- My new turbo exhaust, and the neat old muffler
- What head gasket size do I need?????
- T76 Turbo dyno results in...HELP! Need a diagnosis...
- intake leaks...
- How long would one expect the head unit last on a Procharger D1SC
- Max Power of Stock 346 TTi
- should I go STS or Procharger?
- gt 47 88mm
- How much?
- The firechikn is alive, finally.
- Procharger P1SC
- RFI: Samples of cam overlap
- GT47-85 question
- Dyno tomorrow on T-trim 383. Any predictions?
- BOV,wastegate sizing help
- Sts
- Bad heat soaking on upper intake piping
- Anyone notice new 6.0/6.2 MLS gaskets are 5-layer??
- Kenne Bell f-body?
- FI motor without FI
- Procharged LT1 383, what injectors?
- Procharger rebuild(EPP)
- Help needed... cam and injectors for Turbo Project
- What are everyones thoughts on compound charging?
- high mileage boost?
- Need second opinions on BIG Whipple build
- deck thickness on heads
- Correct intercooler
- hay Bob @ EPP thanks!!!!!(pics)
- Pic's of Steve Verplank's Mazda RX7 from Superchevy at OPR/ATI booth this Summer
- restrictor plate on vortech, will seals live ?
- 8.5 psi D1sc results @ GaFBody Shootout
- need help and info on this turbo?asap
- Radical boost spike 41psi!!!
- BMR and UMI Please come in
- Fixed small leaks, and holy sh*t
- Procharger
- Twins location in an f-body. Starting to brainstorm new set up
- how does this sound?
- Intercooler install instructions??
- Got my 8's with the ttv6
- Single Digit Midget M6
- what goes where?
- Need some advise so I can make a decision
- Boost and lifting heads!?!?!?
- Home built Hot Parts Come on In!
- FI Newbie question
- Remote/low mount turbo oil pump
- Snow Performance Boost Cooler ?
- Horsepower gains from pounds of boost.Weird question
- STS Questions
- anyone want to guess what my car will make
- Boost Leak
- finally getting the hang of driving my car
- Crap...FP blowing fuses again....getting too hot I think...
- Silver Dollar Raceway "Results"
- How meth affects current tune? And how to fix boost spike?
- so i was bored today and fabbed up a different alternator bracket
- Those with a Vortech V-9 G-trim
- C5 procharger bracket?
- stainless steel vs mild steel vs aluminized
- Front O2's?
- Gen tt turbo kit
- TTi Street Kit question ?
- Supercharger rebuild?
- Shaft Play Question...
- questions on what i need for safe twin gt30's
- Need help with a seal on a procharger..
- building 383 forged ls6, what compresion?
- f1 procharger?
- Gauge Install pics on my 408/T88 Build
- PCM for turbo car
- anyone use a autometer 4376 boost gauge?
- Red Carpet Turbo Kit ????
- "Flex Joint" & Scav. Pump Q's
- who has experience with a whipple/kb on an ls1? not an fbody
- Really good Boost question.
- Boost Vs head gaskets or??
- Nitrous with turbo?
- Forced Induction and 76GTS Turbo!!!
- How to keep car cool with IC infront of condensor?
- some turbo Q's(turbo gurus welcome)
- How to attach 4" pipe to D1SC inlet?
- expansion joint
- Ran 9.3 at 144mph today at Bristol.
- Whats your timing free revving and under load
- Noob BOV Q?
- in-cabin intercooler
- I think Las Vegas is one of the worst drag racing facilities in the US
- *** Cartek Turbo Cam and AFR 225 Heads 4 Sale , Track Proven 9.3 at 149 ***
- *** Big-Bore Boost Pistons 4-Sale ***
- what's my compression & how long will this setup last?
- Ported heads and bigger cam or don't bother?
- procharger question
- EGT's on gas turbos
- Anyone port the head chambers to drop compression.
- GT47-88 vs GT55-91 question
- opinions on these turbos for a 408
- Anyone have their car feel slower after getting more traction?
- 450hp turbo ls1
- Kb Blower
- double keyed crank
- Turbo Oil Drain Back Question
- Fuel for FI
- Anyone heard of Q16 Fuel?
- Turbo Guys come on in!
- Decreasing spool time with tuning
- Two TT cars + 3800da + bad track prep =
- Radiator Cap Question
- Why do superchargers give positive displacement?
- STS Turbo Tuck
- supercharging a stocker
- Couple FI questions.....
- hoow much boost should i run with this combo
- quick question
- Ideas on how to change current tune when adding Alky?
- water-to-air leakage problem
- Regret
- New Product: GT45F and GT45FX Non-ball bearing now available
- Need Manual Boost Controller Directions. (Turbonetics)
- FI kit for 496 (8.1L)?
- Vortech SQ trim users inside please
- anyone know a place that sells or has done hot parts for large frame turbo C5 kits?
- Electric Turbo?wtf
- Looking to get a TT system
- Testing our GTO Gen-TTR Intercooled Twin Turbo System
- MSBC-1 user help
- Explanation for oil line restrictor?
- Screened inlet hat pics on a F1R?
- Aftermarket heads worth it?
- 918s hold moderate boost levels?
- Need some help on a NASTY project
- Cam Selection
- Newbie turbo questions
- S91 408 TH400.. Need new cam specs..Or do I?
- Winning streak broken,but new best e.t.
- Some H/C Rear Mount Turbo dyno results FINALLY...
- Accessory belt rubbing with ATI
- So who has the fastest...
- latest progress on my Magnuson MP122HH setup
- O-Ringed Block: Head Question
- ETP Canted Valve Heads and Billet Intake
- 2XXX hp LSX Build Pics
- Does this concern anyone else?
- Old School car/ new technology
- I need your opinions guys
- Anyone NOT running an IC?
- Hit 140 MPH today, TTi Race kit
- High static compression and forced induction
- Need Incon Install help please
- Everyone Welcome - NA$TY-TA JR!!!
- STS without downpipe ok?
- New motor and turbo kit,blowing smoke during decel.
- turbo ls1 advice
- Thanks Canada !
- Innovative Turbo stole our turbo!
- Possible causes of leaning out?
- STS Owners with wrapped exhaust, 2 questions
- Large Turbo > Thermostat Housing
- Base Tune For A F1a 402 Setup W/bigstuff 3
- T76 Turbo. Stock LS1
- Sts Instant Rebate?
- Twin A2W intercoolers Vs 1 Big A2W
- low boost...lag...general bs to pass the time
- Any pics of T6 Thumper setups with truck manis?
- what springs for sts kit?
- MP T70 power rating? Can't find them anywhere?
- Help with supercharged plug gaps!!!
- Flex piping for turbos?
- Does anyone know where to get alt bracket
- My LS1 GT-47 240sx
- Finished Turbo crossover pipe - single or twin 44mm gates??
- best combo for a D1SC Z06 vette
- Engine swap question.
- Vortec
- Finally made some 2007 hits, 9.44@144 and 1.35 on DR's
- building my own CAI
- Who running DARTS with their single behive PSI springs on boosted application?
- STS Experts advice needed!!
- Who sells nice flex sections for turbo app.
- TRT Intercooler for STS kit Installation
- procharger d1sc oil problems?
- Quick boost referanced regulator ????
- Looking for head/intake suggestions for D1SC
- S88 turbo
- is it true ?????
- oil pan/bellhousing integrity.
- EPP Banner Contest $50 gift certificate
- Any TT sts F-body guys?
- Suspension
- what mass air meter should i use?
- My own '99 Hugger Orange Z28 is finally getting put back together!
- STS and Cats
- New turbocar out and testing...
- procharger ?
- Cant find 4" to 3" silicon 90 for turbo inlet.
- COMP 232/240 .595/.608 115LSA RPM Range?
- polished p1sc for corvette for sale cheap!
- use my ported ls1 heads or go stock 317's
- head gaskets?????
- Head Gasket - 370ci, O-Ringed 317 heads
- Times and RWHP. Big build
- Dyno Pegged @ TTI
- EST 1/4 mile
- Need better T-bolts. Spring loaded? "Constant-Torque"?
- Waste gate vlv
- twin gt42 76mm
- Iron 420", Dart 225, D1
- 317 heads any good or go w/ aftermarket?
- LS1 Turbo Kit on a LT1??
- LS2 or LS6 intake?
- SPEED INC. @ drag week
- Thoughts on a PT91 vs. GT47-88?
- The Red Rocket is ALIVE!!
- Max boost for a stock MAP sensor
- Charged and Stroked
- Oh yes. It's my turn, PCV + STS + No Oil Pan tapping
- Need Help??? Remote mount turbo leaking oil out exhaust?
- Question... Twin Turbo truck manifold kit with AC.... thinking...
- Procharger+Roadracing?
- F2 Procharger C5 L92 and E85= 1000+
- Pegged the Dyno.
- Ohio Boys Record Breaking Video!
- Would changing my exhaust effect my tube (A/F)?
- D1SC,....Loosing Boost at 4K rpm.
- Ohio Boys in the 7's and another Win!!!!
- 750 WHP LS1 Turbo LS1 build
- STS Turbo kit near gas tank???
- Paxton S/C Severe Whining??? Help
- whats a good gap for 10 psi on TR6s
- Lt1/4 Fi
- ordering oil feed lines right now... have couple questions
- Intercooler HELP!
- New Dyno numbers @ 8.5 psi
- pyrometer gauge or EGT
- Vacuum Boost Manifold?
- Threaded IAT pt #?
- Idler Pulley for D1SC and Service
- Dead MAP?
- 88 Degrees 4200DA shakedown run with the Speed Inc street kit on the Hawk.
- what do you think
- Will this be a good setup?
- Looking for a Specific Boost Piston
- E Boost 2, help fast
- Boost Leak Pressure Tester 2.5
- Ohio Boys! Damn!!!
- Epp Rocks!!
- Meth blockage
- Who's pushing big power & low ETs w/ 6.0L heads?
- An early Friday treat
