Need help fixing my passenger window
Old 10-17-2008, 12:05 AM
Darkplague's Avatar
Default Need help fixing my passenger window
Hello all,
I noticed that my window in the passenger side would go down but when it was time to roll that puppy up, it only rolls half way up and stops. In one of the posts here I saw good things on the Autotix mod, so I went ahead and bought me that mod. Once received, I went ahead and installed it and still had the same problem, no change. I did hear the relay clicking but the speed of the motor was still the same. I guess I will have to get a new motor. I just wanted to know where I could a get a good motor, should I just go to the dealership and purchase one or should I go to Autozone or O'Reillys?
Would I just need to replace the motor or would I have to replace something else?
Car info:
Trans am 2002/67,254 miles/ONE owner
Thank you,
Ray
Old 10-18-2008, 11:10 AM
Rancor352's Avatar
you can check out the ws6store.com. thats where i just picked up mine the other day.
Old 10-18-2008, 01:19 PM
Darkplague's Avatar
Oh cool, thanks Rancor352..
I will do that.
Old 10-21-2008, 08:12 PM
Cape T/A's Avatar
yep, just pic a new window motor up from your favorite parts store.
Old 10-25-2008, 10:16 AM
jedimaster71472's Avatar
Autozone dumdumdum- lifetime warranty means you get to just pick up a enw one when they go bad.
Old 10-26-2008, 03:01 PM
PONTIAC SLP's Avatar
it's tha same problem with me , i changed the motor and its okay now
Old 10-26-2008, 11:15 PM
Darkplague's Avatar
Thank You for the replies.
Is it easy to replace the motor? What tips do some of you guys suggest?
Old 10-27-2008, 07:04 PM
I suggest going to the shbox.com site and either printing the pix out or bringing the laptop to the garage for reference.
Old 10-27-2008, 08:29 PM
whitdog54's Avatar
First time, you will need to drill out the rivets holding the motor to the arms/frame (not sure what its called). Its not hard, just time consuming if you haven't done it before. Ive never drilled or "worked" on a car really and it took me an hour.
Old 10-31-2008, 08:42 AM
yes like me , it's will take 1 hour work
Old 11-01-2008, 06:45 PM
cmccully04's Avatar
make sure u have a 1/4 drill bit, and aur drill charged.
Quick Reply: Need help fixing my passenger window
