- A little help choosing a fuel system
- a new catch can option from...home depot?
- 1996 Vortech ignition recomendations.
- Porting help all stock
- How would this cam work for FI in a 408
- What Intercooler? SS or Non SS Piping?
- Methanol Injection
- Can we discuss air filters?
- Over spinning a D1?
- got the 6 point roll bar installed. just need tires
- what do you think it will make on HP
- 1999-2002 F-Body Big Stuff 3 Integration Harness (Plug and Play)
- Clutch ?
- How to tell if your BOV is bad?and a turbo too.
- Acceleronics Versafueler w/ 96# Injectors question?
- STS boost!!!!
- Threaded LS1 IAT sensor part #?
- ST80 vs T76gts ***PICS***
- intercooler integrated with intake manifold?
- help with my STS oil problem
- Backpressure Sensor ??
- belt length for a p1sc 3.5 pulley
- anyone makes a truck manifold pipe kit?
- Boosted 6.0 Intake Manifold
- Twin Turbo Recommendations
- I hope that i have better luck here...A/W IC gurus... need input
- exhaust wrap for sts turbo
- Thumbs Up To Bob@epp!!!!!!!!
- Can someone guide me..
- guesstamate on what rwhp i should be able to make
- New here, How bad is this cam going to hurt me.
- need advise
- STS Turbos On Sale / Installation
- good read on supercharging...
- Kenne Bell/D1SC cam difference (For C5)
- sdce owners chime in please
- My Lucky Day, I Won The $500 A&A Corvette Online Givaway!!!!!!
- Timeslip with 6.0L Turbo GN
- L92 heads with a 122HH Maggie?
- Debrits & STS (pics)
- Best Cam for STS turbo setup?
- Ohio Boost System
- Injectors for the STS?
- DIY PT88 kit
- Whats the highest hp you've seen on stock cubes and 93 octane?
- LS1 TT for 67 Nova
- Anyone running Patriot 6.0L heads??
- Question
- Just bought a 6.0 block, 370 or 408
- EPP doing an APS twin turbo installation on an '07 C6.
- 03 Silverado SS 76mm build
- Lysholm instead of root type...
- STS turbo w/ g5x3 cam
- Turbo Tuning Q's
- New Pics of my 348ci/ GT47-88 Setup
- Overspinning Your Centrifugal Blower??
- Manual Boost controller hookup
- Still cant make boost
- 347, 15 psi, pump gas only, mild cam, what SCR
- V6 Turbo
- Silicone Coupler for A2W intercooler help...
- Another update on my build...installed the A2W intercooler
- Procharger leaking oil?
- ls2 going TT kit what heads?
- Magnacharger pics and dyno
- where can i get a F1,F1A,F1R?
- How much power will stock internals hold?
- durability of a stock boosted 5.3 at 600rwhp
- Boost Problem on launch
- Help - what's this
- LT1 hotside
- Smaller pulley = higher boost at low RPM?
- What thickness Head gaskets do I need?
- Vortec? naw. Magnuson? Naw. 8-71? PFFF
- Anyone running 418 cid with boost?
- SX88 Compressor wheel
- Danm!
- Lookin' for Procharger pics
- Magnacharger Boost ??
- got my blown car to run cool... finally!
- Anyone have pics of there Vortech YSI Setup?
- Intake Elbow
- BEST Turbo help me out guys.
- Good on almost stock?
- Have you ever seen this much room for a turbo?
- blown/boosted 454 LSx, worth the coin, worth the effort?
- Gen-TT Twin turbo install today :)
- Low compression, Incon kit & rear gearing.
- which tt setup , aps, ls1turbo, or custom?
- OFI 4" DP Install Pics
- 408 with rear mount 76 GTS dyno
- missing boss on lq4
- STS 04 GTO... 649rwhp/625lb ft
- the beef is finally here....
- heat wrapping
- car having trouble starting
- Anyone using a TRT FMIC...
- LS7 with KB / Lysholm / Autorotor or dual Rotrex
- AIT...too hot?
- Help with MBC, cant add more boost
- turbo+M6= what rear gears
- Cammed LS2 GTO adding ATI D1SC...do I have the right parts...?
- air to water intercooler questions...
- 87 Buick GN, LS1 turbo video
- New dyno #'s for my TT v6 firebird
- E85 + 93???
- Which is the best supercharger? 4.5 & 6 PSI. And the best price for the LT1?
- P/N for 3 bar map sensor OEM Z06 manny
- Fan question?
- Putting together my first FI car,have some ???
- MS3 ok for boost?
- vortech v9(non-sq) kit videos?
- car stalls
- T4 GT66 for 346?!?
- Anyone know where I can get 4" v-band clamps
- Is it ture?
- Who's running Methanol?
- Is anyone running nitrous with there turbo setup?
- Stock LT1 Camaro with STS Setup
- Realistic gains going to an F1A from a D1SC?
- Twin turbo v6 firebird pb vids
- Custom Cam
- Heads lifting under boost: avoid?
- help! need a little info about a paxton supercharger, way to low boost,
- LSX High HP
- eBay flanges vs. StainlessWorks flanges
- Good Deal or Not?
- FMIC Kits
- Still planning FMIC or 4.5's ?
- Thinkin about a Procharger
- Pic of my car on a dry lakebed at sunset
- ForcedInductions.com ??
- Turbo Guys...what do you do for tuning?
- F1R vs F2
- Thinking of Turbo setup, please comment !
- Update for my car
- two totally unrelated turbo questions
- plumbing a boost gauge
- T66 big enough for 370ci?
- turbo gurus ? for ya
- Supercharger Cam
- Need a lil Help...Rear turbo want more power any suggestions?
- What brand?
- hell fire rings??
- Turbo, intercooler and fueling questions
- best turbo setup
- ZO6 comparison: TTI - APS - PROCHARGER
- Just a curious question about out D1SC....
- Needed good tuner in Maryland
- How much boost???
- who wants trouble...
- INCON Help.
- Pro Products Throttle Body
- cme and sts turbo
- Forced induction parts for sale
- installing turbo in my car
- Question - TT and Heat
- Tuning/Drivetrain question
- procharged car with high miles??
- steel wastegate flange
- Need help bad!!! PTS and other boss alt guys please come in
- ATI Pin on crank snapped
- eBay SBC Turbo Set-up
- oil in turbo- hot and cold side
- mustang d1 headunit
- Best manifold for procharged sbc?
- a few wiring questions for you turbo guys- fans- map- etcc
- Spark plug gap
- Your opinions on a custom spec'ed turbo cam
- Short video of ST74 on 3.8L
- who's running F/I on a stock auto tranny?
- wastegate distance
- High power turbo guys- what timing?
- Back from the Dyno today, TTi Race kit
- need a good fuel pump controller
- best f bod twin kit
- gt-47 air filter
- Huge thanks to eb0z06 and SLED28!!!!
- Stewart Warner Boost Gauge Install
- PIcs of my 408 F1R, Becool setup
- Which centri head units can handle a 454?
- Tial 38mm Wastegate and 50mm BOV sufficient?
- a little FI predicament!
- What exhaust housing for a 402 w/76mm?
- Catch can eliminator!!
- help, oil out sts turbo exhaust
- Turbo car overheating
- S88 on a 408 with stock pcm possible??
- 6.0 truck turbo Q's
- Upping the boost, couple questions.
- Twin Turbo LQ4
- Wrapping hot parts with header wrap *pics*
- 6-71 intake prices
- which is better...procharger or vortech
- thinking about turbo
- questions on converter that does well w/sts
- Twin Turbo car in FS section
- supercharger+turbo?
- ok I am going crazy....
- Trickflow 220/224 cam for turbo?
- How Many Of You FI Guys Are Running An A/C
- Intake manifold for FI
- Realistically how bad will my cam hurt me?
- whipple dragon
- PVC Catch can system.... Final conclusive answer
- Looked high and low for 1" NPT/Barb fittings
- Polished cold parts...
- automatic trans...blowoff valve?
- What Boost Pump ????
- is this to good to be true..
- Planning my FI build
- EBoost 2 ??
- Should I do this or not?
- What boost to run?
- Pics Custom Truck Manifold kit
- Turbo guys: BOV, wastegate, and BC
- The ultimate turbo street setup!!!
- Any of you FI guys need a good fuel set up?
- 1,000+rwhp & 6-speed
- Mustang P1SC on an ls1?
- Help me pick pistons/rings/rods
- Procharger oil resivoir under pressure
- ma
- Question. Dont get mad.
- Turbo selection RWD Grand prix drag car
- oil dip stick relocation
- Advise On Car Build
- Help!!!
- Made alot of progress on my GT47 setup...pics within
- Welp...
- IAT sensor in air intake for meth injection
- Dr Turbo and JZ...BCI-18 and UHP questions.
- guys with sdce setup chime in please, anyone having any problems?
- procharged now
- S/C and gas mileage on an h/c car?
- Turbo Help
- pics of altenator relocation brackets?
- First Track Result's With New Setup!!!
- Turbo Kit Prices???
- Just test drove new build for first time!!!
- yes another 2 step thread....finally found 1
- Some vids of twin turbo v6 firebird
- Fired up the 'ol stock LT1
- Stall question...need to get this right
- procharging a 94 t/a
- Heads or Headers for an otherwise stock LS2 supercharged
- New Sponsor: KY Turbo & Perfomance
- Turbo system for $2225 ?!!?!
- Boost
- Procharger guys what exhaust do you have?
