98 + vats + swap car
I know when i did my swap from 2000 v6 camaro to ls1 i was having trouble with wiring and found out that you have to add a wire from the Inj 2 fuse in the underhood fuse box to one of the three big connectors on the passenger fender well. I forget which plug you pin the wire into but i'll look it up if you need me too.
Without it you will only be firing your bank 1 fuel injectors
