Tracetronix wiring harness
Anyone here ever try to install the Racetronix wiring harness without dropping the gas tank? I crated a trap door to replace the fuel pump and had hoped I find a good way to fish the harness from the bottom up, but no luck. It looks to me I'll have to at least drop the bolts from the tank straps to give myself a little space to work in. Anyway, if anyone has made it work without moving the tank, i'd like to know how.
I used the trap door to fish a "pull" wire down and tied the harness to it and then pulled it back up and connected everything. It was pretty tight but you shouldn't have to drop the tank or loosen anything to get it in.
well once I found a good path, the cable pulled very easy up to the tank without dropping the tank straps. I ran the wiring up about mid way and decided it was time for football watching. I'll finish tomorrow after work.
