do i need a better fuel pump or a stand alone fueling system
Old 10-10-2008, 11:28 PM
xdanny510x's Avatar
Default do i need a better fuel pump or a stand alone fueling system
....would i need a better fuel pump or a stand alone fueling system if im gonna do a big 250 shot of nitrous on a 408? If so do we have any sponsers that sell these .. ?
Old 10-11-2008, 12:13 PM
black01_WS6's Avatar
harris speed sells a decent stand alone for a good price. I would run one on that big of a shot as buying 5 gallon drums of race gas to mix gets expensive and hard to get exactly the right mix. With the price of race gas I would definatly look into it.
Old 10-11-2008, 12:18 PM
WHITE DEVIL's Avatar
i am selling a nitro daves dedicated with everything needed in an f body for 600 shipped has low and high pressure spring
Old 10-11-2008, 04:22 PM
94 guy's Avatar
pics of the nitro dave setup forsale?
Old 10-11-2008, 04:43 PM
i will send you one tonight what is your email address?
Old 10-11-2008, 05:25 PM
94 guy's Avatar
z-car@rtconline.com
Old 10-13-2008, 01:26 AM
bluchev's Avatar
i heard anything over 200 shot should have its own fuel system just in case
Old 10-14-2008, 09:26 AM
Ray@Nitrous Outlet
Guest
Posts: n/a
We offer a very extensive line of dedicated fuel systems.
http://www.nitrousoutlet.com/catalog...del=73&dept=11
Old 10-14-2008, 09:34 AM
Nick@HSW's Avatar
Honestly, you might end up having to do both of them. Keep an eye on your N/A pressure if you're running the stock pump in there. Let me know if you have any questions. Thanks.
Nick
Old 10-15-2008, 07:05 PM
Nitro Dave's Nitrous Outlet's Avatar
What are you making on motor at this point.. I see this is going in a truck. I can custom build you a dedicated to feed just the nitrous or a system to feed both motor and nitrous if it would better fit you needs.
Dave
Old 10-15-2008, 07:30 PM
02SOMWS6's Avatar
You need to do both . There is no cheap away around it. The 408 will demand a better pump depending on how much power your making na and you will have to get a stand alone for the 250 shot of spray. I had to do both for a stock bottom end 346 with spray. You don't want to chance going lean so just do both and get it over with and be safe than sorry.
