Twin t76's
Old 10-19-2008, 06:28 PM
94supercam's Avatar
Default Twin t76's
Would twin t76's be to much turbo for a lt1 383?? I'm looking for 800 hp. And maybe something capable of 1000hp later on. If not what turbos would be best??
Old 10-19-2008, 08:13 PM
RealQuick's Avatar
The Lt1 with forged internals is a strong motor. Twin t76 on a good motor should make 800rwhp with ~12-14psi.
Old 10-19-2008, 08:22 PM
subarubill96's Avatar
now i wonder what that setup would look like.....
Old 10-20-2008, 03:12 PM
pozesd99''s Avatar
why dont' you do just a single 88mm turbo
Old 10-20-2008, 04:02 PM
sciff5's Avatar
Might need a few more lbs of boost to do that. Even with better flowing heads of an ls1 you cant usually get to 800whp at 12-14lbs without some good aftermarket heads/intake.
+1 for bigger single. It would make things much easier. No need for twins, especially not 76mm twins if your looking for just 800-1000. You could even get that done with one mid frame 76mm
Old 10-20-2008, 05:03 PM
94supercam's Avatar
I've thought of a single turbo but i think im stuck on twins!! If I stick with the idea of twins what turbo's should i go with for my power level?
Old 10-20-2008, 07:24 PM
id go with the 76's since your gonna have a 383, im gonna pm you some info.
