knocking sound in back when making left turns
Ok here is the deal, just recently I had LCA brakcets welded on the Moser rear and then tubular adjustable LCA put on. Everything seemed fine.
Went to the track, and that night on the way home I heard a knocking sound from the back, when went over bumps so I thought.
So put the car up, made sure everything was tight, one of the adjustable bolts was loose on the driver side Adj LCA, so I tightened it up. Seemed like the knocking sound went away. Also it seemed the noise happened when I had a small child in the back seat, 40lbs or so.
Anyway, it started doing it again yesterday when I had him in the car and only when making left turns.
I have the car up now, nothing is loose, shocks and springs are fine. Not sure what can be causing this noise.
In the back I have the SAM strano lowering springs, Koni adj shocks, adj panhard rod, adju LCA, LCA brackets, moser 12 bolt
Anyone experience this problem before???
Thanks
Sam
Thanks
Sam
