Driver side running lamp
Old 10-18-2008, 12:30 PM
PontiacSpeed91's Avatar
Default Driver side running lamp
My little orange running lamp on the driver side went out today =( i am really really sad as i LOVE to keep my T/a as perfect as possible, im about to go out to buy the bulb and try and replace is, is it an easy fix?
Old 10-18-2008, 12:47 PM
01ws666's Avatar
If this is for a ls1 trans am just reach into the air scoop under the drl with your palm facing up feel the bulb base, push the locking clip in and rotate. mine have enough slack so you can pull it out of the hole enough to swap bulbs then replace and your done...
Old 10-18-2008, 12:53 PM
Thanks man! i appreciate the feedback! ill give it a shot now.
