More cam install questions..
Well, I've got the cam in, timing lined up, but I do have some questions though. I had the EGR deleted out with tune. So does this mean I can pretty much just take out the whole air pump or do I need it for something else? (I apologize if this is a noob question I'm just not too sure on it.)
The timing cover seals are being a bitch to get out. Any special way of getting these out or is it basically beat them until they pop out? haha
Injectors, I'm kinda confused as how to go about getting them off of the fuel rails and put the new ones in... I'm sure I'm just over looking some easy/obvious way of doing this, but I can't seem to figure it out.
Thanks. And my apologies if these are dumb questions, I just want to avoid forcing something that doesnt need to be forced and end up breakin something!
EGR and AIR are two different things. You can remove the AIR pump, its bracket, tuck the wire connector to it and its electrical connectors as well as the metal line going under your motor. (I did all of that to get rid of as much as I could in the engine bay... however its still crowded...)
BUT you must also delete the AIR codes. You may have had this done but you only indicated the EGR codes had been deleted. Personally I think its just added weight and space *Shrugs* (But then I have the same opinion of cruise control...)
The air pump and all hoses/lines and fuse pulled. I believe it will throw a code and you'll have to tune that out.
Thanks guys, but I'm still trying to figure out how to get the seals out of the timing cover. I have new ones for it and they're not wanting to budge. Any suggestions with that? I have the cover off, I'm just trying to get it back on with the new seals in it.
Yeah I'm putting the new seals in it, but I took a flat head and hammer to it and it just won't move. I'll look into that seal puller and see if anyone around here sells them.
Also, the air pump I'm confused as to what it does.. It has a tube from the CAI to the pump itself, then there is another tube from the pump to some type of "regulator" that goes into emissions piping for the exhaust sooo I can't just take all this bs off and be fine? I figured the EGR was all of that. Apparently not. I'm just a bit confused why it will throw a code. But I am pretty confident I do not want this on my car anymore, it's just wasted space in my eyes unless it does play a significant roll somewhere that I'm looking past.
I have LPP headers (have no recirculation piping on them) thats why I don't think I need the AIR pump at all right? I can take it out, throw a code and get it tuned out later?
