Wire Gauge from Battery
Old 10-12-2008, 06:19 AM
Caribe's Avatar
Default Wire Gauge from Battery
What wire guage are you guys using to run constant battery power to your #30 slot on your relay?
Old 10-12-2008, 06:57 AM
n2ocamaro's Avatar
12 gauge here.
Old 10-12-2008, 08:36 AM
Caribe's Avatar
Thanks I was thinking 10 or 12.
Old 10-12-2008, 10:15 AM
Nick@HSW's Avatar
Depends on what the relay is being used for. We supply a 10ga wire with the nitrous kits and heater kits.
Nick
Old 10-12-2008, 12:10 PM
n2ocamaro's Avatar
Nick
Nick, should I be using 10 gauge. I assumed that the short distance from the battery to the noids wouldn't require a heavy wire. The fuel pump relay kits use 10 gauge and they have to travel all the way the the rear of the car. I have always been curious what the current draw is from solinoids.
Old 10-12-2008, 02:30 PM
Nick@HSW's Avatar
what size are the solenoids?
Nick
Old 10-12-2008, 05:08 PM
n2ocamaro's Avatar
Tnt F1
Old 10-12-2008, 06:01 PM
Caribe's Avatar
Mine is the Zex NMU.
Old 10-13-2008, 01:24 AM
bluchev's Avatar
thicker the better you would think right?
Old 10-13-2008, 09:55 AM
Nick@HSW's Avatar
From the battery to relay, I recommend the 10 gauge wire. From relay to solenoids 2 12-14 gauge wires. I hope that clears up the two questions above. Thanks.
Nick
Old 10-14-2008, 11:59 AM
Ray@Nitrous Outlet
Guest
Posts: n/a
This is a chart to help you choose the correct size wire when wiring up your nitrous system.
Old 10-14-2008, 05:05 PM
n2ocamaro's Avatar
So what is the current draw of most solenoids?
Old 10-14-2008, 05:19 PM
Ray@Nitrous Outlet
Guest
Posts: n/a
depends on the solenoid.....will be updating this list with other companies as soon as I can get that info from them.
Nitrous Outlet
.125 nitrous solenoid 27a
.187 Fuel solenoid 7a
NOS
Super Powershot nitrous 8.6a
Super Powershot fuel .6a
Cheater nitrous 10a
Cheater Fuel 1.6a
Super Pro Shot nitrous 8.6a
Pro-Race nitrous 8.6a
Super Big shot nitrous 30a
Nitro/alky fuel .8a
Old 10-14-2008, 05:27 PM
n2ocamaro's Avatar
Thanks for the info (both Ray and Nick!)
Quick Reply: Wire Gauge from Battery
