383 tear down, more damage than I thought
Old 10-10-2008, 04:55 PM
IH8FORD's Avatar
Default 383 tear down, more damage than I thought
Well I finally took my 383 apart because it was making a knocking noise. So this is what I found I wish I just had a bad rod. Notice anything missing in the first Pic.
This is the damage that TB screw caused
And this is what it looked like when it was spit out.
BTW I need a stock lt1 head bad I will buy a set of stokers if someone has any.
Old 10-10-2008, 05:11 PM
Moderator
JasonShort's Avatar
Sorry to see that Those situations are never fun.
Jason
Old 10-10-2008, 05:17 PM
355z28's Avatar
Ouch, I have sevral sets of lt1 heads, all untouched send me a pm just offer! sorry to see this. I think ill go lock tite mine now..
Old 10-10-2008, 05:59 PM
Fixxer99TA's Avatar
Good call, I think I am about to do the same...
Old 10-10-2008, 07:10 PM
chavez885's Avatar
HOLY ****...i'd be pissed
Old 10-10-2008, 07:19 PM
halucinator's Avatar
Wow thats crazy. I've seen that happen a couple of times. Are you rebuilding and just getting a new piston and head or what?
I'm guessing your running forged pistons because hypos have been known to self destruct with something tiny like a screw.
Old 10-10-2008, 08:26 PM
James Montigny's Avatar
Damned, I've heard of that happening to a few motors now ...
Old 10-10-2008, 08:38 PM
fergymoto's Avatar
Was the bore hurt? Why do you want a new head? It's not that beat up. Check the gasket areas with a machinists straight edge, check the valves and seats if if theres no deform or crack run it.
Old 10-10-2008, 08:48 PM
ss454327's Avatar
As good a time as any to have them "Smoothed"
Old 10-10-2008, 09:14 PM
IH8FORD's Avatar
It is hard to tell from the pic but the head is cracked and bent up at the water jacket.
Old 10-10-2008, 09:16 PM
IH8FORD's Avatar
I am going to get one new piston, they were off the shelf Ross Racing Forged pistons. The bore looks fine.
Old 10-11-2008, 10:02 AM
IH8FORD's Avatar
I am thinking of buying a head and cam package at the first of the year from AI or either converting to an LS1, which for some reason I just want to keep the Lt1 in the car.
Old 10-11-2008, 12:09 PM
Tireburnin's Avatar
That is one of the worst feelings. It couldn't have "just" been a bearing or something, it had to go and tear everything up.
Good luck getting it running.
Old 10-11-2008, 12:10 PM
hashtagBMW
Speed Density's Avatar
Holy hell, that sucks!
Its crazy what things do when they get stuck insided cylinders, good luck getting it back together man.
Tony.
Old 10-11-2008, 01:02 PM
riceburnerZ28's Avatar
I never heard of such a thing happening cause of a throttle body. Hope everything works out.
Old 10-11-2008, 03:25 PM
C5042081's Avatar
wow thats crazy, look on the bright side you have a fresh rebuild if you decided to keep it
Old 10-11-2008, 04:02 PM
Mattsz28's Avatar
Ive got a set of ported stockers I'd let go pretty cheap if you want. They came off a 383 that trapped 118 in the quarter the only time I had it down there on 2.73 rear gears. I switched to a set of ported darts :-) Send me a PM if your interested.
Old 10-11-2008, 04:05 PM
IH8FORD's Avatar
I have decided I am going to do a nasty NA lt1 build since I already have a mean LS1 car. I always enjoyed outrunning ls1 with cars with lt1 power. I will start with the build at the first of the year after I finish the tunning on the 99SS.
Old 10-11-2008, 04:17 PM
AChotrod's Avatar
Sweet! Glad to hear your keeping it an LT1. Sucks about that damn screw though.
Old 10-11-2008, 04:22 PM
ThoR294's Avatar
wow... of all things a throttle body screw... im sorry man thats really lame.
Quick Reply: 383 tear down, more damage than I thought
