Springs and high RPM question....
Restricted User
Re: Springs and high RPM question....
What is your cam profile? I have a XE-R 236/240 with the 987 springs as well. From what I am told, anything over 232 duration can go into valve float. I am having Jay from Absolute Speed make me up a set of LS6 heads with Comp Dual 977 springs. The lifters need to be changed to Comp R lifters to handle the spring pressure. Talk to Jay at Absolute Speed about it.
ya, just like 2001 pewter WS6 said, it sounds like your hittin the float range. Check, your cam card will tell you what rpm your valve float is.
I can shift faster than you.
Phil, I got your PM. Do you have a dyno sheet I could look at?
I would honestly look into a set of Comp 918s or the new Crane dual springs. I would toss those Comp 987s in the trash (call Craig @ GTP, he'll agree with me on this). My personal choice would be the 918s w/ Ti. retainers. A set of Comp R lifters wouldn't be a bad idea either. Keep your lifter preload on the low side with these and you should be good to go. The Comp Rs are not 100% needed. I had no problems turning 7200 with 918s and the TR230 on my GTP Stg 2 hydraulic setup (stock lifters).
Jason
Jason
