View Full Version : Forced Induction
  1. Intake runner size for boost?
  2. VHT Trackbite to help with belt slip.
  3. I-Charger (Twin Screw) info from the manufacturers. Good stuff
  4. Lightweight Balancer?
  5. Consistancy of a turbo car in bracket/index racing?
  6. I wanna go Fast(er)!
  7. Whipple LS1?
  8. Dumb question.......
  9. How much boost
  10. Forced Induction + Mass-Flo Fuel Systems
  11. 6.2l headgaskets
  12. Turbo guys I need your help...
  13. Is my boost gauge working?
  14. Anyone Using the APS TT C5 kit?
  15. Daily drivers w/600+ rwhp
  16. MSD Timing
  17. BMR rad cover for INCON TT????
  18. Procharger J-Bracket Problem
  19. Procharger guys. Come inside please!
  20. Your choice for a electronic boost controller
  21. Assembly limits
  22. V-band sizes, is this right?
  23. Stock Long block LS2 breaks 700whp!!!!!
  24. Give me your PUMP gas numbers!!
  25. Reliability of FI'd LSx
  26. 11:1 CR, H/C, and Boost from D1SC ... Need some info
  27. P1SC Cam ideas
  28. blow thru ls1 Q`s
  29. fi street methanol
  30. does this look right (pic)
  31. Help!! Please
  32. Spraying e85 through a meth injection kit
  33. Using E85 and Methanol Injection?
  34. LS6 vs. GT2-3 or similar custom grind on D1SC 347 w/ heads
  35. Couple pics of Turbo Car!
  36. Need intercooler tubing or header tubing? We can mandrel bend you whatever you need.
  37. Twin GT42 LSX T/A
  38. help with overheating
  39. 2007 C6 Vert
  40. Going FI
  41. S91 408 T/A....dyno on low boost and pump gas
  42. What belt length with PTK turbo kit?
  43. where would I get compression clamps for exhaust?
  44. pics of ATI race valve installed
  45. First drive D1sc Video
  46. Is this a gt47-88???
  47. what size motor for f1r
  48. APS twin turbo what size of engine to get?
  49. Ignition system for Procharged ls1
  50. Building a block for FI
  51. What would happen ?
  52. 10's on stock heads/cam/intake/tb
  53. Wanted advice on potential vortech buy *Pic*
  54. Nitrous intercooler spray
  55. what size is a t3 turbo?
  56. Does running E85 affect turbo sizing?
  57. Stock block + 13psi + 7250rpm = (pics)
  58. whose main studdin?? and TB flange..
  59. Cam and Pulley ideas
  60. APS TT GTO vs Modded GSXR 1000
  61. Congrats MIGHTYMOUSE!
  62. Home made meth kit
  63. Procharger F1 Head unit?
  64. Wastegate for a T88
  65. Thick Cometic head gaskets for SC FI
  66. Going from Juice to Boost......help
  67. Good Cam For Turbo'd 408
  68. Semi Results
  69. I just bought a Procharger!!!!
  70. Going Fast...
  71. Paging EPP f1a install help
  72. ECS Paxton Novi 2000 Stock Bottom end 9.8 @ 139 Mph
  73. -10 to 3/8 good enough for return?
  74. My F1A/402 Setup
  75. remote turbo...wastegate feed
  76. new LPE 2 step
  77. Lifted the heads on the Dyno
  78. another aps tt
  79. BOV going bad?
  80. i represented for the FI LS1 crew
  81. SDCE ProFlosurge valve
  82. 408 + stock 317's
  83. FI stuff for sale
  84. 434" Buildup
  85. What would my car be worth?
  86. Turbocharged question!!!!!!
  87. Cheapest place to buy tial products??
  88. Which cam for a vortech blower?
  89. STS guys, get in hurrr.
  90. Procharger?
  91. Help with an F-1
  92. turbo drain ?
  93. any turbo guys had any problems with exaust lifters?
  94. P1SC pulley sizing and boost?
  95. Tial 44mm Wategate Q
  96. Pinning balancer
  97. best heads for boost
  98. Procharger Help.....
  99. Stock heads VS Ported heads
  100. Truck Manifold Twin Turbo New #'s
  101. Flipped GTO manifolds on an F-body
  102. CAM Recommendations for D1SC Procharger
  103. New motor setup for STS car
  104. Will these turbos work for me
  105. Custom rear mount turbo?
  106. Little compressor mapping script
  107. Big single turbo + 481ci
  108. whipple model for mid 90s vortec trucks?
  109. 618/643 aps tt @ 10 psi
  110. Pinning balancer
  111. Need Help With Sts Info
  112. ported victor jr. intakes ?'s
  113. What todo with a slow LT1?
  114. Stepping Up to a 3 Inch Exhaust On my Fi setup
  115. LS4 Turbo, Valve spring & misfire question
  116. the merge into a T4 flange (truck manifold setup)
  117. New to the ls1 world, s/c questions
  118. Best intake manifold for turbo kit?
  119. another "what do you think"???
  120. Have you seen this turbo question
  121. pro flow bypass valve
  122. Garrett Turbo and a Forged 346ci
  123. What is everyone running w/ a D1SC
  124. Future GM Engineer here.
  125. APS f-body it with th400?
  126. Anybody know if the new turbo BMR k member will work with the Fbody APS TT kit?
  127. Help me make up my mind...
  128. Got Fr1 Now Need Motor
  129. Well, did a little tuning
  130. What would YOU like to see in a Vortech big blower setup?
  131. What car to buy to super or turbo? which way?
  132. Garrett GT28R versus T3 60 trim
  133. No one can diag my turbo issue,please help!!!
  134. Shake down passes - D1SC 3.8 V6 Firebird (street driven).
  135. 370 vs. 408 stroker????
  136. LPE MAF? - What are the limits HP/Boost that you know of... ?
  137. paging Bob @EPP
  138. Bypass valve over BOV?
  139. lined up a sts first question
  140. C5 Single Front Mount 91mm Turbo Kit Done [PICS]
  141. How necessary are dual valve springs on 12 psi ls6 heads
  142. APS G8 Pontiac twin turbo system - First pics
  143. 826 RWHP from the 346 cube APS twin turbo
  144. LS1 block?
  145. APS kit with 4l60E
  146. Look what came today :) Gen TT
  147. can I get 800rwhp with my d1 and a 408?
  148. ls2, l92, ls7, lq9 head lifting???
  149. Which 3 disc Vig are people having the most luck with?
  150. Pair of TT Pontiac G8s
  151. how much boost can stock lq4 pistons take
  152. FI valve/spring question
  153. SEMA Photos (all fi)
  154. Oil in downpipe/intake
  155. Starquest Update
  156. What should I go with?
  157. P1SC + 385 ci LT4 Question
  158. Turbocharged LS1 Questions
  159. i need help ?
  160. This is what happens when you go for 9s on a stock 4l60e and stock block!
  161. ohio turbo kit
  162. Yep, another cam ?. Z06 vs. 224's
  163. speed inc tt 6 speed car goes 9.2@156.35
  164. New PB With STS..10.74@126
  165. GM 5-layer MLS thickness?
  166. Going for a twin T off road car, engine Q's
  167. D-1 car finally done (mostly)
  168. turbo selection ?
  169. where to buy 6.0 truck manifold exhaust flanges?
  170. Waste gate on a Centrifugal Supercharger with adjustible boost...
  171. need beger turbos
  172. Who do you use for U-bends/Elbows
  173. Not LS1 but cool Hellion Twin kit with Eaton
  174. BPV/BOV over the stock Procharger
  175. d1sc Procharger oil?
  176. Pt71GTSHP?
  177. TTi LSX holiday Pricing
  178. Should I expect anything going from my 4L60E to TH400?
  179. Which BOV/BPV for procharger
  180. Going to make one more try for the 8s tomorrow with the old 346, wish me luck
  181. Coolant Source
  182. Comp is 10:75 to 1 pro & cons of turbo vs nit
  183. Giving up on turbos, new and improved setup
  184. New Weiand LSX Intake Manifold
  185. Some videos from the track, one showing my spool time.
  186. EPP's blower cam with 1.75 rocker arms?
  187. Got my turbo back from Turbonetics
  188. D-1 kit to F-1 on LT4 motor???
  189. Best Oil return pump?
  190. 98 C5 with F-2 PICS......(56k good luck)
  191. What have you gained going to a larger A/R housing?
  192. 7.84@179 on 275's
  193. Crank Bolt came out
  194. magnacharged TA running to hot?
  195. What will I have to change
  196. Where does the BOV go?
  197. LT1 Forced Induction Gasket?
  198. STS Turbo Installation Guide?
  199. More News at KYTP.
  200. 408 turbo build - need advice
  201. HP Predictions
  202. Best Forced Induction Cam...?
  203. Turbo Choices.....
  204. slp Y with sts
  205. how much boost?
  206. Boost #s with D1SC 7.6/3.4 Pulleys? SDCE Help?
  207. LT1 TWIN TURBO-custom or homemade please post up!
  208. stock ls1 boosted
  209. Paging Ed at Late Model Speed....
  210. Maggie dyno video
  211. map sensor
  212. P0300 Code when car is stopped.
  213. Any F-2 Procharger kits for the LS1?
  214. LT1/ 89 GTA turbo kits?
  215. Jake brake sound
  216. Procharger SES light?
  217. Boost setup ?s
  218. alt 6 rib to 8 rib info (clutch pulley)
  219. Target Static compession on E85?
  220. Ready To Give Up My Money Lol
  221. Attn Ohio boys: O-ring question
  222. LSx misfire issue, come inside
  223. BW S388 turbo?
  224. Which Forged Engine for Boost???
  225. APS kit K member
  226. 60 lbs injectors
  227. GM Kenne Bell 6.0L supercharger
  228. Little vid of the TT Chevelle from Yesterday
  229. Trans Am Build.....
  230. FMIC for 01' TA
  231. Has anyone run LS6 heads milled to 62cc and ran up to 15 lbs of boost?
  232. wheres the best deal to get a Precision T88 turbo?
  233. Windshield Washer Fluid
  234. gm mls gasket purchase
  235. Wiring up 2step
  236. Oil on impeller side
  237. What to do with my turbo 5.3 powered stang?
  238. Most Bad Ass 76mm Turbo
  239. So how much did it cost?
  240. Muffler shop damaged my turbo, need help in fixing
  241. What Garrett turbo is this.
  242. Procharger 4.11's
  243. Turbo Setup in G-Bodies?
  244. Going boosted need help please!
  245. Tune and Boost
  246. Is anyone runnin KY turbo system or Ohio forced
  247. I took the leap!
  248. Some technical supercharger questions
  249. anyone got any info on this turbo
  250. The Turbo Project has Begun......
