- why does power curve get bumpy after 5,200 (centri blower)
- Maintenance/Oil changes on turbo car.
- new project..need help on a turbo size
- 57 chevy truck turbo ls1 build
- anyone been successful in geting a 10-12 rib belt on an F body?
- Opinions on cross flow/dual pass or conventional down flow radiators?
- Procharger bracket
- Suggest a turbo for my setup??
- Spare Parts Sleeper (99 GMC Turbo Build)
- How to seal the block off plate m12 threads for turbo oil feed line.
- Quick piston Question?
- S475/83/T4 Nova 5.7/127 first time out...
- Anyone Have Champion 3-Core aluminum radiator in f-body???
- Turbo making horrible noise under boost
- Rear mount oil system question
- Big power six speed guys??
- Best intake for boosted 402
- What would cause oil to come out of exhaust (STS turbo)
- Budget build questions
- Huron Speed A/C retaining turbo kits IN STOCK ready to SHIP!
- a2w intercooler question about water pump
- Driveshaft builder?
- which turbo for 408/L92 heads M6
- You guys happy with your jgs 60mm wastegates?
- Fuel System Questions
- need help asap tt lt1 breaking up in boost
- Comp turbo 100 turbine wheel vs BW turbine graphs inside
- Smallest T4 Turbos for LS2 Twin Build
- Need help with HP tune for turbo ls1
- New LS world record!
- 69 Camaro 6.2L Twin Turbo - Out Playing
- Will the Corvette PTK Twin Turbo kit fit an fbody?
- Ebay A2W
- Issues with RX Catch Can & PVC System......
- 5.3L set up for turbo good?
- Need ideas on a flexible fuel system
- Procharger F1X on an 09 CTS V - idle video
- megasquirt
- supercharger pulley to add more boost?
- Power gains from A methanol injection kit?
- Opinion on this cam for dd turbo 5.3
- E85 + Turbo + Plug Gap?
- HELP!! Procharger Parts Procurement (PPP)
- Need a little help picking a turbo for my build ebay gt 45, s400??
- vortech supercharger question
- turbo 5.3 transmission that will probably never see track
- cam question
- Head Stud Question
- PT88 + 255 tire + 4L60e = 9s!
- Rear mount exhaust / manifold question
- M122 build on 00 f body need help
- Is 190K miles on a L59 5.3L to many for a JY Turbo Build?
- Heat shield for fender exit exhaust
- What sz are the clamps needed for procharger twin intercooler kit
- Bearing Clearance Iron Block 383 Turbo
- Top Notch Customer Service Tick and FI
- T bolt clamps for twin intercooler procharger 98-02
- part number on 62mm procharger bearing
- Anyone with an F1C or F1R running less then a 4.00" pulley?
- procharger pully upgrade question
- looking for pictures of AN fitting on valve covers
- Another wastegate question
- More boost needed - Edelbrock 1567 e-force
- Every engine builder should have one of these
- 383 Twin Turbo overheating, which fans?
- Twin Turbo LSX T/A first dyno video
- Stainless Procharger J Bracket
- Race gas?
- high or low imp. injectors with holley efi... does it matter?
- Carwash Issues?
- WANTED: ls1 twin turbo kit
- Retune after turbo change
- 3.2 pulley/P1SC-1?
- boosting doubt?
- Holley Dominator EFI question
- custom ECS NOVI 2500
- 81ar turbine housing
- junkyard t76 5.3 ring gap?
- Any GTO owners with ProChargers optional 1300 HP intercooler system?
- 1957 Chevy all Fiberglass turbo ls Build
- small cubes and twins
- s 10 w 5.3 p1sc procharger
- 408 with a f-1a setup! gurus critique it please!
- Steves Procharged Silverado
- Chevelle FI fueling question
- What muffler for a turbo??
- P1sc record?
- S475 on my lil 4.8....
- 5.3 block machined to a.....????
- what pistons/rods for l76(ls2)?
- ls9 in 5.3?
- Procharger boost loss question
- what size precision turbo 5.3 silverado on 37s
- Updated Turbo Build Pics (Lots of Pics)
- A Cautionary Tale about Precision Turbo
- 1979 Malibu Wagon (denmah edition)
- Need some help with My 5.3 idea
- ls6 pcv setup with turbo?
- CTS-v Dual fuel pump on E85 limit?
- help me build my turbo setup
- Stock C5 FRC testing on 20psi
- supercharger for my LS1 offroad car? why not?
- Why does every one put the turbo(s) towards the front on the engine bay? W/ pics
- kvelasco d1 procharger run9.15
- Ls1 record. Can't find it
- Help building a boost motor
- Looking for a vendor to complete my build
- How Will My Cam React To Boost?
- Huron Speed custom T4 Hotside Kit!
- Highest p1 procharged 98-02 fbody
- cam for turbo 408 LQ9?
- What date was Holley EFI coil prob solved?
- *BEST GEAR RATIO for drag racing/street runs (turbo car)*
- Small Vacuum Line on back of intake?
- Stock bottom end F Body
- turbowerx base model vs exa
- Spark plug wires for 1000hp 408 lq4 turbo motor.
- pigtail for GM 12592525 map sensor
- Single 57mm 5.3??
- denmah's lunch and learn, the difference with megasquirt systems
- Procharger d1sc advise
- Running larger fuel lines to the factory rails/FPR
- Spal Fan people in here.....
- Roots boost rebuild questions....
- S480 on a 4.8?
- My Trip to Atlanta Drag way for the CHP and LSX Challenge True Street Win
- Which Fans???
- Max boost through alum LS block?
- Dumb Question of the Day/JY 5.3 swap
- SALT 370ci with a single 88mm turbo - Engine dyno VIDEO!
- got rid of tall valve covers, Huron speed bracket problem still post #9
- Random smoke out exhaust on turbo Camaro
- Custom STS Commodore LS1 to LS3 Conversion
- Standalone oil system (long ish)
- T-4 Mid Frame Ponderings
- 2000 2500LD with twins!
- figure out correct turbo for a ls1 rx7
- IAT'S way too high, more intercooler??
- Which turbo and cam?
- Which Heads for an F1A/346
- Blower Motor
- Plug heat range
- Another Huron Speed T6 Build!
- lsx 6 bolt copper HG's
- F-BODY supercharger for sale.
- home grown turbo build
- mid frame turbo
- point me in the right direction
- Pretty much sure my D1-SC has the wrong impeller! Please, some input.
- Oil feed for passenger mount turbo?
- Which plug wires for coil relocation?
- Porting truck manifolds? Also wrap question
- eboost2 help
- Considering Precison 7175 Turbo
- The "GRENADE" was noticed by GM high performance
- Procharger surge valve/low boost?
- Vortech Guys, Rebuild advice/powdercoating?
- Methanol Injection Brands...
- Probably a stupid question for supercharger
- fuel sensor for Holley hp controller
- The start of my front mount turbo build
- Plug for coolant on APS turbos?
- Bone Stock Longblock.... TC76 too small???
- Alternator relocation options for truck accessories
- Granatelli Super Sale on all Vortech Superchargers
- Precision Billet 6775
- lsa head has blocked off vapor/steam hole... why would that be
- Flex Fuel CTSV Dyno
- Whipple Version 4.0, pics!
- 67' Camaro Pro Street twin turbo LH6 5.3
- Truck manifold kit with LS7 Heads ?
- Brute Speed Aster Bracket and Meziere 55 GPM street pump
- another 5.3l turbo build
- expectations...
- Race Proven Motorsports Dyno Day 2013!!!
- Turbowerx exa pump failure
- Jegs Hobbs switch wiring
- Oil Pump for TT 408
- How much boost? twin gtk650 LQ4
- Hitting the track here soon.
- procharger still spinning after ignition is off?
- best performance trans for 700-800hp turbo zo6
- Map sensor question, need help...
- 3rd gen TA exhaust manifold options - LS3 or LS7 vette manifolds??
- t4 vs t6
- fuel system info 5.3 turbo
- Aps extreme turbos went bad
- SDCE tensioner question
- 64 Chevelle, 5.3, TC78, E85
- The 'LOLVO'
- 5.3 Build, BW S400SX Choices
- 408 S480 build which internals?
- Blown ls1 cam suggestions
- twin turbo intercooler kit suggestions
- Proper head stud install technique
- Emusa wastegate not closing fully
- New converter and smaller pulley. Maxed out fuel pumps.
- Vent for Ricks Tank and 4303
- 05 single turbo gto
- Short Compilation Video of my Turbo LSx Coupe
- 2009 FlexFuel Twin Turbo CTS-V
- Who has the best JY 5.3 turbo cheap on here
- going 5.3L/th400 and have some questions.
- 61/.96 on3 turbo on a lq4 good-bad-or do it
- JY 5.3 with all ebay turbo and parts
- Need help!!!!What injector fuel pumps etc for E85 set up
- Need help!!!!Forged 383,4l80e,9" rear end,gt4788.
- Show off your turbo engine bay with a/c!
- Pushing out PCV under boost
- Maxed out the dyno...
- Which head gaskets for budget build?
- will s480 be too much for 383 5.3?
- Help! Randomly Pushing water out the overflow
- f1r to f1x swap : pump gas /meth numbers
- holset hx 52 vs ebay gt45 on a 4.8 budget build
- Huron Speed - Precision Turbo Dealer!
- New Results after E85 Conversion
- Norwalk Track Rental FRiday 5/24 9-5
- Will a holset ht60 be too big for a rear mount?
- Big turbo TH400 guys. Help me pick a gear.
- Looking for suggestions for mounting a Procharger
- how to use HPtuners Real time tuning
- A/W intercooler inside the cab
- advice and help needed!
- 1967 camaro ls1 twin turbo build help!
- Twin BW S366 on 427LSX?
- turbo spark plugs
- 06 GTO M6 twin turbo build and I've got questions!
- S/C Build
- 5.3 Twin Turbo Build Planing
- Initial startup running too rich.... any ideas?
- Needed, stock alternator bracket.
- Boost activated cutout not working,Pics inside.UPDATE 5-21-2013
- Getting ready for a 370
- Tial 44mm wastegate
- bummer news
- Turbo headers for 2001 camaro
- 9:1 heads vs boost vs bottom end
- What manifolds to fit 6 bolt heads?
- Overdrive balancers
- What's the best place to buy a Procharger head unit from?
- Meth/E users, how much time?
- How to test if BOV opens premature
- ?'s about regular maintenance on FI Cars (procharger)
- I have this in the fuel section but
- Project: Latrine
- L76 intake
- ? hp i can get out of turbonetics hurrican tc78 96ar
- oil relocation + cooler
- Wat size ... On crossover
