LQ4 in Third Gen Camaro
I have an 86 camaro that i recently finished swapping an LQ4 into. The only modifications done so far are a cam and carburated intake.
The camshaft is a comp cams XR275HR - 222/224 - .566/.568
just some LS6 springs on the stock cast iron heads, the intake is an edelbrock rpm, and i am using the MSD 6LS box. My best time with it so far is an 11.97 at 113mph. Here are a few pics.
LQ4 swap
Custom AutoMeter Gagues
Megashifter & custom radio/switch panel
hawks ls1 third gen headers and champ pans 67-69 camaro ls1 pan
Custom alternator brackets
Custom tensioner
Moser 9" 3.55 gears and 31 splines w/ spool
ET street radials
LQ4 swap
Custom tensioner
ET street radials
thanks guys, my plans for it are that i think im going to try a 4L80e swap with a manual valve body, some L92's, then a possible twin turbo setup if i have enough money. all that would hopefully make a 9 second street car
I'm mostly running the same engine as you but not finished. (LQ9, Same cam, Patriot gold springs, Hardened pushrods, Victor Jr intake and a 750 holley)
I was really wondering how this setup would do on the track. Good to know. Do you like the cam?
yeah i really like it for the track but i need a set of heads for sure, i wouldnt mind a little bit more duration on the cam, and a single plane intake because i run it up to around 7000. but other than that it has a nice power curve, pulls good from around 2500 all the way up to 6800. Its a very fun street car i think you will be very happy with your LQ9.
i would but i guess i dont really have any good pics of the car and i am in the process of putting a fiberglass front end on it. So i guess when i get that finished up ill post a few more pics. Im guessing ill have it done in about 2 or 3 weeks.
