PLx to Hptuners Question
Old 10-15-2008, 12:13 PM
sevanseriesta's Avatar
Default PLx to Hptuners Question
I have installed My PLX gauge and DM100 and I need to know how to make it read into Hptuners.
Trick Is I do not have HPtuners. So when I go to get my car tuned I want the individuals using hp tuners, to not have to do much to make it work. Can I just hook it up through my EGr and he can Log the egr for the wideband?
Any help is appreciated!
Old 10-16-2008, 11:55 AM
obi-1's Avatar
It was easy to hook up. HP Tuners has an interface cable from the laptop to the vcm. You will see 8 pins for auxilliary inputs.
Take the 2 wires from the PLX sensor module that can go to the AFR gauge. Hook plus up to pin 1 and minus up to pin 5.
There was one more step, too. In the VCM scanner program you have to tell it you have a PLX wideband hooked up. I don't know exactly where. Tuner should be able to find that pretty easy in the help file.
Quick Reply: PLx to Hptuners Question
