trying to reprogram my transmitter... having issues
https://ls1tech.com/forums/showpost....6&postcount=22
i have followed all of the directions on the FAQ thread to the T, but after i held the lock and unlock buttons on the transmitter, it didnt do the sequence, nor does the transmitter work.
its my only transmitter and the old battery in it was dead, so i replaced it. and now it doesnt work.
am i doing anything wrong?
Don't know why it's not working. Try shoeboxes 96/97 instructions, his step 1 doesn't mention turning the car to RUN first - maybe that's it?
http://shbox.com/1/4th_gen_tech2.html#1996keyless
i will check out those directions. the alarm is always set, so i do need to turn it into run.
after the off to run 3 times in a row it goes through the motions, then i hold the lock and unlock for the 15 seconds, plus longer hoping that you will hear the locking/unlocking, etc. and it doesnt.
i did clean all of the contacts and the battery is properly seated and i double checked and it was the correct battery for the remote.
