need hlp asap
need hlp asap
ok i have afr 225. and yellow terra 1.7 rockers. i went to put them together last night. and the rocker rubs on the head.
now what. do i grind on rocker or on head.
also it hits on push rod side of rocker.
thanks
thanks
LS1Tech Premium Sponsor
I'd just assume grind on a rocker arms rather than on a $2400 set of cylinder heads. I've seen both done without issues though! The perk of clearancing the rocker arms is that you can do it away from the assembled engine without pulling the heads!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Plus, the rockers are then clearanced for other heads if the heads are ever swapped.
