View Full Version : Forced Induction
- Flowmaster Mufflers new contest - "Show us your flows"
- hot side pipe thickness?
- Procharger belt problems HELP!!!!!!!!!!
- Suggestions????
- Help .......
- Rear mount BW s475 forged 364 ws6 trans am. Begins soon
- painting procharger!!!
- which truck manifolds?
- Paxton Sn2000 for a 3rd gen fit LT1?
- Cam profile for Forced induction?
- intercooler and cooling?
- Need opinions
- Where can I get good boost line?(non rubber)
- LMR Standing Mile Update #2
- Exhaust routing for NOOBS
- turbo kits
- Does it matter what a turbo comes off of?
- LS9 headgaskets with a 4.005 bore piston?
- sts turbo build
- What heads are good for a 390ci turbo motor
- Procharger D1SC impeller?
- Turbo VS Procharger
- Best Engine to Boost?
- holset h1c
- pte 7682
- Q on re-torquing head studs
- Bypass Valve Location ....
- completed pics of my 25-3 cage C6 Z06
- Scorpion 1.7 Roller Rockers or Upgraded trunion stockers?
- 4l60e
- Supercharged engine pics
- I want more power what would be the best setup for me?
- Turbo Hot Pipe design/ log's vs headers?
- Want to maximize current setup, opinions wanted
- Hey any one ever seen the ARP 2000 7/16 bolts break ?
- What's it worth?
- Vortech supercharging my LS1 swap. Help!!
- Twin TC 67, 70, 72, or 76
- good turbo cam?
- boosting the LQ9 a few questions
- Questions on Maggie 112, and 112H, 112HH
- waste+centrifugal!!!!!
- can I get away with this cam until rebuild
- Lets talk correct Turbo air filter size
- Champion Motors 1082rwhp dyno video
- Turbo 94 Camaro build
- Need pics of twin turbo f-bodys
- open letter to Spohn about your solid motor mounts
- What's a better turbo rear gear?
- MAGGIE Wheel Size.
- Which spark plugs for Turbo
- Upgrading...Again....Goodbye P1SC, Hello ...
- ls9 head gasket + ls1 heads + ls1 lifter = what pushrod
- EBC location pix
- Help me plan my boosted LSx build
- Ar distribution issues on lt1/4 f/I apps
- Using a FMIC on a TA?
- ProCharger Front Mount Intercooler for 98-02 F Body
- I need some turbo input
- All this activity and no timeslips?????
- Cats or No Cats with Procharger and True Duals
- F1-A on a cam only GTO
- Hydrogen Cell
- Would the stock bottom end be OK?
- LS3 stroker durability as an FI engine?
- forged 347 d1sc reliability
- **Wanted-LSX Mechanic**
- Noob FI questions. Take a look at my parts list please.
- Backpressure question
- What size turbo for my sts
- T70 on 6.0??
- New build Info and Sponsors added 2000+ HP Build
- On the right track to FI?
- Pics of BWS400?
- gt-3582r upgrade to ...................
- Vengeance Racing custom Twin Turbo C6 Z06 build
- what maf sensor do i need?
- thermostat for griffen radiator
- Stock Head Gaskets Question
- Piston selection... Wiseco K444X3
- Jaw dropping turbo engineering at its peak
- head selection: tf 235 vs mast 256 square port????
- AES Block Coming Soon!!
- So i had no idea what i was getting when
- 370 rods and pistons
- Mustang MP 112 supercharger??
- 25-3 Cage is done in my C6Z06, 7's this year!
- Procharger fmic
- 237/249 .585/.585 115lsa +4 is this a good cam for d1 ls2
- Pics of the pro-mod!!!!
- anyone sell already done spark plug wires with 90* boot for plug?
- ChevyChad pulley mod on F with D1-SC!! Having problems installing! Pics inside.
- Solid roller cam?
- need help on turbo identification
- In need of a cam
- Big KB Blowers
- is a tc76 a direct replacement for a Mpt70? lines,v band etc?
- Return line: Pics needed
- which pulley??
- Methanol + Vertical Radiator Mod
- Newb to FI...So a newb question
- Merge pipe- will this work, or?
- divided t4 and spool
- procharger a2w intercooler
- Ls2 formula build
- Need your opinions...Greddy Boost Controller or AEM Boost controller.
- F2 procharged 408
- Need push-rod advice please
- BEst cam choice for my forged ls2 d1 procharged
- S/c ls? C5
- D1 procharger with 3.4 pulley... How much boost will it make? and what size injectors
- 1500HP Build: which TB?
- cary intake on lsx TT
- pt88 oil feed fitting size?
- looking to finish up my 408 short block have a few questions
- Fast 90mm for high boost
- ARP singles?
- 6-71?
- EPP Front Mount Intercooler
- Alky Control Questions
- Adjustable boost supercharger
- Meth vs n2o
- Intercooler question
- Final stages- PTK FRC PICS
- MPGT45 vs. PT76GTSH on a 370ci ?
- NEW TO F/I. Some Newb Questions?
- TC76 vs TC78
- 5th Gen DIY Turbo Build
- LQ4 or LS2,3,6, what is better for tub or supch
- catch can to close?
- Fans
- How is the magnacharger tvs 2300??
- Little teaser shot...
- Need better Drian lines!!! APS
- precision hps vs gts ?
- anybody recognize this car?
- Tick Performance ProCharger BLOWOUT: Installed AND Tuned @ $500 Off Retail!
- How to measure Procharger Pullies?
- Boosted GMPP LSX 454 Cylinder Cracks Like An Egg Shell
- wastegate?
- Help!! vedio of red race bypass
- How would an LS9 cam do with L92 heads and turbo?
- Fast Or Vic Jr ?
- Turbo guys be careful...
- Egay Kit out, Truck mani's In!
- PVC solution for Boosted Motors
- Estimate on what RWHP will be
- Adding Turbo To LSX Swap -TELL ME WHAT TO BUY! PICS ADDED OF BUILD
- Tried to dyno 383/ST80 with 4200 stall
- How often should you change lifters on a Boosted Car?
- Pusher Fans
- personal thoughts
- stock ls1 with 853 heads on 91 octane boost?
- Turbo prices...
- whos runnin stock lifters?
- Best place to mount computer in a 68 Camaro??
- Ls3 vs. 317 heads
- Will C6 manifolds fit LSX block and heads?
- Trans cooler in front of intercooler
- Supercharged 3.8l?
- Is this something to consider for boosted applications?
- Coolant Tank Relocate
- L92 and LSA heads on 20 PSI
- check it out
- JDM's turbo kit ?!
- Recommend me a turbo!
- which spark plugs??
- 1000+ HP Guys... What Oil Pump Are You Using?
- first time turbo
- Changed my build
- head install with arp 12pt
- schedule 10 stainless steel piping
- head gasket blown already, few questions
- procharger inlet hat
- turbo motor converter.. 4l80e
- Opinions on rear gear ratio, 4th gen camaro
- How would you turbo M6 guys like a boost by gear?
- Stock bottom LS3 power limits?
- What kind of power can my new engine handle?(guesses?)
- Twin Setup on 2003 silverado
- sts/Rear turbo "stand alone" oil system
- s400 76mm turbo
- ebay turbo setups? Timeslips?
- how much boost can the L76/LS3 intake handle?
- 98-99 manifold
- whos had a bad experiance with meth?
- Anyone use a Vette style A2A in an fbody?
- Procharger w/twins - questions
- camshaft recommendation for 400 ci
- Truck Manifolds with air tube ok for turbo setup
- 5.3+s480
- 67 Camaro LQ4/T56 - help me pick a turbo!
- Anyone bend a rod bolt on LS2 with 700rwhp or less?
- Whos running wide bands
- Finally pulled the motor and shipped it out.
- turbo build questions
- lsx real street class
- turbo 408 build idea. flame suit on input welcome
- Restrictive exhaust on APS TT car
- For those that are around 600 plus rwhp...
- T3/T4 Turbo flange transition
- Dyno, need opinions please.
- hooking procharger plenum up to TB (no MAF)
- set up questions
- What turbo would work?
- The new build is coming along.
- Anyone make a turbo kit for a ls1 68 Camaro?
- motor internals?
- Procharger f1-a with stock crank?
- Need Help!!! I think I damaged my engine!!
- how much hp can a tvs 2300 make with the proper engine spec'd out for it
- Anyone regret ditching the AC after going FI for mostly street duty???
- Hotside fab
- what cr 8.5.1 or 9.5.1
- KY Turbo install
- Procharger owners : Poor Man's Beltwrap mod standoffs
- KY turbo, high comp, twin turbo, E85 setup
- Fuel pump For 500
- Thinking about switching to E85
- AES Boost 5.3 shortblock $2599
- so am i stupid? crazy? or a genius?
- 383 LQ9+F1-A=9SECs?
- 6 rib Procharger guys
- header fastener question
- spark plugs for a tt ls1
- 5.3, boost cam, w/MP70, 10psi, 6-speed. Will I see 500Hp at the wheels?
- Turbnetics T76 Thumper Verses TC78
- 10 SS Vortech V-3
- S/C LT1 question???
- Possible blown head gasket????
- National Speed Build: 1966 Chevrolet Nova - Full Street Rod Build..
- PT-900 maXXXed out, need options
- Anyone used the gm performance lsx 376?
- **LMR Standing Mile Camaro Build Begins**
- Turbo kit
- diamond piston rings
- MAP sensor
- ls3 rear main seal backwards or normal for boost
- Lq4 Turbo questions? Which one?
- Pro street 64 nova twin turbo LQ4
- Rear mount turbo oil pump question (please help)
- Budget turbo build
- H/C 11:1 comp to supercharger setup?
- Couple more last minute erl 427 questions
- 1142 rwhp 1147 rwtq budget 347 w/ GT-88
- Big Red BOV questions ?
- DIY Turbo Gasket Questions: Help Please!
- Bought a P1SC...What Should I Expect?
- g-body turbo headers.. What other options besides having set custom made??
- someone look at my cam card please.
