P1SC Procharger Questions
I just recently bought a P1SC kit. I am running a 224/230 .581 .588 114 cam. I currently have 4.10 gears in the car. Should I change the gear back to the stock 3.42, put in a 3.73 or keep the 4.10s. What is the ideal gear setup for a cam'd procharged car? The kit I bought also came with a good many Procharger and Crank Pulleys. What combo should I be running to achieve 7lbs of boost?
Thanks.
Zach
Thanks.
Zach
Thanks.
Zach
Thanks.
Zach
Zach, I would keep the 4.10 gears, and if this is a 6 rib kit then I would start with the ProCharger 6.00" crank pulley and a 3.70 blower pulley. Bob
http://www.exoticperformanceplus.com...html?item=1474
This chart enables you to figure out the impeller speed of the blower for the six rib vs the eight rib. Bob
Bob,
I do plan on pinning the kit regardless of 6 or 8 rib. Here are the pulleys that I have.
6 Rib
6 and 8 inch crank pulleys
4.0, 3.85, and 3.20 blower pulleys
8 Rib
7.65 crank
3.40 Blower
Out of these possible combo's; which would net around 6-8lbs of boost?
Thanks again.
Zach
6 Rib
8 Rib
7.65 crank
3.40 Blower
Thanks again.
Zach
Bob,
6 Rib
8 Rib
7.65 crank
3.40 Blower
Thanks again.
Zach
6 Rib
8 Rib
7.65 crank
3.40 Blower
Thanks again.
Zach
Hmm, being a P-1SC and with your camshaft I would go with the eight rib combination. The 3.40 pulley should be about right, but take the rpm's up in increments when you do your tuning just to make sure you don't see too much boost. Bob
