- 3-bar map sensor
- STS Help...
- different prochargers???
- Which BOVs and WGs are preferred???
- Procharger Install Help
- Aps manifolds
- Why Am I Losing Boost - Incon Setup
- Finished! C5 vette single T4 turbo setup
- Those with the 8-Rib SDCE setup
- A2W intercooler help...
- Anyone using Trick Flow heads
- Going Turbo :D
- Pics of boost gauges/controller in dash vents,T/A
- Turbo Spooling #'s!!
- Now is the time!!! It wont be any cheaper!!
- Piston Rings Boosted?
- after catchcan runs like sh@$%
- Turbo specific engine build ?
- gt45 on stock motor...any comment!!
- Turbo Needed
- low oil pressure, is my ls1 on the way out
- sp motorsports west coast killer
- Pick my cam for me
- crank pulley
- Prosport Gauges - Any experience or info
- Tt 04 Gto
- PT98/88 on a 347?
- what do you guys think
- Lq9 and Lq4 heads
- Stock Cube LS1, Which Turbo?
- ??? For you OFI owners
- Incon tt Stage 1turbos HC408 or LC364
- confirm my fear.....
- Looking for 2nd opinions.... Forced Induction camshaft selection...
- highest psi on stock springs
- Vortech T-trim upgrade from S-trim
- APS F-body kit is here (56k take a hike)
- 07 Suburban with a SC
- trans upgrades for sts ???
- All ATI P1 or D1 owners inside please
- got some dyno numbers on T67/403 mis-matched combo
- what to tune!?
- sts turbo kit, good or bad?
- Why Is This Slow!?!?
- How much more power
- INCON FP regulator help
- Cartek Aps Tt Forged 347 Final Numbers 907rwh
- Getting cold, fresh air into a maggied '06 GTO. any ideas?
- Which cam to go with for a D1SC
- I just inherited this!!
- Need some help...turbo troubles
- New Custom Y-pipe
- What would you consider a perfect daily driven FI car?
- TT GTO back again...
- Black dust inside procharger outlet & intercooler tubes... WTF?
- STS cam confusion...
- Which Supercharger?
- OHIO BOYS Video
- any FMIC kits that allow minimal work/mods to bumper?
- Help! Magnafuel pump blowing fuses!
- royal purple =sludge
- Total Seal AP Steel Ring Gap
- Red Rocket meets Sticker Dude!!
- Megasonic BOV with Video
- Power steering fluid boiling!
- how many 8/9sec. turbo cars run air filters?
- 100% Methanol or 50/50 Mix?
- Can you mount turbos vertically?
- Which Twin Turbo kit to buy for an F-Body? APS or Gen TT?
- LQ9 main caps srenth DO or DONT!!!
- And the fun begins
- Help building Turbo Motor
- Calculating Compression Ratio
- Gale Banks Turbos?
- need help installing synergy 2-step for an M6
- newbie to FI... help me!
- Cranking compression of a 8.5 to 1 motor?
- Effects of cam timing on a turbo motor
- Ok Turbo Cam Masters!!
- Twin turbos
- 408 Iron Block with what turbo??
- Maggie + H/C
- Stay D1 or go F1????????
- how much boost stock ls1
- video sticky
- Gen TT
- turbocharged c5
- STS F-Bodies in the 10's
- 3" or 4" intercooler???
- 8.6:1 347 with 14psi,any thoughts?
- MSD Timing twister? MAP sensor boost retard
- solid supercharger tensioner or spring loaded
- Hp Performance Turbo Kit V Sts
- IAT sensor leaking air through it?
- Finished My D1 Setup Sunday!
- Turbo Newbie Question
- Firehawk that we built an LS2 for last year is now going to get an APS twin turbo kit
- 423" stroker, Afr 225 heads, F1a Procharger w/front mount.
- Whats the best Oil feed line kit?
- AFR 227's and Procharger
- LM Speed Maggie Kit For F Body
- 408 with a d1sc?
- Looking for high quality digital boost gauge.
- Cannot get Procharger Belt on....Help
- Exhaust pressure gauge. Who makes a good one?
- Help with prepping a motor for Turbo
- Wideband gauge
- sts and a 75 shot
- Iron or Aluminum for me?
- Turbo and Tuning problems
- To stroke or not to stroke???
- Joy after Heartache!
- how many have a kenne bell sup up for a vette
- finally good pics of setup
- Anyoe interested in my old blower verter? TCT
- Why hasnt someone come up with an STS intercooler??
- vic jr intake worth it for a turbo setup?
- Questions about BOVs
- Aps Gto
- How important are cooler plugs?
- Congrats Ohio Boys 8.06 @ 182
- Can a non-intercooled Magnacharger fit a stock C5 hood?
- What boost are you getting with your pulleys?
- ATI balancer + Procharger Problem with pics!
- Snake Slayer is Back!
- Turbo Car overheating
- Front Mount Turbo or Procharger?
- -25cc dish to much w/ 71cc combustion chambers
- BigStuff3 Boost control
- overheating issues =(
- radix 122 model infor
- procharger fan help
- 36.5" Procharger Belt
- Procharger pulley Question
- Blower or Turbo with a motor plate
- Some turbo projects might actually end...
- project last head gaskets evarr!
- Head flow question, anyone have examples?
- F-1A 427 l92 heads 219 cam 858 RWHP
- Procharger/Turbo?
- What size intercooler tubing?
- 408 with Procharger??
- Dyno tune on Monday, want to guess RWHP and RWTQ?
- turbo cam higher lsa and exhust right?
- APS F body twin turbo system $5495 twin turbo deal extended to Oct 07
- Question about boost.....
- Average Procharger boost with 4.5 pulley?
- Just fired up my 3.3L Whipple on my C5 Z06
- Procharger Help
- Twin turbo F-body or vette vids?
- whats the progress or updates on your project?
- ATI ProCharger Clocking Guide
- My OFI kit Dyno results!
- Anyone running a S-trim?
- What block to use
- Procharger W/ Nos? How and How Much
- Procharger Air filter
- Any reputable shops that will work on a turbo LS1 in Alabama?
- Is Forced Induction Feasible With My Current Setup?
- Theory question on boost.
- ls6 vs Fast 90 for F/I
- NemesisC5: Customized and Supercharged
- Maggie Dyno Sheet
- shims in a BOV
- Maggie M122HH For L92 Heads?
- Building your budget stock block....
- Supercharger Plus Turbo
- looking for hot side vendor
- how much power and boost?
- LT1 turbo. best heads/intake?
- Broke alternator with a D1
- Twin turbo exhaust
- S88 408 Turbo build. What size head valves
- i have guys telling me not to run c16. need some experience here
- ATI pulley bolt, washer, and pin question
- catch can setup help please
- Turbo line questions
- Need Advice....Misfire and PCV line disconnected
- Post pics of your DIY turbo.
- L92 heads for forced induction?
- What head Gaskets for TT 346?
- Plans for the Shop Car.
- 408+ ci with FI, need suggestions
- Traction Control and a Turbo?
- life of a stock A4 behind a procharger???
- fast 90 or carb'd with elbow
- pump gas to c16 tuning changes
- turbo or supercharger
- Cartek 2x w/ STS?
- Quick "bursts" before boost builds?
- where can i find a good procharger for lt1?
- APS GTO twin turbo system - $5995 inc free delivery and free set of 60 lb injectors
- Some pics of my new air to water setup.
- Aps turbo kit
- Guys with P-1SC Prochargers?
- Keyed My crank today!
- Is this a good turbo cam?228/232 (int. = .588, exh. = .574) 115+2 lsa
- I wonder if i can use boost to break this one!
- boost dropping ?
- Need some insight on a built/blown LT1
- most power out of 93 octane
- Sts Help!
- Power question. Turbo guys come in!
- building a turbo ls1 (need some help)
- Opinions welcome on intercooler selection
- vacuum
- Waste gates and b.o.v
- 2.65 Pulley On A Magnacharger...
- first timer needing advice
- Alternative to Procharger Plenum?
- STS Exhaust Wrapping Review
- how much room do I have
- My Incon Install
- Gen-TT Truck Systems
- Looking to upgrade my fuel system can someone point me in the right direction
- Checking out Meth/Water/Alcohol kits. Any Cooling Mist users? Snow Performance?
- Big Cubes + Procharger?
- Intercooler option from EPP
- what's everyone using for heads on a single turbo 347?
- D1SC Procharger?
- D1SC Low boost application..
- 2-step question
- Intercooler mount
- How to figure out D1 boost.
- Co2 && Boost controllers
- Possible vacuum leak?
- D1 408 questions
- Superman09 hits the track, first time with FI. Need input....
- Horsepower question.
- SC Impeller Speed Equation
- Any problem injecting meth directly opposed to the incoming airstream?
- Sucking in Water when it rains
- Good & Bad New's!!
- single plane boost & n20
- centrifugal vs. roots
- Velocity rings for Superchargers-gain 1 to 3 psi?
- any body used this nitrous controller with there boost setup
- Anyone use this zex turbo n20 kit
- PROCHARGER Guys Please Come In
- I got the $$ Procharger or Turbo, help me decide.
- vortech problems
- All stroked and blown Lsx Cars
- Purchased a Vortech kit now what ??
- what happened to my main bearings?
- help with forged internals
- 2 Buy used boosted 408" iron shortblock or no?? "4500" miles, seen 700+rwhp already
- electric waste gate or time based boost controller
- Pistons.......Search times out
