Sponsored by: DashLynx
How do you get the grill off your car????
Old 09-12-2003, 04:09 PM
whatwasthat's Avatar
Default How do you get the grill off your car????
I want to know how to take off my grill that says camaro because im going to paint it , how do i do it?
Old 09-13-2003, 12:21 AM
LSX Mechanic
Damian's Avatar
Default Re: How do you get the grill off your car????
To remove the grill without damaging it will be a major pain in the ***. Most people just rip it off, and get another one. It's much easier that way, and that plastic piece is cheap. I have one that is brand new actually, never wound up using it. You can have it for 25+shipping if you pull your other one off.
I am moving this to the appearance section, it has no business in Parts Wanted
Josh
Old 09-13-2003, 01:45 AM
Administrator
unit213's Avatar
Pull like you've never pulled before.
Old 09-13-2003, 04:35 PM
Tracey's Avatar
I pulled my off and it broke the clips that hold it in. I then purchased another one from my local Chevy dealer for $35.00 and had it sanded and painted. When I tried to put it back in it would not stay because I could not put the clips back on. I had the guys at my work remove the front cumpber to re-install my newly painted grille. Which by the way has been on for about 8 months and the paint is starting to peel. Something having to do with the plastic that GM uses, it releases a solvent of some sort no matter how much you sand it down or prime it.
Mine does however look really good and it was cheap to do.
Good Luck!
-Tracey
Old 09-14-2003, 06:22 PM
joedrum71's Avatar
I removed the front bumper. Didn't feel like "ripping" the grill off. A couple of 10mm and some clips, and the front comes off. About a 45 minute job or so.
Quick Reply: How do you get the grill off your car????
