Direct Port kits can they be jetted to under 150shot
Old 10-11-2008, 05:53 PM
CraZee ZO6's Avatar
Default Direct Port kits can they be jetted to under 150shot
say 100 or 125
Old 10-11-2008, 05:57 PM
ATVracr's Avatar
They can but becareful with small jets as they can clog easy.
What fuel pressure are you running? A high pressure system would need a very small jet.
Old 10-11-2008, 06:01 PM
CraZee ZO6's Avatar
no idea on fuel pressure... 42lb injectors and a walbro # 340 pump w/ racetronix harness is going in so should be plenty of FP. If I can get it jetted to 125 I am in.
Old 10-11-2008, 09:36 PM
Moderator
thechef's Avatar
im sure you can
Old 10-11-2008, 10:01 PM
ATVracr's Avatar
The Fuel jet size should be 0.010" or 0.266mm
A Nitrous jet size of .020" or 0.508mm should produce:
144.52 HP with 8 port(s)
Actual HP to the wheels: 122.84 HP
That would be a VERY small fuel jet.
Old 10-11-2008, 10:07 PM
CraZee ZO6's Avatar
man I need someone to give me a directport kit 411... Can I do a single stage 2 solenoid wet kit or not?
and if its dry only then why need a fuel jet, isnt it relying on the injector?
Old 10-11-2008, 10:08 PM
jmill96Z's Avatar
I might be scared running a .010. Maybe you could go with a low pressure dedicated cell.
Old 10-11-2008, 10:11 PM
jmill96Z's Avatar
There is the possibility of running dry direct port. The injectors will pick it up, but the car has to be tuned for the specific shot you want to use.
Old 10-11-2008, 10:25 PM
CraZee ZO6's Avatar
I am going to hold off on the direct port.... I have a tnt wet f1 kit currently ON the car.
My problem is I am upgrading to a fast 92mm and my tnt power ring will not fit that!
Old 10-11-2008, 10:40 PM
jmill96Z's Avatar
Sponsors on here sell plate conversion kits, where you just get the plate and jets. They are very reasonably priced. They hit hard as hell too.
Old 10-11-2008, 10:44 PM
CraZee ZO6's Avatar
thats what I need......95mm plate conversion kit
Old 10-11-2008, 10:53 PM
jmill96Z's Avatar
Harris sells a 92mm plate conversion for $199.
Old 10-11-2008, 11:44 PM
Hennytime's Avatar
the dp i sold on here had 20/10 jets should have been about 100-125 shot
Quick Reply: Direct Port kits can they be jetted to under 150shot
