View Full Version : Forced Induction
- Metal in the oil follow up
- dyno number seem right?
- 5.3 Turbo w/glide rear gears
- First Boosted Build
- Recommended reading for turbo knowledge
- Turbo Spool Time Increase
- Help me get on track?
- Turbo 5.3 full exhaust too quiet?!
- 7875 spool up on 6.0
- Twin s372
- Racecraft k member fitment
- LS1 Built for boost
- vsr 80mm vs 85mm for 5.3
- Turbo Ws6. 8 year saga 😂
- What's holding me back?????
- Few Huron Speed Kits available w/ VSRacing components
- Tips on keeping my 4 bolt trickflow heads down at 1200rwhp?
- stock 5.7 aps twin cam upgrade
- Boosting Stuff Discussion
- Anyone know the size of the Magnuson 2300 ports?
- Destroke 6.0 8000rpm for twin turbo setup
- Info on 408 turbo sizing
- Cam Choice
- Turbo 5.3
- LS1 max compression for 91 octane and 8lbs of boost?
- HP Tuner Horsepower PID Help
- Turbine wheel sizing
- How I turbo'd my 1973 Camaro 6.0L
- High compression and boost?
- Huron Speed Fox body T4 turbo kit fire sale *big savings, check this out!*
- Holley Smart coils
- Dynamic Compression Questions
- Little Bit Of Tuning Help Needed :(
- Sloppy stage 2 and stock intake
- 1200whp Tick vs btr cam? on Twin 76 LQ4
- Scavenge Pump Mount Location - Huronspeed V3 Kit - 99 T/A
- Switching from pull through to blow through effect tune
- Cut-off point when aftermarket blocks become necessary
- Huron Speed *New* APS Style Twin Kit Group Purchase Intro Sale!
- Aster bracket tensioner
- Swap my manifold?
- Meth Kit bad distribution on truck manifold
- *NEW Kit from Huron Speed* APS Style Twin Kit retains all creature comforts!
- Methanol injection
- Buy LS2 Turbo Headers?
- For the sbe warriors
- Pieced together kit
- Varex muffler?
- Opinions on 418 capability
- Help me pick new rear gears
- Haters bring on the hate....
- Holley Terminator X and running motor on alky/methanol/M1 ?
- Fastest spooling turbo for sub 4000rpm use
- China boosted 102 Dbw TB
- Help with rear-mount turbo sizing
- Build the 5.3 or go ls3?
- Intake tubing?
- Ceramic coat, wrap or both?
- Dragy times
- What's The Smallest Pulley You Have Run With an ATI 6 Rib?
- So Many "STAGE 2" cams...Help me pick one..
- Which turbo
- 98 ls1 turbo in 1971 camaro
- Can I turn the boost up?
- Edelbrock Supercharger
- T4 S480 on a on3 hot side .yes it fits! with a normal fbody radiator !
- 383 LS1 T56 S480 Rear Gearing
- Ran wrong valve seals and developed metal shavings
- My F.I. People in Florida
- How to download Sloppy Mechanics file from tune cabinet?
- Borg S480SXE vs S488SXE on a T56 346ci street car
- Sniper race version on turbo 5.3
- Moderator For This Sub Forum?
- 2 step timing advance /retard boost building Holley terminator x
- 9.56 135mph with JY 4.8 with cast 74mm
- Thoughts on Straub/Yates headgaskets?
- Holley system and emissions?
- Complete LSA Motor Swap into Escalade?
- Battling high IAT's after 10% overdrive pulley added
- Pd blower ice tank?
- Holley Digital Dash Mount Prototype
- Turbo build question
- Magnuson TVS 2650 vs Edlebrock 2650 vs LT5 2650 vs Whipple 2.9L Compared in One Place
- Maxing our map sensor
- LQ4 Turbo C3 Corvette Build
- '12 yukon denali, dart 427, Rossler 4l80/AWD, S48X, E85
- 6.0 gen2 7875 hotside
- What size pulley to reach ~15 psi on D1?
- Can I get 480-500ish rwhp on 92 oct pump gas?
- 2.3L Whipple
- Cutting out under WOT in boost areas
- 388 s400-91 Build (lifter and rocker question)
- paralyzed and Stock Block 5.3 still making progress...more fun than my x275 car was
- Belt tension specification LSA?
- VS 8375+stock cam 4.8?
- GenIV FFV: External FRP for under 10PSI?
- Turbo headers
- I think my intercooler pump is bad.
- IAT k type thermocouple how far inside the charge pipe?
- ASI 3 Row Radiator
- Griptech
- Ls3 boost and fast or stock intake
- Sebring Silver Build
- My first build thread turbo Holden Ute down under 76/82 E85 manual
- S197 5.3 TH400 turbo build
- lq4 with maggie high iat pulling timing
- Do I need to have my ecm/pcm reprogrammed for a single turbo?
- Aftermarket pan oil feed
- BOV ?'s
- *HELP* wastegate questions
- F1A-94 users
- 70 Nova 5.3 turbo build. ROAST ME.
- Stock LSA fuel injector limits ?
- Help on L99 converted to LS3 twin turbo and cam set up
- What is my weakest part?
- 9.86 or 10.44 E85 compression ratio..?
- F1R Air Filter - How?!
- Black WS6 with single Holset +E85
- new nova build thread.
- Big Air to Air vs Air to Water
- holley terminator ls mfi vs gold box.
- turbonetics 6265
- Question for ceramic coating turbo parts
- Holley Terminator and E85
- JY4.8 S474 AIR/AIR 1.45 6.02 117 first time out
- Ls 6.0 ly6 78/75 turbo
- Oil supply for turbo
- Aster bracket users - gotta question
- Matching truck manifolds
- T4 to T6
- Another turbo 5.3 build -help
- Ls1tech expert help please
- OEM exhaust manifolds, Good for turbo, bad for Supercharger?
- What fuel pressure to run with procharger?
- 5.3 turbo build input
- "TOMBSTONE" GMC Build, Dart 427, 88mm, Pro EFI, Air Ride
- Coil Packs
- stock 4.8 with on3 single turbo kit help
- 6-71 EFI question
- Ls turbo hooker headers flange question
- D1sc and 11:5 compression good idea ?
- 99 Turbo Trans Am Build/Dyno/Burnouts 2019
- Truck manifold heat shields
- Any one with a supercharger with wastegate ? Please step in .
- piston rings stock lm7 bore
- 5.3 sbe turbo
- 317 or 243 heads with Magnuson 2300?
- C5 A&A bracket to fbody spacing?
- Keep 10.7:1 or drop it?
- ls2 dbw throttle body overheating
- 800 hp 5.3 cheap as possible
- Let's settle this oil pressure debate.....
- Heat exchanger question.
- Adding auxiliary radiator?
- ProCharger Black Race Valves Now Available
- 4.8 4l80 7875 8.8 fox ...troubleshooting
- 04 Silverado going boost
- TX speed short block advice.
- Hanging idle and booster vac issue
- 260ci TT LS - 1,200 HP.........
- Got hot & ran better ?
- Electronic boost controller with wideband
- 2019 Manual Boost Controller options
- Mishomoto race line fans? Anyone have experience?
- E50 plus meth vs E85
- Turbo manifold help
- Same PSI, different WG spring= different HP?
- Square Body 5.3 turbo. Updated and upgraded.
- Factory 2650 SC'er makes 1,139 RWHP......ZR1 Vette.....NOT BAD...
- Noob question
- 69 C10 ls turbo pro touring on billets project
- Compression with e85
- 1780hp for $15k ?
- Single turbo LS vs 605ci big block for drag car ?
- Need advice on a good 'fun now boost later' motor build
- Cam change/advice ??? Go ahead roast me
- Schoneck Bracket
- Need help please Water/Meth injection, bolt on prochargered car
- ATI Dampner question
- Choosing twins. 6speed 6.0
- Please help 370 build
- Installed EBC Now Car Is Slower???
- Edelbrock E Force on 4th gen?
- Holley Dominator Question
- 5.3L Info Needed.
- ProCharger install guide?
- Which type of forced induction?
- Another 408/f1r build
- Procharger guys - ATI damper assembly ??? See Pics
- Turbo noise
- Procharger/Automatic guys. ?
- Ddnspider's- Project Wrong-Way- Rear Mount Turbo Thread
- Wideband set up? Help a NOOB
- Building a dart 427, Stock Ls6 intake doable?
- New P.B. and a couple of wheelies
- Holley HP and unknown injectors
- 228/232 .600/.600 112lsa with FI?
- 1980 zephyr 4.8 S475 air air - dyno and first bump/launch
- 388ci mildly ported LS3 heads BYR Stage 3 PD and a TVS2650
- 98mm turbo
- LSX376 + 4.5 Whipple
- Gen 3 CTS-V + F1X = 1,429hp
- Securing / Sealing T4 Flange
- Boost district LSA Fbody kit?
- Holley parts
- Turbo LS1 running hot
- Dual fuel with M1 - Injector placement and angle
- So I finally got around to pulling the heads apart......
- Put the quad turbo 4.8 on the dyno.
- Something Different for Gauges & Datalogging - Edge CTS2
- Blow through carb help tuning needed
- Prochager F1A-94 C7 Dimensions
- Twin Turbo Oil Feed and Oil Cooler
- '90 s10 build
- whats the general thought on replacing or re-using hardware..and good head gaskets
- Help reading plugs - new build first 1/8th Mile...
- starting a 6.0 swap..should i go forged or stay stock..? shootin for 650 to the tire
- 2nd test and tune for the C6 Z06
- Boost pressure supposed to be in the top of the wastegate???
- IAT placement question for meth users
- Brake booster delete
- Turbo boost question
- LM7 turbo build questions?
- Throttle body vent with boost
- Turbo 4.8 LY2
- 408 turbo selection
- Oil cooler before turbo?
- Cam driven fuel pump vs a couple walbro 525’s or??
- Turbo 346
- CXracing twin T76's on an LY6?
- Need help tuning blow thru carb mad 6014
- new best but killed my pg case.
- What is the general conscience of the on3performance Single Turbo kit for F-Bodies?
- Help me decide which way to go with build.
- When to kick in the methanol
- Max safe bore.....LSX iron block....22psi+ boost
- Best street car build ever?
- 1000hp build
- which turbo for my app
- first turbo buiid
- "Burping" the coolant system
- Free "boost cut"
- F-1A-94 vs F1X.....are they both equal as far as how loud they are....?
- T-Map conversion.
- Help me pick my next set of plugs
- Coolant surge tank return line location
- Overboosting problem..
- Little dent in deck of ls2
- 90* Coupler on Throttle body question
- Figuring out Turbo For Setup
