View Full Version : Forced Induction
- Futral cam and D1SC questions
- will a D1SC procharger fit with the LS conversion?
- Log Manifold Tube Sizing
- How hot is too hot?
- Check valve location and where to buy?
- t04e too small?
- looking for some advice. 5.3 or lq4
- radiator
- 2 bolt LS6 manifold leaking?
- ls3 holley hi-rev intake
- Unequal length turbo piping. WRONG???
- Got a few questions guys.
- What turbo
- Single turbo C5 build thread
- cam help
- Where to buy catch can?
- will a lt1 procharger bracket work on the ls1?
- Going after the stock short block record
- twin turbos
- Heads or Motor gone
- turbo oiling help
- Simple Pulley question please help
- Some questions on a magazine build (not the 1200hp 4.8!)
- What should my MPH be in the 1/8th? Update 9-13-11 New 3.5 gear
- Can anyone confirm that the Mast Oilpan fixes the oil starvation issues on fbodies?
- E85, 402, F1-A Procharger - 12.5:1 CR too much?
- going to be installing my D1SC in a few weeks. Any advice is welcome!
- turbo advice please
- T6 install kits on sale!
- 370 or 383 steel or aluminum?
- need help selecting engine kit for turbo 6.0
- Need turbo help asap
- Is this turbo to big
- F body turbo kits laying in the yard LOL help me find them a home...
- Air/fuel confirmation?
- Need help Picking Out Procharger for LS1 Miata
- F1c and 8 rib ?
- Oil Leakage
- 3 in cog question
- Cam suggestions for turbo LS1
- track time with turbo 5.3 air bag nova
- Magnum Performance v. On3performance T76 BB
- lq4 turbo opinions needed
- camaro ls1 turbo made 554whp
- Dumb question...can you hear your turbo under regular acceleration
- Need blueprint for j bracket??
- Installing a FMIC for a Vortech SC
- Is this cam good for a Maggie?
- 243 vs L92
- True duals on a twin turbo setup
- How much boost should I be making? P1SC-1, stock LS1 w/ blower cam.
- 317 heads on 5.3 for a twin turbo set up?
- WIW? P1SC kit
- budget turbo 5.3
- radiator for front mount setup
- Turbo 5.3 with 76mm....3" or 4" exhaust opinions?
- Would twin tc78 (1.15ar 68mm) spool on a mild 6.0?
- boostmaster intercooler = cxracing?
- Turbo Manifold Idea....don't laugh
- D1SC on LM7 Questions
- compression ratio with 75cc chambers?
- Twin GT67's enough or go larger?????
- My car feels slow... I want to up the boose. Questions...
- Dyno comparison on TT C6 Z06.. GM LS7 427 Vs RHS/All Pro 427.. Dyno/Pics/Video Inside
- PT76GTS - lq9 370 vs 40X
- Feedback, Thoughts on this FMIC. Treadstone TR12 and TRST
- is it possible to run w no boost ref reg for fueli
- Greddy Solenoid issue
- 3.3 bar map only reading 2.5
- Engine break-in with Procharger
- Turbo or Supercharged LY6
- PT88 or PT8884 CEA???
- hobbs switch placement?
- Speedinc TU2
- Still having staging/launch issues (turbo related question)
- Modern Muscle
- Turbo car over heating
- Rear mount set up questions
- After LT Headers, car got REALLY QUIET
- I need info on a Low profile sheet metal Intake
- piston slap?
- What year 4.8 or 5.3?
- Looking for a turbo system for my 08 silverado hd
- T-72 5.3L what A/R?
- how mutch power does a fast intake give
- Wide band loc
- what ring gap?
- How many daily drive
- new to turbos
- Oil pressure loss...
- Procharger pulley recommendations
- Backpressure on 6765's
- Hate to do this but... "which one?"
- STS turbo Evap/pcv delete ??s
- which intake gasket for lq4 boost?
- procharged f1a joe gibbs silverado
- MP112 height difference?
- head & intake ?
- Need build opinion with stock stuff for boost!
- ?s on ARP torque specs
- Best boost piston, wiseco vs CP
- Single or twin turbo 4.8?
- Air to Air again or A to Water?
- My D1SC will be here on tuesday!
- sts turbo install q's
- What do I do?! Should ports match on a supercharger intake manifold?
- Procharged LT1 build
- Turbo LSX in a 2000 Saleen S281 Mustang Build...
- What size vacuum/boost lines for Hobbs switch and Bypass valve.
- front mount pictures & video's
- Bob @ brute speed parts??
- Porting LS3 heads, Fast 102, 2 inch exhaust questions?
- Sorry for the STS thread but its back
- ac lines and c6 mani kit?
- D1-SC with 3.7 pulley, only 4 psig!! Fast intake problem... maybe! Hypothesis...
- WTF did i break???
- TVS 1900 or 2300 for ls1 gto?
- noob starting soon, need help and pointers on a single turbo build
- Power steering line kit options???
- question about stock ring gap.
- HPS Rear Mount Turbo T/A #'s
- Does meth go bad?
- what boost controller ?
- Motor running too hot
- Procharger fan -> spal fan
- Turbo pistons for a 5.3
- Anyone here boosting on Prc STG2.5 5.3L ?
- question for those who used their washer tank for meth....
- will s480 work for my goals
- Looking at boost
- What is my turbo kit worth?
- ProCharger Price Increase Coming August 22: Order Now and Beat the Price Hike!
- LT1 stay MAF or go SPEED?
- LT1 Turbo Help
- New PB in the turbo Firehawk
- Intake elbow
- Any venders here or reliable places to buy Tial MV-R44 wastegates??
- AEM TruBoost doesn't hold low boost
- LS3 or maybe ls2 conversion guys any problems with PO327 knock sensor code?
- what blower to replace my v9 with??
- procharger guys. post up your ETs
- Aps TT HELP
- 2011 CTS-V 2 door coupe pic/vids
- Turbo Sizing???
- excessive crankcase pressure????
- Help identifying a supercharger bracket
- LT1 just some advice for a D1SC not a build thread yet sorry
- I need turbo 5.3l efi advice !
- What PSI spring to start with?
- Whats you procharger set up?
- recommended bearing clearances and ring gaps for turbo motor: 1000rwhp
- Engine didn't last a summer/ new build time
- keyed lt1 hub???
- procharger ducting q's?
- My Build - 2002 TA 408 - Twin 67's
- supercharged or all motor?
- Procharger j bracket install
- New setup runs 5.81 @ 123 HD video inside :-)
- intercooler
- new pb and lifted a head 9.03@146 updated with pics
- Limits of sdce and aster
- 5.3L Monte SS
- Thanks Ohio Boys
- ? for tubo guys running the 1/4mile in the 9.5 to 10.5
- 20+PSI and stock Brake boosters?
- Where to place wideband on downpipe?
- 383 sbc to turbocharged 5.3 swap questions
- Twin waste gate setup
- Virginia speed build...
- who has the white trans am in the current gm high tech?
- what do you guys think?
- 60mm Eboost2 mount for trans am
- High miles and boost
- going forged now have some questions
- 16lbs on a 2 bar map?
- Heads and cam combo!! for D1SC pls help!
- Wha size turbo
- Vortech vs procharger
- bad placement for oil return pump?
- daily drive turbo fbody
- Starts Then Dies Immediately - Intermittent
- Truck manifolds with V-Bands
- Procharger 8 rib belt woes
- Should the supercharger "free spin"?
- lsx block question
- help with procharger setup, adding bov
- 3.9 k1 crank, k1 6.098 rods, what pistons
- What power are you making with your 6.0, and how much boost did it take?
- procharger guys need help
- Gapping for boost
- Can somebody let me know the proper A/R?
- Help fix my c5 frc with a vortech
- midframe 78 made it in now need some input!
- Supercharger + boost leak? plz help!
- Ok fellow auto aps guys what are you doing for trans cooling..?
- Help me read my TR6 spark plugs
- need help!!!!
- m112 on ls1
- Filter Screens?
- 1/8 results turbo lq4 PICS&VID!!
- Altenator pulley issues
- Pushing water through copper HG
- looking to buy p1 d1 or f1 !!! suggestions
- Pin crank from front or side with ati dampner?
- Oil Scavenge Pump ... Anyone Tried This One
- Turbo smoke?
- Getting weird knock
- KY turbo Build: Stock Btm End
- few questions
- Built shortblock but from who???
- Those of you with FMIC that removed "bumper support"
- What happened to LM Speed?
- What kind of HP numbers can I expect?
- What should I dyno?
- Ebay intercooler and HP
- What cam?????
- Seat pressure with XER cam with boost at 20+ pounds?
- anyone here with a garrett gt budget turbo with a 1.23 a/r looking for a 1.08?
- Ideas for street strip build with an f1
- In the 10's on 8lbs with videos
- how much boost?
- super charger trade
- fixed exhaust leak, no boost
- Maggie vs Whipple 4th Gen Fbody
- IATs with painted factory intakes????
- My Z06 Transformation Video
- Paging Nashville Tennessee
- Supercharged under 9 psi?
- blown 5.3
- Vortech Power cooler question...
- Any videos on procharger enclosed race valve?
- making boost but still making power?
- Decided on a D1SC. Few questions about the setup
- Turbo specific oil system?
- Looking for dyno graphs or results on 370ci PT88 combos.
- Let me see where you relocated your cruise control box to...
- fouled plugs
- EPS 234/246 with boost?
- Thoughts on my wastegate placement?
- ls2 corvette whipple kit
- Work In Progress: '98 F-Body TVS2300
- Procharger or turbo on 6.0
- 98 camaro ss will this procharger kit fit my camaro
- Turbo LT1. What max coolant temp is ok?
- IN need some advice !!!!!!!!!!!!!!!!!!!!!!
- rea mount turbo, change oil weight?
- 3.905" forged piston help?
- Vortech v1 mount question!!!
- Turbo piping question
- New fuel pumps: What do you guys think?
