View Full Version : Small Block & Big Block Chevy Specific
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17
  1. Company built LS7 question
  2. What do i need to put a sbc in an ls1 car????
  3. PROM Part # for 305 to 350 TBI Swap
  4. Can I use a LS1 T56 with a SBC?
  5. SBC in Foxbody?
  6. Cost of EFI conversion on BBC?
  7. Project: SBC Formula T/A!
  8. Crossfire -> TBI swap
  9. LS1 wiring in a 2001 Jeep Wrangler
  10. Camel Humps on a roller 350?
  11. I have a nasty miss fire and need help badly
  12. L31 slow crank when hot
  13. not a BBC SBC or LSX a Duramax Thirdgen
  14. LS6 heads
  15. New GM Small Block
  16. help with zz383
  17. Does anyone produce BBC 4th gen headers?
  18. went to change my timing set HELP
  19. Blown 383 Questions
  20. sbc conversion question.
  21. main bearing clearance
  22. ProCharger Rebate Program!
  23. Hopefully this is the right spot...
  24. sbc Build
  25. Boosted 502 Ramjet
  26. 400 sb with main bearing from 350 ?
  27. Cam companies
  28. Matching parts for optimum combo, how to?
  29. New AFR composite SBC carb manifold
  30. 1994 new motor
  31. 1000 HP sbc
  32. Oil feed sandwich adapter 71 impala
  33. 327 advise
  34. Building 406 for 89 camaro
  35. 1997 Camaro Z28 1LE
  36. breather ?
  37. What to rev limit SBC
  38. Long shot here, but looking for opinons on pricing a SBC 406/th400 for sale
  39. 383 stroker, am I on track
  40. Head gasket problem ( pics)
  41. How hard would it be to stuff this engine in my 1998 F-Body.......
  42. I could use some expert advice on a later model sbc
  43. stroking out my LM7 5.3L
  44. 454 with no spark need help
  45. I want to learn to rebuild a Chevy 350
  46. 1994 camaro z28
  47. weight difference between bb chevy and iron block 5.3
  48. Getting a Nova 350, Mods?
  49. gen 1 sbc and lt1 t56
  50. What can I do with this ole 350?
  51. SBC dying when I blip throttle in gear
  52. Budget Vortec 383 stroker
  53. Low 10s Reqal with SBC ?
  54. 92 loaded 4x4 with 305?
  55. 500whp big block street engine
  56. sbc 400 head help
  57. In need of a LS block
  58. pil pressure acting crazy 5.7 vortec
  59. Top end kit for my 454
  60. 86 454 bb
  61. sbc bellhousing pattern 305 - 307 - 350
  62. old school heads
  63. LT1 crank hub
  64. 1 3/4" headers vs. 1 7/8"
  65. 406 stroker vs 421 stroker
  66. DIstributor Hold down questions !
  67. 96 Tahoe 5.7L 242k Miles Troubleshooting Help
  68. Turbo Build....
  69. Coolant every where.....why? :(
  70. cam help guru's knowledge please
  71. Trying to decode this suffix code, no luck. Help?
  72. Sbc 350 tbi help!
  73. Who knows about holleys?
  74. Thinking of a hotter cam for my vortec 350
  75. 2001 BBC Trans AM
  76. camshaft tech info needed
  77. Cam advice
  78. First Gen VIN check?
  79. Looking for gasket kit
  80. Anyone give me a little SBC help
  81. distributor gear q?
  82. proper main bearing clearance?
  83. 79 vette missing RPO sticker
  84. New roller rockers!!! ????
  85. L98 Oil Pan & Pickup Tube Replacement
  86. Buddy needs help!
  87. K5 running rich after tune up
  88. Need help - TBI 350 running hot
  89. will someone please run these numbers
  90. 350 chevy oil pressure drops rapidly after starting.
  91. timing jumping off on carbed sbc
  92. ughhh
  93. required parts for tall deck
  94. Crossfire vette
  95. 94 z28 twin turbo sbc project
  96. budget 350
  97. low compression issue
  98. help with cam please
  99. Hp Guess on carbed vortec 350!!
  100. what would you do new rotating assembly or new heads
  101. the big decision
  102. How much does a BBC conversion cost?
  103. cam raised, deck height?
  104. BBC Shortie header in 4th gen
  105. bbc head casting numbers what are they
  106. just picked up top end for my bbc
  107. how good are the bbc dimple rods with 7/16 bolts
  108. ring end gap factor
  109. what distrubitor for bbc
  110. swapping a 350 tbi and going with a 305 tbi engine
  111. need advice on studding bb mains
  112. oil pump drive shaft clearance
  113. 1989 Chevy Silverado engine swap
  114. need help
  115. natural gas bb
  116. Nova oil pan removal
  117. BB four-bolts main caps
  118. proper piston-head clearance
  119. oval or rectangle port?
  120. almost 11's with un-ported vortec's
  121. scored a big block for my 63 nova
  122. Converting LT1 to carb & distributor?
  123. connecting rods
  124. gen iv 454 running hot
  125. need help 91 camaro
  126. 388 stroker ?
  127. 8.1 liter
  128. Carb question for bracket racers
  129. lifter problem
  130. BBC in a 4th gen???Motor plate????
  131. About the drop the 454 back in my truck.
  132. 383 stroker bad idle when cold...
  133. stock 400 limit
  134. 350 chev won't run when tach wire is plugged into dizzy what's wrong?
  135. 355ci for a truck
  136. Turbo 565ci 4th Gen build
  137. TBI help please
  138. Big block chevy conversions
  139. 468 Big Block at 8000RPM
  140. Dyno results for nova
  141. need help finding headers for BB
  142. big block street car tranny?
  143. timing problem
  144. 85 IROC TPI, no injectors on start up, please help
  145. Seriouly need some help with 454 motor that i want to sell
  146. small block question
  147. 362 max racing motor with buku restrictions, opinions?
  148. need something built????
  149. 406 with a 5.7 rod. Is it that much of an issue?
  150. 1966 Impala SBC headers
  151. sbc 400 gurus please come in
  152. 427 tall deck
  153. brake booster
  154. '89 truck engines
  155. fastest 3rd gen period.
  156. Blown efi 406 questions!
  157. SBC Milodon steel splayed main caps
  158. Using a marine 502ci block?
  159. Fuel Pressure problems
  160. Did some research and think I got what I want. Input Please!!
  161. 350 4x4 cam question
  162. Mpfi 468
  163. New Engine build
  164. electric water pump help
  165. 350 Big block help!
  166. Main bearing help?
  167. New pushrod length after heads decked?
  168. Need Opinion of 454 Rebuild
  169. planning a 305 build
  170. Help!!!!!
  171. cu engine ?
  172. I need some help with my steering linkage!
  173. Timing Question
  174. Possible Ignition Box Failure, Need Help
  175. block & heads
  176. 1977 trans am with 403 need help
  177. Exhaust gasket
  178. hmm..how bout a 434 fuel injected into a 4th gen?
  179. Anybody seen the new mercruiser dohc bbc ?
  180. What will porting my intake do?
  181. new to this game
  182. Need TPI Diagnosis Advice - Not Starting
  183. New intake manifold leaks at ports
  184. 400 sbc rpm
  185. 500-600$ budget for carburator and Manifold (454 Big block)
  186. Cheap 383. How would you do it?
  187. Hp estimate
  188. Leaking Head Studs
  189. 1994 Chevy Suburban Manual
  190. Carb Help!
  191. peak hp
  192. which crate motor and mods for 700 rwhp
  193. pre-85 sbc with lt1 t56 questions
  194. v6 to 400 sbc help
  195. Best plugs for a 99 5.7 Vortec in a suburban
  196. Vacuum pump might be needed
  197. Starter help
  198. Building 10s Corvette C3
  199. cam ?s
  200. k-member or motorplate?
  201. Max cubic inches for BBC heads?
  202. Help me clarify mount issue
  203. LS1 vs. LQ9
  204. SB head casting
  205. Big block into my small block van
  206. selling my gear drive
  207. After market Vortec heads..
  208. No cam button or retainer...really?
  209. try n figure this one out
  210. Modern starter for 67 396 with 168 tooth flywheel and 700r4?
  211. chevy 350 cam questions, for a boat
  212. help with picking a cam for my vortec headed l98 350!!
  213. What power would this SBC setup make?
  214. v8 swap
  215. SBC into a 98 F-Body, Rack/oil pan Issues?
  216. Ls1tech special msd for sale!!!
  217. ? about 350 rebuild
  218. 85 IROC-Z tpi tuning limitations???
  219. Project Sublime - SBC powered 00' Dodge Dakota
  220. modding a tbi truck lot of questions
  221. Build Motor or Purchase Crate Engine?
  222. Cleanable inline fuel filter
  223. How much difference does lobe design make on power
  224. t56 retrofit to bbc, What to do?
  225. Clutch question.
  226. Track times for my carb'd SBC 4th gen
  227. Knock sensors on a BBC.
  228. please help
  229. bought a truck has a small problem any ideas?
  230. COMP CAM Question?? (on 91 camaro L98 350)
  231. Distributor Not seating problem
  232. heads for FI big block
  233. Dumb question
  234. engine gurus I need help!
  235. Will this affect my CARBS PERFORMANCE?
  236. Budget BBC heads worth buying?
  237. Need Info
  238. Starting problems
  239. advice for serious sbc w 6 spd in a 80 vette
  240. Where or who can I get a guesstimate on my HP?
  241. BBC head bolts sealant?
  242. Lopsided spacer for LT1 intake conversions?
  243. Mild Milkshake
  244. 8.1L to Viper t56
  245. 1994 z28 missing issues
  246. can I just swap out pistons?
  247. 350 vortec vs. 2008 mustang 4.6
  248. Who has a CNC program for Vic Jr's?
  249. BBC 454 PTV ISSUES with AFR heads
  250. Emissions help!!!!!
