car in the shop for the build!
Old 10-16-2008, 06:30 PM
lifeisgood's Avatar
Default car in the shop for the build!
finally my car has made it to the shop for the turbo kit here in louisville, ky.
the car had the tubular k-member installed last night,and its gonna get dyno'd very soon for stock. bone stock ls1 numbers!
the kit consist's of the things listed below in my sig.
ill post pics up soon
lifeisgood is offline
Old 10-16-2008, 07:15 PM
Reject's Avatar
so they are going to fab up?
Reject is offline
Old 10-16-2008, 08:46 PM
lifeisgood's Avatar
yea theyre doing the fab install and tuning.
Old 11-05-2008, 11:01 PM
black98ws6ta's Avatar
I am the guy fabricating the turbo kit. retains a/c, retains stock ground clearance, retains sway bar, everything above the k-member, uses quality parts, gravity drain, ect, ect. It can be installed easily and only relocates the alternator and fans.
black98ws6ta is offline
Old 11-05-2008, 11:23 PM
Josh@KY-Turbo's Avatar
Nice looking work Anthony. I have a similar setup sitting in the shop right now. Have you tested one out on a car yet? I have some concern's about heating up the A/C compressor during hard/spirrited runs on the street and track. Give me a ring tomarrow if you get time. I would like to bounce some idea's off ya if you dont mind.
Josh@KY-Turbo is offline
Old 11-05-2008, 11:27 PM
PaulC's Avatar
Im seeing 2 different headers in the pics, which are they? The kit looks great.
PaulC is offline
Old 11-05-2008, 11:30 PM
Driver is a 6.0L manifold. Passenger is a C6 vette manifold.
Old 11-05-2008, 11:35 PM
SSilverSSurfer's Avatar
badass anthony, keep up the good work. great guy to deal with
SSilverSSurfer is offline
Old 11-05-2008, 11:57 PM
BLWN1's Avatar
As much as I asked the guy he always takes time to answer, and I havent bought **** from him. Thats about to change...... damn houses.
Looks good, as always.
BLWN1 is offline
Old 11-05-2008, 11:59 PM
headed-ws6's Avatar
kit looks great how much will the hot parts run and can this kit be used with the stock k-member
headed-ws6 is offline
Old 11-06-2008, 05:48 AM
WS6HUMMER's Avatar
Nice build!
WS6HUMMER is offline
Old 11-06-2008, 07:56 AM
Reject's Avatar
sweet, almost exactly like mine!
Reject is offline
Old 11-06-2008, 10:17 AM
Gingervitis Addict
slow67's Avatar
RICE ETR has a very similar setup and hasn't reported any problems.... but I think his piping went around the k member between the a arms.
slow67 is offline
Old 11-06-2008, 10:41 AM
You are correct. I dont see any problem with heating, if so you could use heat shielding to take care of the problem.
Old 11-06-2008, 11:16 AM
99Z28LS1's Avatar
kit looks great!
99Z28LS1 is offline
Old 11-06-2008, 11:28 AM
TurboZ28408's Avatar
you using the BMR k member ?
TurboZ28408 is offline
Old 11-06-2008, 11:33 AM
I am using one I have made for me.
Old 11-06-2008, 12:17 PM
lifeisgood's Avatar
im building this car on a budget. anthony has been very helpful in every aspect... i originally wanted to do a h/c combo on the car. after we talked we came up with prices and the two werent that far off from each other.
so the turbo kit was the way i chose.
most people you deal with when building a car usually talk over people heads and just do it and not care if the customer understands or not.
although i graduated from wyotech and know a good deal about things there was questions i had concerning with this kit and prices. he broke everything down and showed me exactly what i was paying for and why he chose the parts he did for the kit.
cant wait to get this things done
Old 11-06-2008, 12:21 PM
WS6HUMMER's Avatar
Is that a 3" or 3.5" down pipe?
Old 11-06-2008, 12:23 PM
3'' but it can fit larger.
Quick Reply: car in the shop for the build!
