New Bests!
Old 10-20-2008, 01:30 AM
OMGWTFBODY's Avatar
Default New Bests!
Car is as follows:
Cheap 275 Street tires
1998 TA M6
3417 lbs without driver.
Hooker LTs
3" LTs to a cutout (open for the fastest pass, closed on the 2 second fastest passes.
LS6 Intake
dot 4 clutch fluids
Best pass:
http://www.youtube.com/watch?v=EdIZMhNroSc
I got outrun by a damn V6 Camaro.
lawl.
1/8th Mi.
8.33@85.76 for the lazy
1.90 60'
Old 10-20-2008, 11:35 PM
OMGWTFBODY's Avatar
Oh ****!
They closed the track down. That was the last day. =(
Old 10-21-2008, 12:24 AM
snk-huntr's Avatar
not bad.
Old 10-21-2008, 10:13 AM
OMGWTFBODY's Avatar
Car weighed in at 3417 with no driver, and a 1/2 tank.
Old 10-21-2008, 11:47 AM
registered user
ScreaminRedZ's Avatar
Nice run! That's a light car you got there if you haven't done any weight reduction. Very good 60' for non drag radials!
Damn fast sixer!
Is the track closed for good, or just closed for the season?
Old 10-21-2008, 12:19 PM
OMGWTFBODY's Avatar
Damn fast sixer!
a LIGHT car at 3417 without a driver?!!?
Thanks. The track was prepped RIGHT. It freakin booked (Subframe connectors helped)
Track is closed for good. George Howard was unable to renew the lease, and all the future races for the year have been moved to Montgomery ( 3 hrs south)
That V6 had the cutout closed, with exhaust running out a stock LS1 Catback...
Old 10-21-2008, 02:07 PM
PewterScreaminMach's Avatar
Damn, nice 60' on street tires. I know a few people who can barely beat that time with Nittos.
Old 10-21-2008, 02:20 PM
registered user
The TA's usually weight slightly more than the Z28's, but your car weighs slightly less than mine did before the 12 bolt.
Old 10-21-2008, 02:21 PM
Same here. Your car seems pretty light for a TA, OP. Be glad.
Old 10-21-2008, 10:12 PM
OMGWTFBODY's Avatar
I wish I didn't throw 285 in it when I sat in it.
Old 10-22-2008, 11:26 PM
OMGWTFBODY's Avatar
wellllllllll
There went the clutch.
Old 01-17-2009, 02:31 PM
OMGWTFBODY's Avatar
Clutch is in. Also had to replace the passenger axle and pinion bearings. Didn't let go, but it was leaking out of the pinion seal.
Old 01-18-2009, 12:15 AM
TravisMcGill2000's Avatar
dont know if u have ever been to steele. its a great track and there open all year long. matter of fact i will be testing out the new 9in on the 25th
Old 01-18-2009, 09:58 AM
OMGWTFBODY's Avatar
Steele is not somewhere I've been, and it is the closest 1/4.
I've heard nasty things about the shutdown area being potholed. I plan on going in March
Quick Reply: New Bests!
