 5.3 with AFR 205's, cam motions turbo cam, ls6 intake ported tb
  186. procharger inlet options
  187. Will I have a problem with valvesprings ?
  188. procharged silverado vs lt1 trans am on spray
  189. 5.3 turbo bilud
  190. APS Twin Turbo Kit install help
  191. What is a slip discharge?
  192. twin 88s or 106mm or 118mm turbo
  193. PT76 Stock bottom end LS1 717/720 12.5lbs
  194. 100MM MAF guys - please reply
  195. chinese turbo track times
  196. oil pan drain for turbo... think i fugged up
  197. 408 and pt-88 ???
  198. Turbo peeps, step inside...
  199. Your thoughts/warnings on this set up
  200. precision vs turbonetics? anybody done a comparison on the dyno
  201. LQ4 or LQ9
  202. Holy $hit, Twin turbo, Trans brake vids.
  203. STS possible exhaust leak???....video inside. UPDATED with P0300 and ex man temp scan
  204. I need a .055 thick head gasket
  205. Want a Free Tick Performance Shirt? Guess the RWHP of our latest ProCharger Install!
  206. Hps 2012 Twin 88 LSX Drag Radial Racecar!!!!!!!!
  207. p1sc going from stock 75mm maf to 85mm 5 wire questions
  208. Hell yeah!
  209. some pics of my progress. D1SC, Big Red, FMIC...ect.**More pics/vids Added!!**
  210. looking for a new intake manifold
  211. 406ci will this turbo work
  212. TC76 rear a/r sizing on stock 346?
  213. anyone running a Lingenfelter 100mm MAF?
  214. For the very few...
  215. 402 F1 Firehawk Start Up
  216. High compression and Boost question
  217. combo help?
  218. exhaust on 427 + TVS2300
  219. Stock vs. Forged Shortblock
  220. some pics of my engine bay
  221. DC Power Engineering 185 amp alternator work with procharger
  222. tvs for my 5.3 in 67 Chevelle
  223. Twin 70mm or 76mm spool on 5.3 on the street?
  224. Front Mount build thread. Stock Shortblock, TC78, 6spd. Numbers/Vid on Page 3!
  225. good low boost bov?
  226. best stock block platform?
  227. Hoosier drag radials
  228. Why not to buy cheap BOV's
  229. FI on M6 or A4, whats better & safer..?
  230. selling my 05 vette procharger setup
  231. front mount t76 346 ,what convter?
  232. SC a reverse-intake LS7?
  233. Rear Mount Oil Leak
  234. Attention all stock shortblock players!
  235. which turbo set up should help me
  236. Damage in turbo sts
  237. Just a farmtruck... nothing to see here :)
  238. Plan on taking out some fast imports next year.
  239. 317 vs 243's for a 5.3L TC78 setup
  240. PT7875 times finally, 10.01@144mph
  241. turbo or procharger on 5.3?
  242. Lets talk turbine wheels and "trim,"have some questions.
  243. trying to down size turbo, need some help with physical sizing
  244. Boost Spike/Drop
  245. 370 what turbo?
  246. turbo engine build
  247. Could it be? Finally an 8 second pass?
  248. Im after your opinions on a Turbo for stock 346
  249. FMIC Procharger help
  250. Keep 241s or go 317 heads
