1LE driveshaft question
Old 10-15-2008, 08:38 PM
firehawk238's Avatar
Default 1LE driveshaft question
i have a 1995 formula firehawk that originally had a steel driveshaft. the previous owner recieved a recall letter from GM stating that the car needed to be brought in to replace the steel shaft for an aluminum due to vibration issues. my problem is that i went to the parts store to pick up some new U-joints for it, and all they showed were the flush mount type with clips that go on the inside and my shaft has recessed caps with locks on the outside. does anyone know what U-joints the 1LE shafts take? i looked up the part number for a third gen shaft and it showed a 280. is that what i need? any help would be awsome!!!!
thanks in advance
karl
Old 10-15-2008, 09:41 PM
JScamaro's Avatar
You could look into getting an aluminum one off an LS1. I'm sure they are pretty cheap too.
Old 10-16-2008, 08:03 PM
but i already have an aluminum 1LE driveshaft. i just want to replace my U-joints and need the part number for them.
Old 10-21-2008, 08:15 PM
Kevin97ss's Avatar
The 1LE shaft uses 1310 joints. If it is going to be used with the stock rear(stock yoke) then you will need one "combo" joint 1310 to factory. I dont have access to the part numbers for the combo joint....maybe a google search will help.
Old 02-15-2009, 07:58 PM
multmigs's Avatar
ANyone ever figure out which is the correct U joint to use for a 1LE shaft? is it the same as a later model one since they have the same alum driveshaft? I bought stock 94 replacements and they don't work at all????
Old 02-15-2009, 08:11 PM
multmigs's Avatar
http://www.autozone.com/N,11200178//...eResultSet.htm
check above should be a listing for 1991 firebird formula w/ 305 TPI motor... looks correct..
Quick Reply: 1LE driveshaft question
