Cam Only
Old 10-12-2008, 11:10 AM
01blackz28's Avatar
Default Cam Only
Sick Speed Performance (1984camaroz28) built cam only z28 goes 11.3@121 with a 1.60 60ft time. The time i cut a 1.49 60ft I banged the revlimiter and both shifts and still ran an 11.4 @119. Not to mention it was about 75* i even got burnt lol. I think it has 10's in it if it will hook up launching 4k off of the brake.
Old 10-12-2008, 11:32 AM
chrs1313's Avatar
yup you are going to need mid to low 1.4s with that mph but it can be done...
Old 10-12-2008, 03:27 PM
01blackz28's Avatar
yeah it yanked the wheels about a foot on the 1.4 60 but i hit the revlimiter on both shifts. i think the tranny was hot thats why it did it.
Old 10-12-2008, 06:54 PM
plaf713's Avatar
stock trans?
Old 10-12-2008, 07:22 PM
01blackz28's Avatar
nooooo, built th350 with a transbrake. its got 10s in it
Old 10-12-2008, 10:03 PM
twin74s's Avatar
what cam?
Old 10-13-2008, 09:07 AM
01blackz28's Avatar
trex. fast 90/90, 4.30's, 241 stock heads, stock internals, arp rod bolts.
Old 10-13-2008, 08:37 PM
twin74s's Avatar
Awesome man...Runs good.
Old 10-14-2008, 11:42 AM
01blackz28's Avatar
thanks the da was around 1500 that day. If i can get moroso ds2's and drag brakes i think i can be on the top ten cam only list. Not to mention there records are in the negative thousand DA lol
Old 10-14-2008, 01:32 PM
slowformula's Avatar
I'd say it has 10's in it. Going to have to hook like a mother though.
Old 10-14-2008, 01:36 PM
01blackz28's Avatar
just like any other of the top 15 cam only cars. They cut high 1.3 60 ft times. Im at 1.6 and 400 lbs heavier.
Old 10-14-2008, 04:28 PM
chrs1313's Avatar
and how do you plan on getting into the 1.3 range
Old 10-14-2008, 04:39 PM
BADSZ28's Avatar
What is your race weight? You are talking about droping nearly 4 tenths...I suppose it can be done with negative DA and another solid 1.4X 60'.
Old 10-14-2008, 07:20 PM
01blackz28's Avatar
Lets see i have shitty stock shocks in the rear. Ill go with qa1s. I only launched it at 2500 to cut a 1.49 60. It goes to 4200 on the brake. HMMMM just maybe i can cut another tenth like that. GENIOUS I SWARE !!! not to mention that the tires on the car are shot and there is some power left in the tune. Oh and it was run through a full exhaust no cutout.
Old 10-15-2008, 05:00 AM
chrs1313's Avatar
just hate when people are like i could do this and then do this and can run 1/2 sec faster...just do it and run the times, no qustions there...not saying you cant bud i know the trex and 90/90 are plenty also i thought you were a stick...get the times the cold air is coming...
Old 10-15-2008, 06:34 AM
studderin's Avatar
good luck
Old 10-15-2008, 09:41 AM
BADSZ28's Avatar
I still would like to know weight. I run the T-Rex too. M6 though and trap 119 and change at 3600+lbs. I have a stock intake and ported stock MAF and TB though. Best with that set-up is 11.48@119.47. I have switched to SD tune and the car feels stronger. I hope to have new numbers soon. That was on a 1.62 60'.
Old 10-15-2008, 12:31 PM
01blackz28's Avatar
i would say 3400 lbs the weather that day was hurting me also. im gonna put it back on the dyno to get some more power out of it. I was only shifting it at 6800 that run i may try 7000 and bump the limiter up. What were u shifting at ?
Old 10-15-2008, 12:39 PM
BADSZ28's Avatar
This cam does not make power as high as people think. I shift mine about 6700. Mine stopped building power at about 6300, but I think the intake was limiting that a bit. In Any case, I do not see these building power above 6500. Holding power up to 6800 sure. You can try shifting at 7000 and see what she does.
Old 10-16-2008, 06:49 PM
CanuckSS's Avatar
I have a similiar setup with a trex. I weigh 2950 with me in it. Do you fiqure to get a 1.3 60 foot I would have to dump the clutch at 7000rpms? I guess I need to grow a set of nuts and give it a shot!
Good luck to you!
Quick Reply: Cam Only
