View Full Version : Forced Induction
- Car Wont Rev Past 6000
- Going SD...what is needed???
- Stock LS3 Heads\Cubes, AUTO, Procharger D1, NO METH = 888rwhp 827tq
- AES 390 Boosted Heads??
- Radiator moved forward with ac guys, which fans??
- How much boost are you guys with big brass ones running on the stock block?
- Quieting the Whine
- Smoke coming out valve cover breathers
- Which blower cam?
- FI catch can, which is best?
- Link to a lil video of my turbo trans am.....
- turbo timing
- Forcedinduction
- LME Motor dynoed and shipped
- 5.3 in an 86 IROC
- 19201805 valve material (lsx L92)
- Custom $1000 rearmount
- Conversion from LS3 to LS9 help needed!!
- How much timing are you using to spool larger turbos
- 6.0L coils vs 5.7L coils
- What boost level do I have?
- pro charger super damper
- how must boost can i run?
- new pb 9.12@148
- GTO fans in replacement of ls1?
- What kinda power without an ic or meth
- Need to decide today.ls1,or lq9.forged 18psi
- a lil help plz
- Stock block DD reliability- Take a guess how long it will last
- Lets see some exhaust setups! (front mount turbo)
- School me a little on Superchargers...
- Stock ls2 block reliability??
- New IRS Record 7.89
- wastegate question/concern
- Got my FTI Poweglide installed
- Trap speed with 9-10 psi
- Wastegate mounting?
- Autometer cable help?
- Alternator Relocation Bracket
- LS9 Cam
- Ford TB TPS
- blower cam choice!
- procharger pulley questions
- STS TURBO too LOUD...BEST MUFFLER TO KEEP FLOW.
- venting wastegate to atmosphere or to downpipe?
- 4.040 x4.00 piston
- 10.5:1 compression 408 with s91 turbo
- Gauge Question?
- Eboost in TA air vent
- Spal 12" puller fan question for turbo car..
- Why is this kit do cheap? Is this Garbage?
- Just bought a d1sc kit..... Parts needed for install
- Looking for P1sc head unit
- ls9 cam stock heads 4.8 pushrod length
- Is this blower cam ok?
- timing chain
- turbo and oil pressure ?
- I need YOUR advice!
- For those who are running a veritcal Griffin
- Exhaust smells like sulfur after WOT pull?
- Cooling setup for procharger
- 5.3L Turbo Motor with 6.0L heads...Gasket Suggestions???
- Anyone ever ran an F1A on an AES boost motor?
- FMIC on a LT1 Trans Am
- Our TT kit is FINALLY done.....
- Pro charger install
- Maggie Questions
- What pistons and cam?
- what rings to go with
- meth tank placement
- LT1 boost cam for 76mm?
- How would you do it? 408 w/STS C5
- Is partial boost possible at part throttle with a Procharger?
- Intercooler size
- Procharger belt size
- going boost...do i keep my wiper fluid reservoir?
- How reliable is the P1sc-1 procharger?
- APS turbo upgrade
- LS1 Bogging with Procharger
- ati crank pin
- **Another 700+rwhp ZR1 Corvette from Late Model Racecraft**
- P1sc install. Coolant pipe conflict with Procharger pipe conflict
- problem with procharger breaking belt
- 69 Camaro single turbo I'm working on.
- Oil drip from rear exhaust.
- Ebay/PTK Kit Owners What Size V-Band clamp on Driver Side Oil Pan Pipe Connection?
- PCV - Valley pan options
- car smoking a little... what do you guys think?
- 370 + F1c @ 900-1000hp.... double pin crank? Key?
- Piecing together procharger set up. Any help appreciated
- Turbo Sizing for Rear Mount
- Got new ERL 427 engine home today!
- Another PCV question
- Muffler ideas for down pipe?
- TC stall ? help!
- intake question
- is my turbo to low
- The little 76GTS that could, a new best!
- Got the car back. It made 905rwhp 802rwtq on 13lbs
- Check my build..am I an idiot or pretty close?
- BMR bracket/stock alternator/truck manifolds....with pics!!
- Question about boost fluctuating.
- cam ?
- What would you rather have? 408TT, or a 408PT88
- Will I be maxing out my stock ls1 maf?
- vacuum switch?
- Insane Idea.... your thoughts?
- What in the tune affects spool on a turbo car?
- Help! Pt88 or Tc78 or 76GTS
- Maggie owners, fit strut tower brace ?
- a little advice- breakin up bad under wot , until 4k
- L92 with boost
- Newbie Question on boost.
- Adding turbo to 11.5 to 1 lsx370
- Im taking off my D1SC for smog
- P1SC Procharged GTO
- Whats the numbers on your cam
- help!!!!
- F1c???
- Maggie or pc for 02 camaro?
- o2 and W/B problems
- Where to mount my 3 Bar MAP?!?!
- Final- Twin 76 C5 coupe
- Oil Cooler Adapter for Oil Line to turbo?
- Twin 38mm wastegates with 6lbs springs in each spiking to 8 then settling....???
- Are plasma moly rings usable for boosted applications?
- What gear for th400. I have two options...3.0 or 3.25
- It runs...project elcheapo part #2
- Few questions for my front mount build
- I think I lifted a head.. What side effects may be associated?
- Getting toward the end of single turbo build
- will a vic jr intake fit in a C5 with aci cowl hood?
- Project Instant Boost. Pic Heavy
- Will A 96-98 mustang cobra procharger d1sc Mount up to an Fbody kit?
- Stock LQ4 + boost..... How much will the stock cam hurt vs. LS6?
- FYI - Turbo '98 T/A For Sale
- heat wrap question
- Just picked up my S/C for my SS
- Who is running AC with their turbo setup?
- Need inspiration before I light my car on fire for insurance $$
- pics of d1sc install
- LS1 Rx7 E85 Boost, thoughts?
- Roots Blower Fuel atomization question
- T4 Turbo inlet pipe size
- questions on removing front bumper cover for intercooler install
- methanol injection
- Upgraded my VA speed down pipe
- procharger question
- ebay kit
- Jdm turbo kit
- 65 chevelle ls2 turbo dyno video finally
- Gauge install
- intake for trickflow heads
- Procharger Problems
- Bye-bye bottle. Hello twins. LS Coupe refit.
- Incar view of 220+ blowouts
- ran a new PB saturday. 10.439 @ 133.63
- Another 'How much boost?' newb question.
- Target air/fuel ratios and other affects
- msd 6010 timing map starting point??
- build thread with some issues want some opinions...
- boost controller - by speed or gear
- Forged 346??? Boost???
- Which pulley for my D1?
- Turbo 5.3 in an RX7 project idea need some advice.
- Iron Block 378, gt-91, front drive distributor...base timing?
- Turbo gurus, help me create a build list...
- Post turbo O2 sensor reading issues?
- What filter fits a procharger bypass valve
- TVS1900 GTO, screaching noise at high RPM's
- LT1 stalling, MAF readings and bypass valve.
- Latest blocks for FI
- Best turbo's for a twin turbo 5.3/6.0?
- OFI t6 test fit
- Random eaton supercharger question..
- vortech Maxflow Mondo Bypass Valves
- Is this really an alternator relocation bracket?
- Problems
- twin turbo hawk build
- Need advise on intake
- Help me identify this kit
- Hows this cam look? Supercharged App..
- update on my ls2 forged 364 F1 build
- Have boost rotating assemble,cant find lq9 or 4. Chicago or close people please help.
- Best turbo lt1 manifold company...single turbo. Which one????
- WTF 28,7 PSI on a 4 bolt heads
- Water/methanol injection expierence?
- Would this be a pretty decent turbo cam with the right turbo spec'd out?
- STS Setup Questions.
- s91 vs. gt91
- loosing boost
- 6.0 CR ? for boost.
- Looking for a cam
- Erl superdeck
- regulator spring
- What do you guys think about the 5140 compstar crank in the aes 390 shortblock?
- spark plug wires resting on headers..what heat shield can i use?
- anyone want to trade turbos??
- Kentucky Turbo Alternator Relocation Bracket LS1
- Odd screeching sound from engine bay (VIDEO)
- Critique: My radiator/condensor/puller fan setup
- Turbo kits?
- Cam change based on heads?
- cam for boost
- 232/236 cam,80mm turbo,370ci, what do you think?
- Comp LXL Lobes
- Manley rod strength?
- TR 220 cam
- Did I make the wrong choice going with an LS6 cam?
- rear mount wastegate location
- **LMR TX Mile 222mph Vid**
- LS9 cam in a turbo 5.3?
- blow thru ignition
- Procharger kit
- Those who made their own alternator relocation brackets step inside
- Any sponsors sell a 10 AN turbo drain kit?
- CALLING ALL BOOSTED LS 4th GENS F-BODIES!!!
- How restrictive is stock exhaust on a blower car?
- Procharger install questions 99 formula
- **LMR TX Mile 239mph Vid**
- Filter dimensions for a D1SC??
- Removing my whipple?
- Oil for FI
- Opinions on Turbo Heads
- probems holding steady boost
- Precisions b/s about fixing my turbo.
- blow-thru question?
- 4.8 silverado 10psi turbo camshaft, springs, timing chain recommendations??
- AES 410 LSX boost shortblock package - NEW
- What hp will this setup yield and what fuel system will be needed?
- budget turbo ls1
- pro-flo xt fit under lt1 ws6 hood?
- Lt1 boost dyno graph
- F-bodies turbo set-ups pics
- procharger guys
- sts turbo fried?
- Which Plugs?
- Anyone using an original E-boost EBC
- 5.3 t-72 build, e85?
- sts install instructions
- has anyone made a bolt on vertical radiator mod?
- 10 second pass on 2nd ever pass on twin turbo setup
- SDCE or Aster For my new setup
- Poor Man's Beltwrap Stondoffs... THEY ARE FINISHED!!!
- mp70 with 6.0 build..need help please
- Ls3 + aps tt = 606/578
- Trans AM APS TT owners come in
- APS Manifolds and turbo exhaust side
- 3.5 to fmc
- Walk around of my 1200 horsepower (I hope!) trans am
