View Full Version : Forced Induction
  1. TQ Converter in TH400 with Laggy Turbo
  2. STS and my results!
  3. need some help with a FI and NOS set up
  4. Cam for LM Speed Magnacharger?
  5. Kinda wanting to try a homemade kit.
  6. wastegate effecting tune??
  7. 408 ci with TTi street kit?
  8. Which setup?
  9. Finally took it out to the track
  10. iridium plugs yes or no
  11. L92 turbo set-up
  12. internal volume Maggie vs ls1 /ls6 manifold
  13. bolt thread size vortech pully ?
  14. ebay turbo kit
  15. why does pulley size relate to boost different from one car to the next?
  16. If I used a REAL octane booster, how much timing can I add in boost?
  17. boost controller
  18. Street/Strip Single on T4
  19. What the cheapest I could find a used C5 Maggie for?
  20. Couple short videos of my Camaro idling in the garage.
  21. Spray small dry off the line (turbo)
  22. New track time with the Turbo car
  23. TTi Race kit DONE!
  24. FI Maintenence/Problems
  25. What Is Required??
  26. Is this a good Turbo cam?
  27. Oil problem with turbo
  28. on the dyno .68 to .96ar swap
  29. STS KIT-Is it possible to have toooo much vacuum pressure?
  30. Turbo hose
  31. MAF/boost question
  32. LS6 or FAST intake worth it with Turbo setup?
  33. :( sts.....car is shaking and stumbling
  34. 9 lbs boost supercharger/ ngk tr6 plugs?
  35. Turbo/ cam match questions
  36. STS guys, what are you doing with radiator shroud?
  37. A&A Vortech SQ being installed today.
  38. Are you guys changing Rods when changing valve springs?
  39. Wanna see a pro charger w/ 50lbs of boost
  40. My DIY install is almost done
  41. New TTi Race Kit getting closer...
  42. Loudest Supercharger for LS1
  43. Comparison on intake manifolds Carb vs. FAST vs. LS6 vs. LS1
  44. Going With A Procharger
  45. Where has turbos IN STOCK.
  46. A little help with chevelle turbo
  47. low 9/high 8 sec. turbo build questions...
  48. STS charge pipe size? Downpipe? FMIC w/fogs?
  49. where to buy procharger pulleys
  50. STS Guys, where does this hose go?
  51. valve spring sizing and boost
  52. please help me with FAST intake
  53. PLEASE HELP Identify this Turbo/Wheel/Hotside
  54. Home built D1-SC: part 3 (Dyno)
  55. Does a fluid filled harmonic balancer stop false knock readings?
  56. Vortech guys. Come in here please!
  57. Pictures of one of my side projects... ST74 3.8L
  58. Do you have a Speed Inc. kit?
  59. Meth/Alky only???
  60. Turbo numbers???
  61. What ya think of this setup
  62. 5" silicone?
  63. where to buy 5" flared for the turbo ?
  64. New Car/New Build Part 3. TC76MPS Dyno numbers inside
  65. blowing out the dip stick under boost!
  66. how much boost one the street?
  67. Anyone running a meth injection kit please chime in!
  68. STS guys spark plug gap
  69. cam question
  70. gates belt part#???
  71. what size turbo???
  72. procharger boost
  73. 920 RWHP/ 820 RWTQ ! The cdnperf.com motor just keeps going !
  74. What fans do you guys run and results?
  75. WG spring
  76. What's the best turbo size for a 346?
  77. 15psi on the rev limiter....now a mis...??
  78. Better Head?
  79. 5.3 Liter Turbo Conquest...
  80. Vortech Supercharged LS1
  81. silencing a turbo car
  82. BOV?/Help
  83. Any body out there using fast xfi on boosted ls1's
  84. A few Turbo questions
  85. Pushing a Stock Crank.... to Far???
  86. Going to try a little camshaft experiment..
  87. max boost on vortech V-9 SQ G-Trim with intercooler?
  88. Best way to break in a new motor with boost?
  89. im pulling my heads, should i switch to the big ass cometic gaskets? (.071)
  90. Very Small Turbo
  91. tti street kit- tensioner and alt bracket q
  92. FI Motor, Need Advice
  93. 1000 rwhp-aluminum or iron block
  94. In Iraq saving money for a ...
  95. front mounted turbo w/ truck manifolds guys come in
  96. LVMS Drag strip, the black hole of HP
  97. pease look inside
  98. Need help finding which spark plug I need to run...
  99. What year Iron Block to reuse my head/main studs from '99 LS1 block?
  100. will not idle???
  101. Do i need to worry about MAP sensor?
  102. Ran a new PB with issues and would like some advice (a bit of a read)
  103. MAF question
  104. ATI belt issues, first style C5 setup
  105. Which turbo kit for a C6?
  106. What do you guys think of this FI setup?
  107. TT setup q....
  108. D1SC Guesswork
  109. What shold i do?
  110. Supercharged LT1... what spark plugs and gap do you guys prefer??
  111. Turbo setup
  112. HP vs MAF Flow and dyn/cyl
  113. D1sc on a 427??
  114. 800rwhp 800rwtq
  115. Belt size when using truck manifolds and relocating the alt up top ?
  116. Do turbo's cause widebands to jump around?
  117. Broken Valve Spring??
  118. simple question
  119. Carb Intake/ Elbow throttle cable?
  120. How would a turbo do with my motor?
  121. LSX block work moving forward
  122. Im new to turbo help plz
  123. does anyone know how to get in touch with OFI??
  124. What to do about breather, brake booster, and PCV?
  125. who has the best price on stainless mandrel bent pipe?
  126. Difference between trims.
  127. 3bar sensor, how do you keep it plugged in the intake under boost?
  128. Who would be best to spec a cam for sts?
  129. Bore + stroke + Boost = ?????
  130. VP Race Fuel. 14% HP Gain?
  131. I Got Screwed By Vortech Today!!!!
  132. more ofi results
  133. On the Rollers Again.. Better...
  134. Need turbo selection help for TT corvette.
  135. Any prep work?
  136. t-66 with stock motor for 550 rwhp. or suggestions on turbo
  137. What effects have you seen from changing the rear gear ratio of your car?
  138. Max Power with Stock ATI Intercoolers
  139. Need intercooler tubing or header tubing? We can mandrel bend you whatever you need.
  140. what do i have here? unknown turbo.
  141. bmr k member install how hard ??
  142. Highest fast intake psi on forced induction cars?
  143. Anyone running e85 yet?
  144. Turbo Auto vs Turbo 6 speed from 40 to 160mph??
  145. Turbo boost and low gearing question
  146. anyone know if a Torquer v2 will work with Turbo??/
  147. Any site sponsors selling D1SC's?
  148. TTi Street Kit goes 11.08!
  149. Anyone seen this happen before?...
  150. T70 w/ T3 Flange on Stock cubes
  151. twin roots blowers
  152. sts kit
  153. The latest project
  154. possibly a sill noob question
  155. 06 Silverado 5.3 Question
  156. Questions about piping and welding for hot side...
  157. F-body Roots blower and meth injection questions
  158. Car back fires while Entering boost
  159. Need Help Asap!!!!
  160. are the ATI s/c's really loud?
  161. LSX = How much Boost?
  162. got my 9 second daily driver back friday
  163. please help 408 turbo ?????
  164. Where to tie in boost reference for fpr and gauge???
  165. STS on a 6-speed?
  166. Ls1 twin turbo
  167. Incon People Inside
  168. kenne bell ??? is this quite possible??
  169. 408ci Magnacharged Cam?
  170. ??? about f1 procharger..
  171. Help with procharger
  172. boost and fuel pressure sgague install
  173. Will these heads work OK for FI?
  174. want firebird fmic pics
  175. Vortech supercharger
  176. Pete's "Nu Breed" '69 Twin Turbo Convertible Camaro
  177. How Can I Make This Inlet Pipe?
  178. pulling timing based on elapsed time
  179. Twin turbo trans am build
  180. Large Turbo - how to support it?
  181. Now THIS is a turbo.
  182. Turbo cam selection
  183. Synchronic Wastegate
  184. magnachargers?????
  185. Running Diesel Turbo on LS1
  186. Turbo CHEVY Silverado 4.3L V6 (ideas)
  187. F series prochargers?
  188. LS6 intake, and what throttle body?
  189. Anyone running a T3/T4 twin setup?? Incon?
  190. Track Results of 2.5" insulated exhaust for rear mount setup
  191. Weber Racing Equipment FI Sale. Shortblocks, Precision Turbo, and Acceleronics
  192. Would you run a Incon kit w/no filters?
  193. Procharger Oil Leak
  194. Turbo Build
  195. Anyone have numbers on there PTK setup
  196. Calculation for Compression Ratio?
  197. Help..on a custom turbo system
  198. high iats during normal driving?
  199. Biggest cam compatible with FI??
  200. CI's, CR's and boost affect timing?
  201. Incon kit up for inspection
  202. Need to go from a tial bov to a recirculating type..
  203. Sdce???
  204. where is your procharged lsx making peak HP?
  205. stock camaro/TA heads with blower
  206. HELLFIRE rings?? How much BOOST
  207. exhaust wrap
  208. how much hp can a stock ls1 take?
  209. Boost Gauge Installation help
  210. Ring gap different with FI rather than N20?
  211. EXPERT HELP NEEDED - What twins for my setup?
  212. Inlet turbo ducting....PICS
  213. Jets for meth kit
  214. My 02 SS Magnacharger/h/c/exhaust/suspension build
  215. need some turbo fitment help with my 3.8
  216. whats a used procharger worth???
  217. BEST T4 FLANGE TURBO on the market
  218. PC STS Pipes
  219. o2's for Forced Induction?
  220. wanting to trade my 98 GTP for LS1 F.I. kit
  221. LS1 vs. LS6 intake and few other questions
  222. 2000 gmc sierra 5.3
  223. APS dyno numbers on my 05 GTO :)
  224. Help-need to reduce power-bigger pulley or less timing?
  225. Can anyone ID this turbo... STS haters beware!
  226. Radiator dimensions?
  227. Gen-TT LSX Boost Proof Fuel Rails
  228. Cavalier Remote Setup
  229. What wideband to tune turbo car?
  230. Stock suspension record going down!!!!
  231. who has side exit exhaust?
  232. New Et Record For Turbo!!!
  233. 6 bolt heads listing
  234. need to find 3tenths in the quarter.....
  235. FI and fuel
  236. Blower Belt instalation?
  237. boost within the system, SC.
  238. Does this look like a 10sec. pass?
  239. Paging Incon people need some info please.
  240. Twin Turbo LS7
  241. how do is the best way to get oil to turbos
  242. How much power will twin 2.5" IC tubing support?
  243. anybody have any exhaust wrap left over they want to get rid of cheap?
  244. Mean Turbo TA...... Pic's
  245. In need of some advice, switching from n2o to turbo....
  246. v band clamp question
  247. Procharger Guys.....help
  248. Did your Procharger change in sound as it broke in?
  249. OFI low/med boost results
  250. Need some help for the Magna Charger!
